#1877 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
I wish i was not in the middle of tuning my celica's new supercharger, otherwise my money would be on the table.
#1878 |
Boostin'
Drives: FRS-T
I am VERY impressed with those figures. Amazing work guys!
#1879 |
Drives: AVO BRZ
rated hp / baseline whp * new whp = 345.25 hp
#1880 |
Drives: None yet
#1881 | |
Drives: Argento 6spd FR-S
Great work! Now this is what I envisioned from your kit from the begining. A very repectable number. |
#1882 |
Drives: 2013 BRZ Limited
shit my brain tells me to pay down my loan, but my heart says turbo kit.
#1883 |
#1884 |
Drives: DGM BRZ Limited
It's just crazy how smooth that dyno graph is. Looks like someone dropped a V6 from a 370Z in this thing. There is no surge of boost onset. This progressive output should do wonders on the track.
#1885 |
You guys running into knock issues @ 10psi? Or is the lack of injector cc the reason you're backing off a bit. I know its a fresh motor and you don't wanna blow it up.
#1886 |
Drives: Pearl 86 GT
Now all we need is one for the RHD drive market. Not buying coilovers and mags and going to use that money to boost this. Also bought a GT instead of GTS, for the same reason
#1887 |
6/22/12-2/6/24
That is beautiful work there guys.
Considering how this is for the simple turbo setup do you expect to see a big shift in gas mileage?
#1888 | |
Drives: '06 AM V8V Coupe
Any fuel economy loss at steady low load cruising conditions will be due to the turbine adding restriction to the exhaust, which doesn't seem like it's going to be a big deal. Most turbo engines "spool" well before this one does. Under normal acceleration, engine efficiency will drop a little bit when you use boost, but again it appears there is very little boost below 3000rpm so probably not going to impact fuel economy much. Best if they can tell you how much boost it builds in the lower engine speed ranges, and if they have any exhaust pressure readings (probably not going to be a significant increase). |
#1889 |
Drives: '97 RSP JZZ30 GT-T
god I LOVE that power and torque curve. looks amazing for the kind of car this is!
Germans>Japanese>Italians>Americans. Unless its a Corvette. |
#1890 |
Site Moderator
Drives: Stuff
Just because you have more who doesn't mean the driveline takes more hp to move. So rated-base+new.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| Accelerated Performance 2013 BRZ Intake Dyno Testing Video | Don@Accelerated | Engine, Exhaust, Transmission | 109 | 05-17-2013 11:24 AM |
| Accelerated Performance 2013 BRZ Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 135 | 09-03-2012 11:24 PM |
| Accelerated Performance 2013 BRZ/FRS Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 24 | 07-07-2012 07:05 AM |
| Hello from Accelerated Performance! | Don@Accelerated | Announcements, Contests, Giveaways | 5 | 07-04-2012 08:14 PM |
