Old 09-03-2013, 07:27 PM   #169
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
Just had it happen yet again. Just out of curiosity i let it sit in neutral then held the clutch in and tried 2nd gear. Same thing. Stuck half way
abutterman is offline   Reply With Quote
The Following User Says Thank You to abutterman For This Useful Post:
radroach (09-06-2013)
Old 09-04-2013, 01:01 AM   #170
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by Carwhisperer View Post
Seems like a noticeable pattern for the transmission. My 4th gear used to be scary going into for the first time and if I went into it again it would be okay. But since 10k miles I'm good. Downshifting 6th to 5th (going 70 mph+)will grind sometimes unless if I do it extremely slowly as of right now.
I get this 6th to 5th grind a lot. It's steadily becoming worse.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Old 09-05-2013, 01:49 AM   #171
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
My 3rd and 4th gear are crunchy and the car is a week old... thought it was just new-car issues, but its getting annoying and after reading this its obviously a problem.
It feels like it just needs better fluid IMO, but I don't want to use the cocktail I used before in my 5-speed Impreza tranny cause that would certainly void the warranty.
Kostamojen is offline   Reply With Quote
Old 09-05-2013, 02:42 AM   #172
asianCHAU
asianCHAU's Avatar
Drives: 2013 Whiteout FRS
Originally Posted by abutterman View Post
i have that crunch in 3rd as well if i'm light on the gas. Mine seems to change all around how it feels every so often. At the moment, i have 2nd feel real rough downshifting from any gear at any rpm and 1st often gets stuck half way in at a dead stop with the clutch in for a few seconds. No grinds though. I dunno what its deal is. i'm at 4500 miles
I have no problems downshifting into any gear, although 2nd needs more effort in blipping the throttle. I feel sometimes like this car only wants to be driven hard to achieve a smooth throw.
asianCHAU is offline   Reply With Quote
Old 09-05-2013, 02:52 AM   #173
asianCHAU
asianCHAU's Avatar
Originally Posted by radroach View Post
Same problems here, 1st gear gets stuck halfway in- not a huge problem but it is a fault.
Sometimes the car is such a breeze to drive, and is very smooth going between gears and getting to speed without fussing and puts a big smile on my face- and then other days the car seems so jarringly rough and unsettled and is hard to drive. Not sure if I just suck at driving or if the car has hidden bugs in it that make the car difficult to drive.
I feel the same about my driving. I'm like arguing to myself if what I did was my fault or that was just the car. When I drove my friends Z3 for hours after class, I never once got in the car and messed up. I drove that thing smooth as an automatic. My FRS on the other hand is a different story.
Old 09-05-2013, 07:03 AM   #174
Weeber
Hey guys I was just wondering why do the Auto transmissions have relatively smooth gear changes without any crunching?
Do they even have synchros?
Weeber is offline   Reply With Quote
Old 09-05-2013, 12:22 PM   #175
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
Is this a serious question?...are you trolling? In case you are serious I will try my best to explain...automatics don't have gears in the same way a manual does. They use something called planetary gear set and use clutch bands that grab each gear set separately depending on where the fluid gets directed too-these combined will be your "gears". Then there's also the fact that an automatic uses a torque converter which uses fluid to transmit power from the crankshaft to the input shaft-this acts like a clutch. So in simple terms when you start to accelerate from a stop the torque converter will start transferring power from the engine to the transmission which will then start with the 1st gear ratio via electronic servos and ecu, that will direct fluid to one side of the bands(think of this as wrapping your waist belt around a spinning round object but with one side fixed and you pulling on the other to stop the rotation of this "round object")thus grabbing that set of planetary gears which then turn the output shaft to the driveshaft, to the diff, and then finally to the wheels. When the transmission shifts it will shift the fluid to a different planetary set by applying fluid to that band and release the first, and will repeat the cylcle for each gear. Anyone chime in that knows better? I'm a little fuzzy on the details.
Gords_zenith is offline   Reply With Quote
The Following User Says Thank You to Gords_zenith For This Useful Post:
Weeber (09-05-2013)
Old 10-07-2013, 11:58 PM   #176
asianCHAU
asianCHAU's Avatar
I think its safe to say my third gear crunchiness has gone away . I'm currently @4600 miles. Although if its cold, it may click into gear like my 2nd gear.
Old 11-01-2013, 12:48 AM   #177
asianCHAU
asianCHAU's Avatar
@5505miles
Seems like I have the same problem again with my 3rd gear. I wonder if it has something to do with the cold weather.
Old 11-01-2013, 04:08 PM   #178
NYC BRZ
AutoX Addict
NYC BRZ's Avatar
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
The car is a lot better as the trans breaks in. I'm just over 17k and the shifter is smooth as butter with a simple fluid change and a heavier shift knob. The 3 -> 2 downshift still sucks though.
2013 BRZ Limited- GBS - 6MT -VIN #0937
~~NYR SCCA # 18 C Street R (CSR)~~
"But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson
NYC BRZ is offline   Reply With Quote
Old 11-09-2013, 07:19 AM   #179
Yukonse7
Originally Posted by FRiSson View Post
I have about 1,100 miles on my MT FR-S. I've noticed that the first and second gear synchros are a bit "crunchy". It is hard to shift into those gears smoothly, there is a little bit of push back and a feeling and sound of pushing metal pieces. It's not grinding at all, and the clutch is fully depressed. What it seems like is synchros that are not as smoothly meshed as they could be. Anyone else having this issue?
Hi, I have experienced a similar issue with my 2013 BRZ. Recently in upshifting into second gear, with the clutch still fully engaged, i heard the sickening sound of syncros grinding. It was as if the gear selector missed second and locked into something between second and fourth. The grinding only stopped when i pushed the stick into neutral. I had the vehicle at the dealer for two weeks where he could not replicate the problem. He did drop the transmission to check the clutch, which he has said was ok. The car is now stored for the winter. Has anyone had this issue with a fix?
Yukonse7 is offline   Reply With Quote
Old 11-10-2013, 03:48 AM   #180
Antheezy
Ive been a bit worried. I grinded twice as of recently. Clutch fully depressed, Pushed the shifter from 2nd to 3rd and heard a grind and it rejected my shift. Is this normal? my fault? Ive been driving manual for over 5 years.
Antheezy is offline   Reply With Quote
Old 11-13-2013, 06:12 PM   #181
EL_to_TBD
EL_to_FR-S!
EL_to_TBD's Avatar
Drives: Scion FR-S
Not your fault.
Look up all the threads in here related to grinding.
This is not normal. Take it to the dealer so it's one more added to the list.
EL_to_TBD is offline   Reply With Quote
Old 12-27-2013, 03:49 AM   #182
crouchingpinoy
crouchingpinoy's Avatar
Drives: Firestorm 6MT
Originally Posted by Rayme View Post
I found that you got to shift a bit "firmer" than softer with this car (compared to like, eh, a dx civic). Just a small firm push instead of a slow/easy slide makes the shift better.
I agree with this. Noticed shifting 1-2 in a "firm" motion instead of granny shifting removes the crunchiness/grinding. I'm still going to change the gear oil because factory is junk...
Rick
crouchingpinoy is offline   Reply With Quote
A bit of a problem Gost Other Vehicles & General Automotive Discussions 13 02-12-2013 07:07 PM
A problem with new rules in SCCA/NASA regarding FIA seats CyberFormula Other Vehicles & General Automotive Discussions 3 11-09-2011 09:13 AM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
