Old 09-05-2013, 01:49 AM   #169
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
'Competition Car Suspension' by Allan Staniforth.
Target audience seems to be British hill climb racers who build their own open wheel cars.
Because England???
I got these guys... Because sale at barnes and nobles! lol
I need material that's more concentrated on suspension. Those are more general chassis dynamics.
Just to clarify. They were talking about motion ratios, and the photo I put up is calculation for wheel rates.
Old 09-05-2013, 02:13 AM   #170
Dimman
Kuruma Otaku
Dimman's Avatar
Same topic, really. It's all connected.
(I have the Herb Adams book, too.)
For a pretty in-depth look at the insides of dampers look for 'Race Tech's Motorcycle Suspension Bible' by Paul Thedes and Lee Parks.
Great insight into how the damper curves are generated through orifice size, shims, check valves, bypasses the circuits for high speed and low speed oil flow, etc... Plus a look at the guts on how up to a 4 -way adjustable works (Low and high speed comp and rebound clickers). Plus rebuilding how-to (emulsion and reservoir type rear bike shocks are what best apply to car versions).
Edit:
Because titanium.
Old 09-05-2013, 03:06 AM   #171
autobrz
Drives: Mazda 3
Have you had a chance to measure the stock sway bars to figure what their equivalent wheel rates are?
Also, if I wanted to run no rear sway bar for 100% street, canyon driving on moderate grippy tires like RE760, what would you recommend for spring rates?
autobrz is offline   Reply With Quote
Old 09-05-2013, 05:20 AM   #172
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by OICU812 View Post
Ok I know as stock front is zero camber is that really best for wear even spirited driving steady? Common sense leads me to believe not so and then as DD a guy should consider even half a degree to full degree of negative camber up front agree or no?
That's absolutely going to depend on your driving. I've ran -2.7 on the street and had my tires wear even to within a 32nd across the thread. That was a different car mind you, but there wasn't much body roll in it either.
Old 09-05-2013, 09:28 AM   #173
Wepeel
Drives: '13 BRZ Ltd
Originally Posted by ZDan View Post
I do not agree to disagree! It's not a question of differing opinions, one of us must be wrong! Either offset/scrub radius affects leverage/motion ratios or it does not.
So thanks for making me actually *think* about it a bit
Yer right, changing lateral location of the wheel/tire only increases the lateral loads in the LCA and at the top of the strut, but the leverage/motion ratio between spring and tire is not affected.
Yeah, it's definitely not obvious (as evidenced by the posts following yours ). Takes a little while to think through it.
Wepeel is offline   Reply With Quote
Old 09-05-2013, 09:31 AM   #174
Wepeel
Drives: '13 BRZ Ltd
Decreased offset/increased scrub radius DOES increase leverage.
There can only be one!
This isn't a strut.
Old 09-05-2013, 09:34 AM   #175
Wepeel
Drives: '13 BRZ Ltd
Eibach measured the sways to have spring rates of 141 lb/in front, 113 lb/in rear (at the endlink). After you work through the respective motion ratios they contribute 262 lb/in front wheel rate, 79 lb/in rear wheel rate (in roll).
I posted up all my spring, bar, wheel rate and frequency calculations here:
http://www.ft86club.com/forums/showp...&postcount=108
Old 09-05-2013, 11:34 AM   #176
autobrz
Drives: Mazda 3
wow the stock rear total wheel rate is very soft! That number agrees with my feeling driving the car stock.
Old 09-05-2013, 11:36 AM   #177
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Red face
@Racecomp Engineering, I am still waiting for a good quality Camber Top Mount. Last time I asked you about the issue of Whiteline mount, and u told me that its not fixed. So I did not placed an order.
I have a Cusco strut bar so its seems like all mounts like HVT and Ground control will touch that bar.
So would u plz tell me when those Whiteline mount will be avaliable for sell?
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 09-05-2013, 11:42 AM   #178
Spring rates for stock dampers or coilovers? If coilovers, which coilovers?
Old 09-05-2013, 11:55 AM   #179
solidONE
solidONE's Avatar
Originally Posted by Wepeel View Post
This isn't a strut.
So wheel rates are calculated differently on a strut suspension? Can you show me the calculation for strut suspension wheel rate?
Old 09-05-2013, 12:09 PM   #180
autobrz
Drives: Mazda 3
KW V3?
Old 09-05-2013, 12:10 PM   #181
Dimman
Kuruma Otaku
Dimman's Avatar
It's essentially just the coil rate adjusted for the spring mounting angle.
If you look at a strut the spring and shock are basically locked to the top of the hub since there is no upper pivot. Wheel goes up, strut slides up the same amount.
Because titanium.
Old 09-05-2013, 12:22 PM   #182
KW V3?
With stock valving, I'd recommend you stay with the stock rates. You can go a bit softer if you want a more comfortable ride.
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
