Old 12-28-2015, 04:29 PM   #169
Uplink
Uplink's Avatar
Drives: anything you let me
Originally Posted by Nitti View Post
What can you do with techstream that you can't do with the android Torque app? Is this the same software used by toyota dealers today? Can you monitor injectors, maf, fuel pumps, give commands to the ECU, open close vacuum valves etc?
It's not a scanner program. It's more for adjusting options on the car. For instance, I used mine to turn off the seatbelt buzzer, turn off the light auto-off delay, turn off the alarm chirp when armed, and set the keyfob so unlock 1 time opens both doors. I believe you can also sync up new TPMS' as well as a host of other options.
Uplink is offline   Reply With Quote
Old 01-13-2016, 12:33 PM   #170
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Carista on android for $20 does the same stuff....
Old 02-22-2016, 10:54 PM   #171
camry619
Drives: Camry
Toyota TIS techstream V10.30.029 tested working fine
Toyota TIS techstream V10.30.029 is tested working fine with Xhorse MINI VCI cable, Xhorse MVCI and Mangose cable for Toyota. Anyone need just download from http://www.chinaautodiag.com/html/mi...nload-223.html.
I have one Xhorse MINI VCI USB cable from http://www.uobdii.com/wholesale/mini...able-2442.html and used it for 4-5 times, it working fine for almost 1 year, and yesterday download techstream V10.30.029 to update.
techstream V10.30.029 installation is a little different from the former version, it need not to active since the supplier contains a txt document with the key to register.
I install techstream V10.30.029 with only sever steps:
1) Install TOYOTA TIS Techstream V10.30.029
2) Install MCVI driver
3) Copy "Mainmenu" application, right click the gray icon "Techstream", click "Properties" - "Find Target", then paste the "Mainmenu" application to replace the existing file.
4) Connect the device to the vehicle and then install driver!
5) Open the icon "Techstream" on the desktop, please note you shoule select area "Europe"
6) When you click "Connect to Vehicle", it pops up a window about "Register Techstream Software) and it asks for a new key, click "Cancle". Go to open the folder "Toyota techstream 10.30.029", open text document "Serie" and copy the key number in it, and paste it into the blank key after "New key" and click ok, register successfully.
7) Diagnose Toyota vehicles.
Done!
Hope it helps!
camry619 is offline   Reply With Quote
The Following User Says Thank You to camry619 For This Useful Post:
tato.valverde (02-23-2016)
Old 02-24-2016, 05:02 PM   #172
BabaYaga
BabaYaga's Avatar
Drives: FRawSome Hot Lava
Toyota TechStream Ver GTS_10.10.018 - Diagnostic Tools for FR-S/GT86/BRZ
Does anyone in Sacramento North CA area or Bay Aria have TechStream? I just need to silence the passenger seat belt buzzer. Can anyone help? Let me know, please!
BabaYaga is offline   Reply With Quote
Old 02-26-2016, 01:20 PM   #173
marksas
Drives: 2013 camry
key fob
I have one Xhorse MINI VCI USB cable from http://www.uobd2.net/wholesale/mini-...able-2442.html and used it for 4-5 times, it working fine for almost 1 year, and yesterday download techstream V10.30.029 to update.
Done!
Hope it helps!
have a question for you,i have a 2013 camry ,has the remote and key in one unit. do i have to program the key and the remote separately? are there 2 separate programs that you will use? in the techstream proggy. not sure ,any help will b appreciated.
marksas is offline   Reply With Quote
Old 02-26-2016, 04:45 PM   #174
HyperTech
HyperTech's Avatar
Drives: Mazda3 2013 / Scion FR-S 2015
is this normal? when i try to download something from the link
it automaticaly block it and say its dangerous, from chrome, firefox and edge (explorer)
HyperTech is offline   Reply With Quote
Old 03-06-2016, 02:35 PM   #175
stevesnj
stevesnj's Avatar
I have TS 10.0.18, can I simply update to the latest version or do I have to just install over again?
