Old 01-24-2017, 11:20 AM   #169
jvincent
jvincent's Avatar
Originally Posted by Tor View Post
If you can check the name of that adapter it would be much appreciated. I don't get anywhere near those update rates.
I'm on Android so I use the bluetooth version of this, which has very good update rates.
http://www.obdlink.com/mxwf/
Old 01-30-2017, 12:21 AM   #170
ysu
Drives: Toyota 86 GTS Auto
Obdlink LX (green) is the bluetooth one. Perfect for Android linking, not so much so for Apple afaik.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
Old 01-31-2017, 06:41 AM   #171
Tor
Tor's Avatar
Drives: Toyota GT86
Yes, I may do something with my head unit, or buy a cheap android tablet and mount it in front of it. If I do, I'll get the OBDLink LX. I only heard good things about it.
Tor is offline   Reply With Quote
Old 02-11-2017, 01:44 AM   #172
Spec C Wannabe
Drives: 2017 WRB M/T BRZ
Not driving much at the moment because of the winter weather. I'm not working on the car much either as it's so bloody cold in my garage.
I did do a bit of weight reduction, however. Replaced this:
With this:
The car is noticeably faster without that extra weight.
Interested in your DIY Tuning as your result just turned out GREAT!!
What program or application did you use for tuning your car?
How did you manage to fix the Torque Dip?
I used to tune many WRXs in the past, so don't worry as I understand all those ECU tuning basics/ knowledges and terminology. I just need your kind sharing of which parameter to tune out the torque dip on the BRZ/GT86.
Did you do anything to VVTI (Variable Valve Timing) tables? Or you just tune the A/F and Ignition timing like normal tuning.
Thanks in advance for your kind advice
Spec C Wannabe is offline   Reply With Quote
Old 02-11-2017, 09:45 AM   #173
Tor
Tor's Avatar
Drives: Toyota GT86
Thank you. Yes, the car runs fantastic and it's now a lot of fun to put the foot down from already 3000 rpm. The Virtual Dyno curve depicted in the video is from the actual wide open throttle pull shown in the video. Bumps in the road will, of course, affect the result somewhat. I have, however, made several pulls that all show roughly the same results. I can't say (yet) how they will compare to actual real dyno graphs. I suspect they will look fairly similar, but will show a larger drop off above 7000 rpm, where I suspect the resolution of the logs is too low to provide accurate results. The torque dip is still slightly visible in the curves, but most importantly, not noticeable while driving.
As to "how" and "what":
I use a Tactrix Openport 2.0 OBD2 adapter to flash with their software EcuFlash 1.44. Editing of the tunes is done using RomRaider.
The base of the tune that I am using comes from the free OpenFlash Tablet tunes. They did actual dyno tuning of the FT86 in various configurations and made different tune available respectively. As an example for unequal length header on an otherwise stock car (same as what I have). Among a lot of things that they have tuned is the VVTI (or AVCS - active valve control system - as it's called in Subaru/FA20 terms).
These tunes have then further been refined by open source community. Most noticeably in the tunes by Wayno as you can read a lot about in this thread. These improvements add up to around 50 tables that have been changed with minor fine tuning or large adjustments. There are a lot of (further) adjustments to A/F, timing, and fuelling compared to the OpenFlash tunes.
The tune I run is one of Wayno's tunes with a fair bit more added timing, as we have high-quality fuel in my neck of the woods (100 octane RON or approx 95 US AKI).
Old 02-11-2017, 11:17 AM   #174
Spec C Wannabe
Lightbulb
Hi Tor,
Thank you for your prompt and clear answer, really appreciated your help here. Thank you sir.
OK, I have used those hardware & programs back in my tuning days, though mine were much older version hehe. So, I am pretty familiar with what we are talking about. Actually, I used EcuEdit mainly for rom editing as it has quite a nicer interface and make the rom editing easier and clearer. It has "Microsoft Window" similar interface and it can show very nice 3D Graphs. IF your haven't seen it, check it out here. http://www.epifansoft.com/ecuEdit-screenshots.html. It is very easy to "visualize" the curve/graphs and do the smoothing for A/F ratio and Ignition Timing 3D tables. Bad thing is it isn't free.
My further question:
Your car is EURO version while OpenFlash Tablet is kinda focus more for the U.S. version of GT86 as it is a US based company. So, is your ECU compatible with those of US cars? Do they have free "Off The Shelf" map for the EURO Calibration ID? Or are they all the same US and EURO ECUs? Back in my WRX days, US and UK ECU (mine) are so far different that it is almost useless to use US map as a base map!
And Did you have the guy "Wayno" help you with the tuning? Like sending ECU data logging files to him and let him edit the rom for you. Or Did you just follow his guideline and tune your ECU by yourself?
Thanks again for your kind support.
