Old 08-02-2020, 01:47 AM   #18593
newyorkreload
Drives: Safari build FR-S
After a few months of piecing together a set of used 4-pot/2-pot calipers to rebuild and DIY powdercoat. I finally got them finished and installed with some DBA 5000 fronts and 4000 rear rotors.
Was a long time SWRT fan and have a soft sport for Prodrive, and as these calipers were on the P1 Impreza I don't feel bad about putting their name on them.
newyorkreload is offline   Reply With Quote
The Following 4 Users Say Thank You to newyorkreload For This Useful Post:
Busybee (08-02-2020), MJones_RB (08-03-2020), new2subaru (08-02-2020), Stephen W. (08-02-2020)
Old 08-02-2020, 11:19 AM   #18594
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Love it. I am a Prodrive fan as well. I may have to do this on my 04 WRX when the brakes need a rebuild.
Ernest72 is offline   Reply With Quote
Old 08-02-2020, 02:05 PM   #18595
I think we are in the presence of an expert. I just can't believe the amount of "stuff" going into the little Twin..
Then you haven't seen the Junk in the Trunk thread.... @Busybee you should definitely add this there!
Busybee (08-02-2020), JD001 (08-02-2020), why? (08-07-2020)
Old 08-02-2020, 02:08 PM   #18596
JD001
JD001's Avatar
Drives: Subaru BRZ
Technically anything defined as "junk" won't make a finely crafted temporary abode.. I will head over to the referenced thread as it may contain some insight. If I don't surface then you are to blame..
Old 08-02-2020, 02:16 PM   #18597
The phrase may have lost something in translation....
JD001 (08-02-2020)
Old 08-02-2020, 02:40 PM   #18598
Stephen W.
Stephen W.'s Avatar
Drives: 1993 Caterham HPC Evo
For those outside the US it's "Loot in the Boot!"
The Following 2 Users Say Thank You to Stephen W. For This Useful Post:
JD001 (08-02-2020), soundman98 (08-03-2020)
Old 08-02-2020, 02:59 PM   #18599
JD001
JD001's Avatar
Drives: Subaru BRZ
I was only messing with you.. my trunk's junk consists of some non junk items, 2 puncture repair kits with 2 electric pumps ( Subaru OEM and one aftermarket). One footpump, a medium size bag containing car cleaning stuff. And, my sister-in-law's wedding guest book, still in its wrapper... She had given me the book to take to the wedding venue, I placed it in my trunk and you can guess the rest...
The Following User Says Thank You to JD001 For This Useful Post:
Dadhawk (08-02-2020)
Old 08-03-2020, 04:32 PM   #18600
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Went to AutoX Saturday
Thanks @turtlesharkshooter for the awesome pics!
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
MJones_RB (08-04-2020), norcalpb (08-04-2020)
Old 08-03-2020, 10:25 PM   #18601
aaron_latimer
aaron_latimer's Avatar
Drives: 2017 Toyota 86
Polished and Waxed my car for the first time.
Honestly was super nervous to polish/wax my car. Thankfully the compound I used isnt too aggresive. So it helped a novice like me. One day I'll be pro at it haha. Check it out.
aaron_latimer is offline   Reply With Quote
The Following User Says Thank You to aaron_latimer For This Useful Post:
Old 08-04-2020, 01:50 PM   #18602
6ixbrz
6ixbrz's Avatar
Drives: 2017 Subaru BRZ
Made a video cleaning my wheels.
I may have gone a little over board here, but I deep cleaned my stock wheels and put a protective coating on them to help with future washes and brake dust.
