Old 12-07-2018, 09:55 PM   #1807
staples323
staples323's Avatar
Drives: '22 GR86
Originally Posted by Kodename47 View Post
It's normal
Cool, thanks for the reply
2022 Toyota GR86 Halo NASA TT5
2015 Subaru BRZ Crystal White Pearl NASA TT5 SOLD
staples323 is offline   Reply With Quote
Old 03-31-2019, 10:55 AM   #1808
Balf
Drives: 2013 WRB BRZ Limited 6MT
Datalogging question
Hi all, I have tuned my car with an OFT and would like to see how things are running post tune. It's currently running the v4 stage 2+ tune, using 93 octane gas regularly. I don't really know what kind of driving needs to be recorded, so I'm hoping someone could give me a bit of guidance. I did record a few logs yesterday with the default settings, but I have no idea what I'm really looking for.
Mods:
Perrin drop-in intake
Perrin intake tube
Gruppe-s UEL header
Gruppe-S overpipe
Invidia Q300 catback
https://datazap.me/u/balf/wot-0?log=0&data=1
https://datazap.me/u/balf/driving?log=0&data=1
https://datazap.me/u/balf/more-driving?log=0&data=1
I appreciate any help.
Balf is offline   Reply With Quote
Old 03-31-2019, 11:24 AM   #1809
tomm.brz
Drives: brz 2017 hksv2
Looks ok, maf looks good, maybe next time log also flkc, so you can see if some knock occurs
and do a WOT from 2k to redline in 3rd gear, like smash the pedal exactly at 2k rpm
Old 04-02-2019, 11:35 PM   #1810
Balf
More logs
Alright, I found some time and clear roads to finally get some clean(ish) pulls in 3rd gear as requested. There was maybe 5 minutes of driving around time between the 3 recordings.
https://datazap.me/u/balf/4219-3rd-g...&data=1-2-7-12
https://datazap.me/u/balf/4219-3rd-g...l?log=0&data=1
I appreciate the input.
Old 04-05-2019, 10:30 PM   #1811
Balf
Any thoughts? I see some FLKC, but IAM never changed. Does that mean anything?
Old 04-06-2019, 02:59 AM   #1812
tomm.brz
remove a bit of ignition timing from 4800 to redline, like -0.7 from 4800 to 6000, and -1,05 from 6000 to redline
Old 04-14-2019, 04:58 PM   #1813
mcsmokey
mcsmokey's Avatar
Drives: 2016 Scion FRS
I was wondering if anyone could take a look at these for me. I was thinking that I might have an exhaust leak after I installed some JDL headers and saw what I thought were high LFTF but after reading around i'm not sure if its anything I should be worried about.
OFT E85 Tune
Perrin Drop in filter
JDL Headers
3rd gear pull
https://datazap.me/u/micha3l/e85leak?log=0&data=1
mcsmokey is offline   Reply With Quote
Old 04-15-2019, 01:56 AM   #1814
tomm.brz
seems good, a bit goofy afr that goes rich on low rpm /high load and goes leaner on higher rpm, shouldn't be a problem on e85, maybe fix a bit the maf scaling
Old 04-24-2019, 09:40 PM   #1815
Balf
I haven't got around to actually changing anything in the tune, but i did take another log today for the hell of it. This one shows positive flkc from 1600 to 3500. I've never seen it be positive before. What could that represent?
https://datazap.me/u/balf/424run1?log=0&data=1-12
Old 04-25-2019, 02:05 AM   #1816
tomm.brz
positive means it knocked much enough to let the advance multiplier go down from 1, and te tries to let him go uo again advancing the timing
when it s positive you have an adv multiplier of 0.94, it succeded raising it to 1 again, but shortly after started to knock and correct the timing again
remove 0,35 of ign timing from 4600 to 5200, remove 0,7 from 5600 to 6000, and remove 1,05 from 6400 to redline and you should be ok
Old 05-01-2019, 09:13 PM   #1817
Balf
when it s positive you have an adv multiplier of 0.94, it succeeded raising it to 1 again, but shortly after started to knock and correct the timing again
Thanks for the info. I finally got around to flashing an adjusted tune, but based on your previous recommendations. Third gear pulls as always in all these logs. Another question....how much driving should I be doing in between flashing and logging? The ECU needs time to feel things out, right? These logs were recorded the same day as flashing, but after about an hour of varied driving (highway and traffic).
Side note, I've been hunting down what sounds like an exhaust leak. Would a substantial enough leak cause any performance issues that could be recognized in a log? I feel like i'd want to get everything all sealed up before trying to get the tune just right. Or is that nonsense?
https://datazap.me/u/balf/4-27run1?log=0&data=1
https://datazap.me/u/balf/4-27run2?log=0&data=1
https://datazap.me/u/balf/4-27run3?log=0&data=1
Old 05-02-2019, 03:22 PM   #1818
tomm.brz
still knocky, and rich
you could pass on the rich but try remove 1.05 degrees ign tining from 4600 to 6000 and 1.75 from 6000 to redline
Old 05-13-2019, 08:19 PM   #1819
Trac Toy
Trac Toy's Avatar
I'm using an unmodified OFT 4.01 tune (The one with the quiet start and starting at 0.7 for the timing advance)
I noticed late last year that it was having a hard time getting back up to 1 from .7.
So now that the car is back out this year i started having a closer look at it.
I'm running 94 octane fuel, 10% ethanol, which i've never had issues with in years past.
Car has UEL header and full invidia cat back, BPB installed.
I have a weak coil on #1 cylinder and will be replacing it shortly.
Here is my log from a track day session this past saturday.
https://datazap.me/u/tractoy/log-155...0?log=0&data=1
Anyone offer some insight?
My only two options as i've not changed anything on the car is either the weak coil is causing the issue, or the BPB with the updated OFT tune. My Old tune file i had changed to support the blocks.
Anyway, any help or insight would be welcome.
Thanks.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 05-16-2019, 04:51 PM   #1820
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Hi, Can someone look at my logs also please. I think my AFR is not good and should scale my MAF. Also, I'm seeing negative FLKC.
Mods: Perrin CAI, OFH UEL with Perrin OP, Berk FP and Invidia CB.
3rd Gear Pull:
https://datazap.me/u/sideways/oft-te...data=1-8-10-11
Sideways is offline   Reply With Quote
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
