#1849 | |
BoostedBRZ
Drives: Turbo BRZ
#1850 | |
Chin Chief Instructor
Drives: 2015 Ford F150 Aluminium Couch
2015 Subaru BRZ
2008 NC Miata with 2.5 swap Building 1963 289 Cobra Le Mans Replica Cobra Replica Build Pics Chin Chief Instructor www.ChinTrackDays.com |
#1851 | |
Drives: 2013 BRZ Limited M/T
Sent from my Nexus 6P using Tapatalk |
#1852 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#1853 |
[ame="https://www.youtube.com/watch?v=liTSFI4PAPs"]JDL Auto Design BRZ turbo kit tour - YouTube[/ame]
#1854 |
Drives: 2013 Subaru BRZ
Do you plan on having your engine built? Or keeping it all stock?
I can just imagine a lot of stress on it via Turbo + Track Time. |
#1855 |
Not planning to run a lot of boost on track or often on the street. Stock motor should hold up for a while but we'll see. 400whp at ~14psi for the occasional fun run and 325-350whp at 10-12psi on track assuming temps and pressures are in check. This isn't a dyno queen or a driver with something to prove.
#1856 |
Drives: 2014 BRZ Limited
I think one of my favorite aspects of this particular car journal is how methodical you are with all your parts. Can't wait to see the finished product!!
#1857 |
Drives: WRB Brz / SR S14
Does the kit include all the AN fittings that were in your video or was that an option on JDL's website? Also, are there any instruction for the kit? Thanks
#1858 | |
#1859 | |
Sent from my Pixel using Tapatalk |
#1860 | |
The Precision base turbo is good and you can get it sized to make more power than the stock motor can handle. It's a journal bearing turbo and it will make 300whp on pump gas pretty easily. I prefer the Garrett turbos because theyre ball bearing and oil/water cooled so there's more inherent durability there. Can't go wrong with either turbo but for a simple street build I would stick with either of the base turbos. |
#1861 |
Drives: frs
I thought you would stick UEL
#1862 |
Fueling stuffs. Walbro 485 pump kit and ID 1050X injectors to deliver ethanol sufficiently.
| Tags |
| jdl turbo, mazworx, racecomp engineering, track build, verus engineering |
| Wnt3d's 86 - Turbo E85 Daily/Track Build | wnt3d | Member's Car Journals | 77 | 07-17-2017 03:35 PM |
| No Limit Motorsport Full Blown BRZ Build | No Limit Motorsport | Member's Car Journals | 16 | 07-08-2014 12:46 PM |