6ixbrz is offline   Reply With Quote
The Following 2 Users Say Thank You to 6ixbrz For This Useful Post:
Busybee (09-13-2020), MJones_RB (08-04-2020)
Old 08-04-2020, 10:45 PM   #18603
soundman98
ProCrastinationConsultant
soundman98's Avatar
we've got a few threads for this, both showing off, and asking questions!
couple notes for the future:
yeah, it usually takes me about 1-2 full days to do a car-- i'll usually try washing/claying the night before, and then it leaves the entire day for buffing and waxing, with time to clean up the interior while the wax is setting up in the end. last time i did my car, i was doing it at 4-5hr stints at night, it took me a full week.
did you use the same bucket/soap/mitt on the wheels as you did on the rest of the car?
did you clay bar the car after washing but before buffing? claying the car makes for the best paint setup-- it will strip off any contaminants in the paint, which means you need to do less work with the buffer to get a nice finish.
i use the larger 'professional' buffer from HF(harder to learn with, but can offer better technique in certain circumstances, you got the right one for starters), i usually leave it at about halfway on the speed, but then bump the trigger to dial in the speed i really want the pad to spin at..
it looks like you did most of it outside, car detailing is best done in the shade. for that, i usually empty out the garage and park it in the middle of the two bays, or set up some canopies over the car. the reason it's best done in the shade is that it keeps the paint and body panel temperatures consistent across panels. buffing heats up the paint and 'moves' it around on the car-- all things equal, if you're buffing a scratch that goes across an area that's in the shade, but also in the sun, the same force/time spent into the buffer to correct the scratch in the shaded area will be 2-4 times more force/time than the sunny area will need.
i've also found that working outside doesn't have the greatest of light-- i strapped a 4' led work light to a hand truck so i could see the blemishes in every panel. in the past, i've used halogen lights sitting on the floor, or those drop-down 'work lights' to see where blemishes are and how far i need to correct them. it becomes very easy to miss parts of the body that you regret later not addressing!
one of the techniques that i always try to teach people is to treat the paint as a very firm clay that you're smearing around on the car body. pushing in one direction and then pushing the opposite direction can help balance and fill in blemishes that just straight moving from one side to the other won't fix. for me, it also helps understand that if you put way too much pressure in, it can cause damage to the surface, just as sticking your finger into the side of a clay pot
and lastly, i don't really ever use all 3 steps. i vary everything based on how bad it really looks. compound is the most abrasive, polish is least abrasive.
for things like bird poop stains, and scratches that are very obvious but can't be felt with a fingernail, a compound is really needed, or double the work with polish (i usually just either put some compound on a towel and work it by hand, or will use the machine and do a double-pass with polish to get the same effect). for water spots, and scratches that can be just barely be seen, the polish is all you need.
you're going to notice this in about 2-3 days now, but painters tape is your friend. any black textured plastic pieces that you might have accidentally bumped with the buffer pad and the compound/polish are going to turn white in those spots(i haven't met anyone that can do a whole car and not hit a few of them). so before you start, it's best to cover over all those spots with blue painters tape to minimize the damage(and blue painters tape doesn't like to release if it's been out in the sun for a while, another reason to do it in the shade!). those pieces can be brought back by mothers Back To Black, or similar products, but it's really a pain to use-- it requires multiple recoatings, and seems to wear off very fast.
and lastly, i hope you had fun! there's ways to do it faster, and there's ways to do it slower. but the most important thing to take away from it is that there's a million different ways, techniques, and products to do it, and they all end up with the same result!
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
SkyeHack (08-25-2020), wolffbite (08-18-2020)
Old 08-06-2020, 09:57 PM   #18604
N_Raged
Drives: 2019 BRZ Sport-Tech RS
Changed the oil for upcoming track days. First time doing it myself on this car, easiest oil change I've ever done - no engine covers, no cartridge filters (my Saab had).
N_Raged is offline   Reply With Quote
The Following User Says Thank You to N_Raged For This Useful Post:
soundman98 (08-09-2020)
Old 08-07-2020, 09:36 AM   #18605
SUSPECT_BRZ
SUSPECT_BRZ's Avatar
Drives: 2020 Subaru BRZ TS
I drove it to work, owned it for almost two months and there is only 600KM on the clock...
SUSPECT_BRZ is offline   Reply With Quote
The Following User Says Thank You to SUSPECT_BRZ For This Useful Post:
MJones_RB (08-07-2020)
Old 08-09-2020, 06:12 PM   #18606
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Spent the weekend prepping the ol' Turbo kit for sale. Just waiting on a couple of replacement silicone couplers to arrive. Hope it will bring just enough to let me finish my other engine build. :P
The Following User Says Thank You to Kiske For This Useful Post:
