Old 04-16-2012, 08:07 PM   #169
86fanatic
Drives: auto
Originally Posted by Capt Canuck View Post
I wouldn't doubt one of the reasons for the V6's low top-end speed limiter is because of the amount of them that end up in car rental fleets. They don't want anymore of them getting wrecked than need be ;-)
These are still cracking value IMHO and continually banging on about some weak points, that can be fixed, really is fanboyish or having the blinders fastened too tight.
Well you only have to look back one page in this thread to see the video of the driveshaft failing on the V6 Mustang that had it's limiter removed. I was surprised upon seeing that video, and upon further research also surprised to learn that the V8 has a speed limiter which is relatively low for it's power, and same with the Boss.
All in all, it does paint a picture about weaknesses in the drive train.
Of course they are still a good value and your accusation of calling me a fan boy seems way out of place relative to what I was saying.
86fanatic is offline   Reply With Quote
Old 04-16-2012, 08:14 PM   #170
Capt Canuck
Drives: BMW E36 323is
^Ah right! Sorry about that, I did quote you there. Oops I wasn't referring to your post as being fanboyish.
I quoted you for the speed-limiter part. My 2nd paragraph was after looking at carbonblue's post, I should have clarified that better.
Capt Canuck is offline   Reply With Quote
Old 04-16-2012, 08:34 PM   #171
MrBonus
MrBonus's Avatar
Drives: 2012 Boss Laguna Seca
Originally Posted by carbonBLUE View Post
yeah sad that the new v6 driveshaft shatters and the v8 tranny starts having problems at 5k miles
i would spend 30k on a supra with 200k miles on it compared to a new mustang, i may break a driveshaft... at 800rwhp...
the reason why mustangs are cheap is because they are cheaply made and untested... i mean if the 5.0L started having tranny problems for a lot of people at 5k miles... they must have done almost no track testing and built the thing on a computer hoping it would work, the BRZ/86/FR-S has seen 6 years of track testing... i would be amazed if its reliability didnt satisfy me... or if anything broke under 50k miles, even on its first year...
This post is absurd. The transmission "issues" have largely been reported by people who modified and drag raced the car.
The V6 driveshaft was designed for fuel mileage and it is suspected that the speeds from the infamous video were not intended by the manufacturer, creating vibration the driveshaft wasn't designed to take.
Given the heavy motorsport involvement of the Mustang, especially in the Continental Tire Championship running engines nearly identical to that available in the Boss, it's quite clear that the Mustang has no shortage of track testing.
It paints a picture of the upper limits of factory aerodynamics, much like manufacturers like Mercedes and BMW, who don't want a few exercising poor judgment and ending up with a short-distance aircraft.
When I bought my Boss, I did so because I tired of the costly repairs and maintenance of Porsche 911s, both old and new. It's a stout, well-built package of a machine that doesn't have the brittle and expensive movement arms that require frequent replacement of its German and Japanese counterparts when driven as intended. I don't have to worry about the "Porsche tax" if I have an off or have to replace a major component following track usage and I'm happy with my decision.
2012 Jeep Wrangler
2012 Ford Mustang Boss Laguna Seca
2013 Subaru BRZ - On Order
MrBonus is offline   Reply With Quote
Old 04-16-2012, 08:53 PM   #172
Dimman
Kuruma Otaku
Dimman's Avatar
I saw a cut-up V6 display engine at the autoshow, and if the factory headers are an indication, there is still power left in it... (Assuming fitment isn't an issue.)
Because titanium.
Old 04-17-2012, 01:01 AM   #173
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I personally dont have a problem with the boss, it was well designed and doesnt share a lot kf the drivetrain parts as the v6 or v8
My Celica has had no problems that greatly effected the car, and it was a first year model made in 1999 , the first year 2zzge had 2 problems
1 the lift bolts broke, 7 dollar fix and rarely happened also didnt cause the engine to fail, you just didnt have lift anymore
2 oil pump would shatter on a missed down shift, and only if the RPMs breached 11k, none of the internals would suffer damage at those RPMs,
My 5th gear rubs but my tranny is 13 years old, that is my only problem, my engine is beat on from the moment it starts till I get to my destination and im at 155000 miles, there isnt many motors that can be abused like that... My friend has a new v6 mustang and hes having sludge issues, im very hard on my car and do 8000 mile oil changes compared to his 4000 mile changes and I have no sludge issues....
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 04-17-2012, 08:50 AM   #174
MrBonus
MrBonus's Avatar
The Boss's motor is a Coyote-based 5.0 and shares the MT82 transmission with the GT. The main difference is the Torsen differential.
2012 Jeep Wrangler
Old 04-17-2012, 11:54 AM   #175
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I believe if the Mustang V6 had a IRS suspension, upgraded driveshaft, and 18'' wheels standard it would be priced like the old V6 BASE GC(25k) which had those features and more standard.
SUB-FT86 is offline   Reply With Quote
Old 04-17-2012, 02:44 PM   #176
KatHawkDown
Drives: BRZ STi (date TBD)
that why i have so much love for the supra, mechanically, when maintained, by maintained i mean just change the oil, nothing should break for a very long time... a lot of cars cant say that... if its built like a true toyota sports car then we shouldnt have any problems at all.
I think this car will have at least very respectable reliability but there is no way it will be built like the Toyota sports cars of the nineties or eighties. They can't afford that these days. My mother's '08 IS250 has more creaks and rattles than my good buddy's 98 Avalon. I don't have empirical knowledge of this, but they over-engineered them and the Supra is the pinnacle of it. Now they build them just to the point where they have perceived quality and nothing more.
No kidding right? I am honestly astonished at the performance value of all current Mustangs. I drove a Fiesta recently (just for fun) that cost $26k here in Canada. Leaving the dealership I looked at the window sticker of a '12 Mustang V6 that was $22k BEFORE incentives. WTF? Over 300hp, some ok standard equipment, and more than respectable fuel economy for what would end up being close to $7k cheaper than a Fiesta?
Somehow I can't bring myself to buy one though. :-)
KatHawkDown is offline   Reply With Quote
Old 04-18-2012, 04:04 AM   #177
SuqMadiq
Drives: BMW Isetta
All good points, but 'out corner the BRZ and FRS all day long' is pushing it. On a tight and technical AutoX, the BRZ would almost certainly post better times than the GT.
I shouldn't have said all day long, but certainly in stock form the 5.0 will out handle the BR-Z/FR-S. The tires on the Scion and Subaru seem to be a budget tire in my mind, it should have at least a 225.
Anyways, since the Mustang is based on a 2011 design, a $3-4k discount off invoice seems like a pretty good deal. I just checked USAA's car buying service and you can get a 2012 GT for about $25k including destination.
Since the BR-Z/FR-S is brand new you'll be paying the full amount if not more (scumbag dealers adding mark-up).
SuqMadiq is offline   Reply With Quote
Old 04-18-2012, 05:06 AM   #178
KeepGuessing
Drives: e30 150 deville etc etc
Question...
How do you test a rod to a certain HP..unless you've got a spare XxX HP car you're borrowing parts from.
I can see testing them to a certain pressure reading..
Oh there is much to be had by way of aspiration on the Duratec 6. It just lends itself to becoming the a-typical horrible sounding V6 Mustang
KeepGuessing is offline   Reply With Quote
Old 04-18-2012, 05:58 AM   #179
ZDan
ZDan's Avatar
Drives: '23 BRZ
Tire make/model = WAY more important than width. On the same make/model tires in OEM sizes, I would bet on the FR-S/BRZ in a pure handling test (i.e., power not a factor).
But anyway, the FR-S/BRZ have MORE tire width per pound than *any* Mustang, including the Boss 302 LS and GT500.
Old 04-18-2012, 11:25 AM   #180
MrBonus
MrBonus's Avatar
Originally Posted by justaquestion View Post
+1
Cars in the 90s were over engineered, cars of today aren't. Its as simple as that. Not to mention with inflation, you could buy two GT's today for the price of one Supra.
I don't entirely buy this argument. Today's cars have better knock protection, cooling, and performance than 15 years ago.
Most new sports cars need little more than higher temp brake pads or fluid to be flogged on the track without worry while those same cars 15 years ago required larger radiators and oil coolers to do the same and that's before you sort the aging suspensions.
The thing that bothers me about today's cars are the litany of electronic nannies that must be disabled (or cannot be disabled) to protect the driver's body and ego but, of course, that's why we are all interested in the FT86.
2012 Jeep Wrangler
Old 04-18-2012, 12:01 PM   #181
MrBonus
MrBonus's Avatar
http://www.nytimes.com/2012/03/18/au...0000.html?_r=2
Here is an interesting article about the longevity of today's motors. I do however agree with a lot of what you're saying but I think people tend to over-romanticize the quality and engineering of those cars from the '90s.
2012 Jeep Wrangler
Old 04-18-2012, 12:12 PM   #182
Turbowned
Turbowned's Avatar
Granted the 1000+whp capability of stock bottom-end Supras and Skylines were definitely impressive. They were still big, heavy brutes and are outclassed by many of today's performance cars. Not to say I don't love them all (gimme an FD RX-7 or an R32 GT-R any day!); technology just has gotten better.
Motorcycle and Mustang Drift monevasia Other Vehicles & General Automotive Discussions 0 01-15-2012 10:14 PM
Thoughts on the specs from a potential owner... FR-S/BRZ over new V6 Mustang? Shadowsong6 FR-S / BRZ vs.... 17 11-05-2011 10:12 PM
Your thoughts of the Ford Mustang Abflug Other Vehicles & General Automotive Discussions 31 08-25-2011 10:15 AM
Mustang? WOW! Nemesis Scion FR-S / Toyota 86 GT86 General Forum 39 06-19-2010 01:08 AM
2011 Mustang... Shadowsong6 Other Vehicles & General Automotive Discussions 19 12-20-2009 05:00 AM
