Old 11-01-2013, 02:24 PM   #169
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Originally Posted by endrswrd View Post
I have flashed both a stock image with the 0 padding issue and one of the shiv roms with the bad checksum (I believe its the calculation that is having issues). Both cars were perfectly fine after the flash.
Ah, interesting - so you didn't correct the checksum error? I believe Skullworks did, might be the issue.
Td-d is offline   Reply With Quote
Old 11-01-2013, 02:36 PM   #170
vgi
Drives: frs
Originally Posted by jamesm View Post
yeah i wouldn't go flashing anything not based on the rom that came off of your own car until more is understood. personally i've flashed roms based on my pulled image as well as another (stock image) dozens of times with no issues. i suspect the guy flashed the wrong rom for his car or had some other sort of hardware issue.
maybe you're right, I hope it's not a beta soft.
vgi is offline   Reply With Quote
Old 11-01-2013, 02:46 PM   #171
Td-d
I can tell you that using the various older version of Ecuflash, I've used it literally hundreds of times on my STI, without any problems.
Old 11-01-2013, 03:18 PM   #172
vgi
Drives: frs
just like many other folks i have faith in Ecuflash but it's still a beta
PS for brz i mean
Old 11-01-2013, 03:27 PM   #173
SkullWorks
Drives: SSM LT MT BRZ
That's what I'm thinking as well - he flashed an OFT stage 2 rom I think. At this stage, I would edit whatever rom was pulled off the car to flash, the architecture (i.e. CAL ids) of the various roms is only just being identified.
I hope he managed to get hold of Skullworks, they should be able to take him through the SHBoot process.
Per MikeyPSF: He understood that Colby had worked out the recovery method for this ECU, BUT he was under the impression that there was an AUTO recovery feature, that appears to be not working ***IN MY CASE*** I have full faith that it will work, However Colby is getting married this weekend, Mike offered to try and steal some time from him to help me solve my issue, I insisted that he not think about my utter stupidity until after he has taken care of getting hitched.
Again I have full faith that my issue will be handled early next week and that we will find the issue is my stupidity.
SkullWorks is offline   Reply With Quote
The Following 3 Users Say Thank You to SkullWorks For This Useful Post:
CSG Mike (11-01-2013), jamesm (11-01-2013), Td-d (11-01-2013)
Old 11-01-2013, 03:54 PM   #174
Td-d
I'm sure you'll come right - don't be too hard on yourself - I've also nearly fried the ECU.
I didn't realise that when I got into the car, I had kicked the OP2 extension cable just enough to have it half in half out... I was lucky that I picked it up after a couple of failed attempts, and with the ignition on, and the cable firmly in place, I managed to flash.
I remember having a couple of stiff whiskeys that night
The Following User Says Thank You to Td-d For This Useful Post:
Deadspool (11-06-2013)
Old 11-01-2013, 09:29 PM   #175
ztan
Drives: Toyota 86
How does EcuFlash behave when writing the padded ROM files to our ECU? Does it write all the 00s or does it write from 8000 on?
Asking because my ROM pull was padded and I have not yet tried to write with this beta.
ztan is offline   Reply With Quote
Old 11-01-2013, 10:25 PM   #176
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Along those lines... the only thing I absolutely detest about my BRZ... is the location of the OBDII port. It's like they designed it to put the OP2 in harm's way.
Ralph Spoilsport is offline   Reply With Quote
Old 11-02-2013, 12:26 AM   #177
vgi
Drives: frs
Originally Posted by ztan View Post
How does EcuFlash behave when writing the padded ROM files to our ECU? Does it write all the 00s or does it write from 8000 on?.
well, based on this
if i had to guess, looks like the EcuFlash just writes block 8000-13FEFF and thus the padding difference between oft (FF) vs ecuflash (00) for the first 32768 bytes and last 256 bytes doesn't matter as long as checksum correction is not applied
Old 11-02-2013, 06:53 AM   #178
Td-d
To answer that:
Originally Posted by cboles
Here is a full ROM for ZA1JA00C to get you started. I'll be posting up a beta for and EcuFlash version that does the "OEM style" 0x8000-0x13FEFF reads and writes in the next day or so, just to get you started while I work on finishing up a kernel based reflash which will be quicker and more flexible, along with being able to read out the full ROM. Since there is no longer a kernel loader in the stock ROM, I will be adding a patch to allow for this. I'm also working on another patch to add fast and complete logging capability.
vgi (11-02-2013)
Old 11-02-2013, 10:39 AM   #179
ft_sjo
Drives: GT86
Is the boot loader part of that address range?
The Following User Says Thank You to ft_sjo For This Useful Post:
CaptivaBlueTeg (02-17-2014)
Old 11-02-2013, 11:35 AM   #180
Td-d
I assume so - my understanding is that Colby is also coding a new kernel based reflash alongside the logging capability.
Old 11-02-2013, 11:36 AM   #181
Td-d
I have started on the Ecuflash definition, it's a work in progress and requires an updated 32bitbase.xml - check out the original definition thread for the new links.
The Following 2 Users Say Thank You to Td-d For This Useful Post:
EAGLE5 (11-03-2013), Sportsguy83 (11-02-2013)
Old 11-02-2013, 11:41 AM   #182
utekineir
blowhard
Drives: frs, project forester
is this viable for the unwashed masses yet?
tactrix cable waiting,
very computer literate, but 100% programming retarded.
thanks,
utekineir is offline   Reply With Quote
Close iJason Member's Car Journals 1 08-04-2013 08:26 PM
Close pche Engine, Exhaust, Bolt-Ons 3 08-04-2013 02:04 AM
Sorry. please close. finch1750 Scion FR-S / Toyota 86 GT86 General Forum 1 07-31-2013 01:00 AM
please close abutterman Wheels and Tires 0 07-05-2013 09:40 AM
