Old 07-16-2015, 03:08 PM   #169
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
So I assumed that for the V3 kit, there is no new and old version right?
I think the model number is 4TF218-114L.
The price is different on different website so I am not sure whether it has older&cheaper and newer&more expensive version or not.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 07-16-2015, 03:25 PM   #170
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Not that I am aware of. In the beginning there was a compressor change but I doubt any of those are still for sale new.
bee_are_zee is offline   Reply With Quote
The Following User Says Thank You to bee_are_zee For This Useful Post:
Figo (07-16-2015)
Old 07-16-2015, 03:36 PM   #171
Figo
Figo's Avatar
Thank you.
So I think most people here just get the V3 version right?
I am not sure whether I need a V2 upgrade or not. And I dong know whethet the V2 upgrade will be a problem during cold winter..lol
Old 07-21-2015, 02:08 PM   #172
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
I'm having an issue with my setup making full boost. I only have the stock pulley installed but the car only makes 7.5psi at redline.
I have tbolt clamps on all the couplers. Ive clamped all the evap lines including the ones under the manifold. I checked all the lines going to my radium cans.
Any other advice before i take it to my work and use our smoke machine?
I'm assuming it's best to take the hot side loose and pressure check it from there?
Sent from HTC M8 while in burnout mode
cruizin01 is offline   Reply With Quote
Old 07-21-2015, 02:10 PM   #173
bee_are_zee
Drives: GBS BRZ
Is it the proper sized belt (slippage). what bypass valve are you using?
Old 07-21-2015, 02:14 PM   #174
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
It's definitely the proper sized belt. I replaced all the pulleys and belts when i installed the kit. Its a stock? Metal bypass valve for now. I did just pickup a turbosmart bov so ill try that later this week. I've used those diverter valves on vw's and never had sticking issues.
Old 07-21-2015, 02:17 PM   #175
bee_are_zee
Drives: GBS BRZ
I was thinking an improper spring in the bpv. But doesn't sound like the case. How are you measuring boost?
Old 07-21-2015, 02:22 PM   #176
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Yeah i don't believe that's the case. I know it made 9psi at least initially when i installed the kit early this spring. I only noticed it wasn't making full boost when at the track this weekend. I'm just measuring it via OFT which uses a 2.5bar sensor.
Old 07-21-2015, 02:26 PM   #177
bee_are_zee
Drives: GBS BRZ
I use the same setup and haven't seen an issue. I know some have had bad readings from mechanical gauges. I would pressure test the setup maybe a pipe/intercooler is cracked.
Old 07-21-2015, 02:32 PM   #178
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Yeah, that's what I'm gonna have to do. Blah. Thx!
Old 07-21-2015, 09:09 PM   #179
cruizin01
cruizin01's Avatar
Drives: 13' BRZ
Made up a boost leak tester tonight with some random crap. Used a coupler, a plumbing cap and a fuel pressure gauge. Pulled a tire valve through the cap to pressurize it.
I don't think i have a leak...
The system leaks down from 12psi to 8psi in 50 seconds. It takes another solid minute to drop to 5. I assume that's normal leak down through the valves.
Any other ideas why the car won't make boost?
Old 07-23-2015, 09:23 AM   #180
Figo
Figo's Avatar
Will it be a problem to run V2 upgrade kit in cold winter here in New Jersey?
I am thinking to get the V2 but do not know whether there is any drawback of this upgrade kit? Is there any?
Old 07-23-2015, 09:26 AM   #181
bee_are_zee
Drives: GBS BRZ
Is it a track car? I'm not quite sure why you are set on v2. The Normal kit can take a pretty heavy beating before overheating the oil.
Figo (07-23-2015)
Old 07-23-2015, 09:30 AM   #182
Figo
Figo's Avatar
Go to track day some time, but not frequently.
So the V2 upgrade is JUST a cooling kit for the supercharger itself?
I am thinking that if there is no drawback of this V2 kit (for example, the proper temp might not be reach during cold winter), why not spend a few hundred bucks on a upgrade for the future.
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 04:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 02:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 11:09 AM