My 2016 Build thread
Old 04-05-2016, 08:43 PM   #176
babybreath
Drives: toyota 2014 rav4
how to install Techstream 10.30.029
here is my TIS installation steps
i used MINI VCI OEM cable from http://www.obdtool.co.uk/wholesale/2...gle-cable.html
installed on windows XP
Step 1- install Toyota Teachstream
Open “Toyota Techstream 10.30.029.exe”
Select a steup language to go on
Click Next
Accept the agreement to go on
Customer information: click Next
Click Install to begin installation of Techstream 10.30.029
Finish installing Techstream
Step 2- install MVCI driver for TIS
Open “MVCI Driver for Toyota”
Click Next
Click Install to begin installation of the MVCI driver for TIS
Finish installing MVCI driver for TIS
Step 3- paste and replace Main Menu
Copy “MainMenu” application
Open Techstream Properties
Click Find Target
Paste “MainMenu” application in C:/program files/toyota diagnostics/techstream/bin, confirm file replace
Close bin folder and Techstream Properties
Connect the mini vci cable to the vehicle and then install the driver
Open “Techstream” on Desktop
Click No
Select Setup->Techstream configuration
Select an area (here: Europe), click Next
Select a language (here: English), click Next
Techstream configuration, click OK
open Desktop folder “Toyota Techstream”->notepad “serie”
Copy the key
Click Connect to vehicle in Techstream interface
Paste as the New Key when register Techstream software, click OK
Finish Option (here: VIOS, China & 1205-), click Next
Select Engine and ETC to continue
Trouble codes display
Select Data list on the left menu
(Lost communication with vehicle: click Retry)
Click Close->Main Menu->Log out (Techstream)
babybreath is offline   Reply With Quote
The Following User Says Thank You to babybreath For This Useful Post:
Imperius (02-08-2017)
Old 04-06-2016, 10:37 AM   #177
BabaYaga
BabaYaga's Avatar
I end up buying the cable from aliexpress - installed the app on my comp - did couple of twiks in the the process and successfully updated all Customizable settings in both my toyotas: Camry Hybrid and FR-S.
Made the sound of locking car more loud (with 3 pushed on remote lock button car makes 2 loud buzzes and one horn beep).
Changed to open trunk with 2 quick clicks on remote.
Silenced the front occupant seat alarm (decided not to silence driver side).
DRL decided not to turn off - but turned it off on Camry.
On Camry change the settings of open/close doors - now with long push on open button - window is rolling down.
Also, when driver door get unlock via remote access - all doors got unlocked.
Anyway, I like it and if anyone needs help in Sacramento area - shoot me PM, we might meet and I can customize your GT-86.
Old 04-12-2016, 08:51 AM   #178
Toy1
Drives: ..
Thank you everyone for a very informative thread.
I have the cable with the 2.0.4 firmware, I got it to connect once but on the second time I started getting a Can't connect to vim error, the firmware update tool still sees the cable, I have tried on different computers, firmwareupdate connects to it and the TIS software let's select xhorse but I get the vim error.
Toy1 is offline   Reply With Quote
Old 04-19-2016, 03:45 AM   #179
Liliflower
Drives: 2008 FT86 GTS
VIM error is because the mvci software (toyota,honda...) will both communicate with MVCI hardware, and interrupt Techstream working.
Solution 1:
Restart laptop.
open Techsream, click “Setup”, then “Techstream configuration”.
Select “Area Selection”, get a country list and then select “Europe”.
Select “Default Language Selection” and choose “English”.
Click “Ok” in the next window.
Solution 2:
Install MVCI software and drive on a desktop with Windows XP system.
Run Techstream separately.
so that's why most people use mini vci cable with toyota software only.
http://www.obdii365.com/wholesale/mi...-shipping.html
FIY, latest techstream goes to V10.30.029
Liliflower is offline   Reply With Quote
Old 06-01-2016, 09:06 PM   #180
FX86
i set the region to north america and it detected my car and let me customize the settings...but in europe it gave me some weird codes which i didn't have a clue about
Old 06-16-2016, 03:54 AM   #181
Chasen
Drives: toyota camry
This is all about Toyota Techstream TIS v11.00.017, including free download link, new information (models, features, corrections).
http://blog.uobdii.com/toyota-techst...-where-to-get/
Chasen is offline   Reply With Quote
Old 10-14-2016, 10:39 PM   #182
camry619
Drives: Camry
Techstream lite v11.20.019 tested without problem
Today, I received notice that Techstream lite v11.20.019 tested no problem working with xhorse clone mini vci cable, and they attached a download link, I tested it with success, I would like to share with all of you guy here. Anyone who want it browse this page: http://blog.uobdii.com/toyota-tis-te...chstream-lite/
It plublics where to download lite v11.20.019.
Good luck.
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 01:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 11:03 AM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 03:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 07:47 PM