Old 02-11-2017, 01:05 PM   #175
Tor
Tor's Avatar
Drives: Toyota GT86
For the FT86 it's called BRZEdit. I was told not to waste money on it, as it supposedly doesn't provide any benefits if you are not dyno tuning the car. But, yes, it looks nicer than RomRaider.
They are different, but OpenFlash has tunes for all Cal IDs. So does Wayno's tunes.
Wayno has been a great help in answering a lot of all my question (so is the whole community in the tuning subforum here should I add).
I didn't get "remote tuning", as in making logs and getting a fully customized finished ROM specific to my car sent back to me. But you just have to skip back to page 8/9/10 of this thread to see I did get help with problem areas.
In general, for the whole community, my experience is that if you put in the work and educate yourself the best you can before asking questions, the more likely you are to get help. This is quite logical since everyone here is doing this in their spare time and would probably rather answer a question or help solve a problem that isn't seen frequently than answering the same questions over and over again. There is tons of info in the tuning subforum and searching provides answers to many questions. If there is a problem you can't solve yourself (after putting some time into it) or a question you can't find the answer for (after searching and reading), the community is outstanding to provide help!
The tune I run now, after switching to stg 2, is an almost "standard" Wayno tune. Except I changed the timing to resemble the most aggressive OpenFlash Tablet tune, and am in the process of adjusted it back a bit where there are excessive timing corrections. So far I am doing it on my own.
That's what's the forum is for. Glad to help.
Old 02-11-2017, 10:25 PM   #176
Spec C Wannabe
Thanks a lot for your kind answer and advice to DIY tuning.
Sorry if I asked too much.
Old 02-13-2017, 04:39 PM   #177
Tor
Tor's Avatar
Drives: Toyota GT86
Glad I if I could help. And no, I wasn't referring to your questions here. Just trying to set the expectations.
There is the option to find a suitable ready-made tune and run it with minimal adjustments which require little effort. If, however, you want something beyond that, be prepared to put a lot of time into it.
Old 02-26-2017, 12:50 AM   #178
Tor
Tor's Avatar
Drives: Toyota GT86
Made my car a bit more slippery (for extra speed).
[ame="https://www.youtube.com/watch?v=cA_nW3CAggI"]So you think your car is clean? - YouTube[/ame]
Old 03-05-2017, 07:39 PM   #179
Tor
Tor's Avatar
Drives: Toyota GT86
I installed the Whiteline Postive Traction kit. I have had it lying around for a year but didn't install it because I knew it would take some finagling and it's a bit risky if you mess it up. For anyone interested this is a 25 mins video:
[ame="https://www.youtube.com/watch?v=S3CE29SNT4c"]Whiteline rear subframe inserts installation, Toyota GT86 (Subaru BRZ) - YouTube[/ame]
As mentioned in previous post/video, I clayed and waxed my car and wheels. Since the car was now so sparkling, I felt bad about how dirty it was underneath - specifically the wheel wells and suspension. So I went ahead and washed it all:
A bit nutty, I know...
Also since it's officially spring, I put the Yokohamas back on:
The car is now so clean and sparkling that it's actually a bit ridiculously! It's actually a bit over the top for my taste. I have to get it dirty again ASAP...
The Following 2 Users Say Thank You to Tor For This Useful Post:
Iceman (03-07-2017), Twinguin (03-06-2017)
Old 03-05-2017, 10:21 PM   #180
norcalpb
norcalpb's Avatar
What are your impressions of those sub frame inserts? That was prob the most in depth install I've seen, I might have the confidence to do it myself now.
My only reservation is that I don't want to make the car uncomfortable with these inserts.
Old 03-06-2017, 04:04 AM   #181
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Another option are the STI inserts which are installed only on the front part of the rear subframe. I remember a post of a guy installing the Whiteline inserts in two steps (one day the fronts and another day the rears). The improvement after installing the fronts was noticeable, while the improvement after installing the rears was not so much. Just my two cents of getting the most of this gain with an easier installation ...
Old 03-06-2017, 06:39 AM   #182
Tor
Tor's Avatar
Drives: Toyota GT86
I will report back once I've driven the car.
From my experience, there will be no difference in installing only the fronts. You would have to losen up the rear as well to get the frame to realign with the new way it is seated with the insert stuffed in between.
GT86 - inferno orange Artalos Member's Car Journals 4 04-14-2015 01:21 PM
GT86 TRD Parts Coming to Europe Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 37 12-05-2014 12:07 PM
Toyota Improves 2015 GT86's Dynamics, Adds Shark-Fin Antenna in Europe vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 93 04-26-2014 04:31 PM
No factory turbos for GT86 says Karl Schlicht (Toyota Motor Europe VP) vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 163 03-17-2014 10:53 PM
GT86 pricing for Belgium (Europe) NA_T Scion FR-S / Toyota 86 GT86 General Forum 13 01-15-2012 12:33 PM
