Old 01-31-2017, 08:52 PM   #169
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by ogrowup View Post
Anyone know what the spring delete would be on an aftermarket clutch like
a Clutch masters FX 300?
I have an extreme pressure plate on my clutch without the spring and it feels like a 2002 corvette heavy. Nothing to go crying home about.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-14-2017, 09:44 AM   #170
StraightOuttaCanadaEh
Wes
I'm having difficulties, 14K later, shifting smoothly from 1st to 2nd. Would this mod help me find the engagement point better or is it hopeless for me? I did learn to drive manual at 28, so that muscle memory you get as a youngin didn't kick in for me. However, I don't remember having this much trouble shifting in my last manual car.
Old 08-14-2017, 10:34 AM   #171
burningjello
burningjello's Avatar
Drives: 2016 FR-S
Can't guarantee, but that was the shift that I struggled with the most. My wife even noticed how much smoother it was after removing the spring. I'd highly recommend.
burningjello is offline   Reply With Quote
The Following User Says Thank You to burningjello For This Useful Post:
StraightOuttaCanadaEh (08-15-2017)
Old 08-15-2017, 12:32 AM   #172
sato
sato's Avatar
Drives: Dodge Patitas
Shifting issues with 2nd gear will not necessarily improve with this trick; it helps with all shifts. Have you replaced the factory transmission fluid?
Sent from my E6653 using Tapatalk
The Following User Says Thank You to sato For This Useful Post:
Old 08-15-2017, 02:25 AM   #173
NRXRaptor
I've heard mtec shift springs are a good idea too
NRXRaptor is offline   Reply With Quote
Old 08-15-2017, 07:04 AM   #174
Wes
Thanks for the input, I'll talk to my mechanic
Old 01-13-2018, 01:27 AM   #175
Jasonb
Drives: 17 Series Yellow BRZ
Just did this and drive it only 2 miles so far, but I think I’m going to like it. It’s too early to tell for sure already, but I think I noticed smoother shifts and smoother revmatching on downshifts. Will test more tomorrow.
Jasonb is offline   Reply With Quote
Old 01-13-2018, 01:56 PM   #176
HSUBLU
Drives: 2017 BRZ WR Blue
Originally Posted by Romanov View Post
I did this mod and i gotta say, i should have done it sooner. Probably should have been my first modification. The only issue i have now is near the top of the travel it feels loose so i may need to adjust the clutch. (about the first 5% of travel has no feel because its not engaging the clutch).
Originally Posted by Qc86 View Post
Same here! I just did the mod on my 2017 86 and the first 5% feels loose. Anyone know if adjusting the clutch going to get rid of that? Anyone else experiencing that?
There is an additional portion to the clutch spring removal process that will help you with it - here's the link. http://www.ft86club.com/forums/showthread.php?t=8040
HSUBLU is offline   Reply With Quote
Old 01-13-2018, 11:01 PM   #177
Brzandt
Drives: 2014 BRZ Limited.
Read most of this thread and removed the spring today. So much better. I can actually feel the engagement and drive much smoother.
I have ofh/oft, totally transformed the car, but doing the clutch adjustment and spring removal is right up there. Just makes the car so much better to drive and enjoy.
Brzandt is offline   Reply With Quote
Old 01-27-2018, 05:45 PM   #178
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Just did mine today, and the most noticeable thing is that now that the spring assist is gone, I really notice how high up in the pedal travel the clutch engagement it. My pedal position hasn't changed, but I wish the engagement point was a lot lower. I do like the improved feedback though.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
Old 01-29-2018, 10:12 AM   #179
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
You can adjust the engagement point by loosening the nut behind the pedal and then adjusting the shaft.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 01-29-2018, 10:17 AM   #180
venturaII
venturaII's Avatar
That's just going to change pedal height, no? I don't want to reduce the pedal stroke necessarily - just move the engagement point closer to the floor.
Old 01-29-2018, 10:38 AM   #181
8RZ
The Gunshine State
8RZ's Avatar
It changes engagement point as well. There's a video on YT explaining which direction to turn the shaft in order to raise or lower the point (I can't remember on the top of my head).
Current DD: M235i
Old 01-29-2018, 01:06 PM   #182
venturaII
venturaII's Avatar
Yeah, I saw that but got the impression that the net result would be different pedal height only. In order to change the clutch pedal engagement point, you'd have to change the position of the piston in the master cyl; I'll take a closer look at things and see how much adjustability is available...
clutch helper spring, helper spring removal
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
