Old 09-23-2020, 12:42 PM   #18677
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by Bunchh View Post
I hope these help. These were the only photos I took.. :X I only cut the area where the vents would be (see the second image using the garnish pop clips as reference points for yours). If I had the older model fender garnishes then I would've extended it more back (but I like this design better). I can feel heat escaping through them. I was initially going to install some discreet vents on the oem CWP hood (if you know of any.. let me know!!), but I wanted to keep the oem look. So I tried to take a stab at this one first. Seeing how you have the 86 garnishes, I think it'll be easier to cut out the fake vents on the garnishes than the brz variant.
Does it have any effect on hood lift/wobble at highway/interstate speeds?
dragoontwo is offline   Reply With Quote
Old 09-23-2020, 01:04 PM   #18678
Bunchh
Bunchh's Avatar
Drives: 2017 Subaru BRZ
I didn't notice any of that at highway speeds. I assume if it was an issue, others that have done it in the past with the more popular 2013-2016 brz garnishes would've said something in the diy fender vent threads. My intentions for doing this was to help venting out heat from the supercharger in stop and go traffic and after parking.
Bunchh is offline   Reply With Quote
Old 09-23-2020, 01:30 PM   #18679
Dzmitry
Dzmitry's Avatar
Drives: 2018 Subaru BRZ Limited with PP
Decided to make my 2017 BRZ fender garnishes functional The hardest part was removing the old molding tape......
Very nice and aesthetically pleasing!
Dzmitry is offline   Reply With Quote
Old 09-23-2020, 01:38 PM   #18680
dragoontwo
dragoontwo's Avatar
Really? I can watch as my hood visibly raises above the fender. More speed lifts it more. This is on a 2020 model.
Old 09-23-2020, 01:53 PM   #18681
Bunchh
Bunchh's Avatar
Ah I see what you mean. Let me rephrase my previous post. Yeah I get the "normal" hood lift at highway speed, but cutting the fender to vent out air didn't increase it any further. I say it's "normal" hood lift cause I suspect air is entering through the gap where the hood meets the headlights and the air just wants to exit through the gaps of our hood and fender.. thus lifting our hood above the fenders. Correct me if I'm wrong xD
Old 09-23-2020, 11:55 PM   #18682
norcalpb
norcalpb's Avatar
My hood would lift when the little rubber height adjusters were set too low. Maybe yours weren’t fully adjusted from the factory. Try shaking your hood from where it hangs over the headlight. It shouldn’t move at all.
Old 09-24-2020, 12:08 AM   #18683
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
My hood had these problems, but I discovered my hood stops were actually set too high and keeping the corners raised ever so slightly. I turned them down like a half turn and it seems to have helped. Still solid, just sitting a bit lower. One might also be able to adjust the hood latch to be lower.
Old 09-24-2020, 12:37 AM   #18684
GaDgeT
GaDgeT's Avatar
Installed a Kayak on the BRZ today..
Whispbar aero cross beams and Rhino Rack ditch mount racks
GaDgeT is offline   Reply With Quote
Old 09-24-2020, 03:14 AM   #18685
GaDgeT
GaDgeT's Avatar
Originally Posted by beltax90 View Post
how much hp we talkin' now? like how it's colormatched btw
Thanks mate, custom order from the manufacturer ;p Haven't got the conversion chart handy, but estimating that it adds at least 100FP (fish power) to the rods and rear wheels
Old 09-24-2020, 07:08 AM   #18686
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
Is that 100 FP at the rod or at the reel? Cus rear reel fish power is all that matters.
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 09-24-2020, 07:54 AM   #18687
dragoontwo
dragoontwo's Avatar
I'll check that out.
Old 09-24-2020, 12:01 PM   #18688
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Do you have a spoiler or a color matched trunk?
tehShirt is offline   Reply With Quote
Old 09-24-2020, 05:57 PM   #18689
GaDgeT
GaDgeT's Avatar
Both?
Old 09-24-2020, 06:13 PM   #18690
tehShirt
tehShirt's Avatar
Both?
I wasn't clear, I was wondering if you had a trunk like this paint matched or just an OEM trunk with a spoiler.
