, dpfarr
Old 11-17-2016, 11:21 PM   #1849
Silverfox
Silverfox's Avatar
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Originally Posted by paiceyfan View Post
Is there a normal idle? Mine is stock except for the SC and the idle bounces between 500 and 900 RPM constantly. I hope there are those whose idle is constant.
Sent from my XT1031 using Tapatalk
Yeah mine does that same fluctuation sometimes when the A/C is on.
Silverfox is offline   Reply With Quote
Old 11-18-2016, 03:31 AM   #1850
Kodename47
Kodename47's Avatar
Drives: UK GT86
High cold RPM is normal, happens on the stock car to. It's for cat heating.
As for bouncing idle, sounds like the idle control needs sorting.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-18-2016, 06:09 AM   #1851
ajc209
Drives: GT86 Cosworth
The ecu is probably still learning. After flashing mine a few times I have noticed it either learns really quickly and gives a steady idle regardless of turning on the a/c or loading the alternator, or it take months.
ajc209 is offline   Reply With Quote
Old 11-18-2016, 09:44 AM   #1852
paiceyfan
paiceyfan's Avatar
Drives: 2014 Porsche Cayman S
It's been eight months now, so I hope it's not that slow a learner 😀
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
paiceyfan is offline   Reply With Quote
Old 11-18-2016, 09:58 AM   #1853
ajc209
Could be the idle control then like kodename said.
Old 11-18-2016, 10:12 AM   #1854
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Two months ago I stopped by CSG to flash to the CARB/EO tune, and immediately I noticed an occasional hesitation at around 4k-5k RPM under partial throttle conditions. I thought it'd give the ECU time to learn, but it hasn't gone away. It doesn't happen at WOT or the low end of throttle input; but more at 50%-70% throttle. It'll happen when i'm rolling along at 'cruising' speed (RPM around 2.5k) and push the pedal down to accelerate (not WOT) and it'll buck a bit when it hits around 4k. It doesn't happen every single time though.
It happens straight from cold through normal operating temps so from what I can tell, it doesn't seem to be very temperature dependent. I stopped by Edelbrock for them to get some logs, but it only manifested itself a few times during the drive, and we didn't see anything weird in the logs, so it seems safe to drive as is (which was my main concern). We saw it show up as a blip in RPM but weren't sure why.
Anyway, I'm hoping that they'll have a chance to take a more detailed look at it (I'm wondering if other people have experienced the same issue), as it's a little bit annoying for daily driving. They've been very responsive and helpful. I'd rather keep the EO tune rather than flash back to the original one (which did not present this issue) just to keep it 100% compliant.
shiumai is offline   Reply With Quote
Old 11-19-2016, 08:22 AM   #1855
mert34
Drives: 16 Brz.
Originally Posted by Silverfox View Post
Damn. Well I would push for that. They've been making that a staple of their sales pitch and I haven't seen anything on here that says they had changed that offer. Great company so I'm sure they will make it right. If you are self installing definitely go back and read dos and donts. I would recommend getting it professionally done if you want to utilize the warranty. Otherwise read the DIY and have fun 👌🏽 no other parts needed it's an amazing kit right out of the box.
Thanks for the answers. Just took advantage of the dt sale they had to order the tune. I will be self installing. It didn't look too complicated from the online PDF. Does the d-box make that much of a difference?
mert34 is offline   Reply With Quote
Old 11-19-2016, 07:26 PM   #1856
Silverfox
Silverfox's Avatar
Only about 10-15 extra hp!! Definitely a significant difference for me considering the very affordable price point.
Old 11-20-2016, 10:34 PM   #1857
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Shoot me an email, lets get you setup with a Delicious Tune!
The Racers Line is offline   Reply With Quote
Old 11-20-2016, 10:48 PM   #1858
paiceyfan
paiceyfan's Avatar
I am considering that option, but we are saving for a trip to Africa, so I don't if or when that is going to be a possibility. Cheers!
The Following User Says Thank You to paiceyfan For This Useful Post:
The Racers Line (11-20-2016)
Old 11-21-2016, 10:18 AM   #1859
GT86Asia
Drives: 2016 BRZ
The idle RPM oscilation is because of the Edelbrock intake design, I had the same issue, and my car actually stalled when I had the AC on and it was hot outside this past summer.
In any case, the problem was solved by about 99% with the NEW version of the Delicious Tune update tune.
So I strongly advice you contact DT for a tune from them. Bill know what he is doing.
There was also a small problem with the blip rpm at 4-5k rpm, and he kinked it out as well.
A third problem was when taking off, sometimes it would be a bit of a rough take off with a hesitate as soon as you pressed the gas. He fixed that too.
I've been driving with the edelbrock since May, with these issues, then the Delicious tuning update tune came out around June/July, and since then it's been like driving the car with stock reliability, but with power that makes mustang and gti owners cry and wonder why they wasted their money in their cars instead of a brz, haha. :-)
GT86Asia is offline   Reply With Quote
The Following 3 Users Say Thank You to GT86Asia For This Useful Post:
paiceyfan (11-21-2016), Silverfox (11-21-2016), taiguy (11-21-2016)
Old 11-21-2016, 10:19 AM   #1860
GT86Asia
Drives: 2016 BRZ
Oh, and forgot to mention, the rumor is Edelbrock is supposed to be working on a redesigned V2 air intake, to help with this idle rpm hesitation issues, but I haven't heard if its something that it will really happen or not.
The Following User Says Thank You to GT86Asia For This Useful Post:
taiguy (11-21-2016)
Old 11-21-2016, 09:32 PM   #1861
taiguy
Drives: 2013 Black BRZ Limited
just curious, what sort of mpg are you getting with the DT?
taiguy is offline   Reply With Quote
Old 11-21-2016, 09:47 PM   #1862
Silverfox
Silverfox's Avatar
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
I'm averaging 24.5 on 91 with a heavy foot.
The Following User Says Thank You to Silverfox For This Useful Post:
CSG Mike (11-22-2016)
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 01:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 05:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 03:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
