Old 08-21-2013, 04:49 PM   #169
ftc~brz
Done
Drives: WRB BRZ
Originally Posted by 2pt5RS View Post
Oh well...I'll tear it apart this weekend and fix it.
+side…it should go faster for ya this time around
ftc~brz is offline   Reply With Quote
Old 08-21-2013, 06:17 PM   #170
White64Goat
Give them something for free
and they always want more, more, more.....
Old 08-22-2013, 11:20 AM   #171
2pt5RS
Berz
hopefully!
Also, this should be ready to install at the same time.
2pt5RS is offline   Reply With Quote
Old 08-22-2013, 11:33 AM   #172
Dipstik-sportech
Dipstik-sportech's Avatar
Has anyone experienced any sloppiness in the shifter? I have probably 10,000km on mine now and it doesn't seem to be as precise as it use to be.
Old 08-22-2013, 01:39 PM   #173
OrbitalEllipses
Drives: Attitude
What, the rear shifter bushing? You know, I THINK I installed mine the right way, but the KB one has less of an angle than the Perrin one so I'm not really sure.
Old 08-22-2013, 03:21 PM   #174
2pt5RS
Berz
I haven't even installed that yet. might get around to doing it...we'll see
Old 08-22-2013, 03:25 PM   #175
OrbitalEllipses
Drives: Attitude
So you installed the shifter rod backwards?
Old 08-23-2013, 01:47 PM   #176
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Best write up evar!!!!
Thongpocket is offline   Reply With Quote
Old 08-24-2013, 01:35 PM   #177
2pt5RS
Berz
After tearing it completely apart...it appears that I did NOT install it backwards..but still not sure why it was different from the pics in this thread.
Old 08-24-2013, 07:45 PM   #178
OrbitalEllipses
Drives: Attitude
Think less, shift more!
Old 08-25-2013, 01:31 PM   #179
2pt5RS
Berz
I will! Thanks to JPM!
Old 08-25-2013, 02:28 PM   #180
SilverCard
SilverCard's Avatar
Drives: 2002 EP3
Very informative post!
Silver
SilverCard is offline   Reply With Quote
Old 09-02-2013, 12:24 PM   #181
Ooops
Wannabe Enthusiast
Drives: 2013 BRZ Limited White Pearl
1st and Foremost, AMAZING DIY and it is the sole reason I purchased it!!!
Preface: I am no mechanic or even a grease monkey, no offense intended. In fact, I am a wannabe grease monkey. I envy your skills!!
1st Point: Please include some of the pics posted of the shift lever boot and removal process in the original post, as I also tore mine and did not read the 9 pages of this Thread before proceeding and did not understand the shape of the boot nor the proper way to remove. (I removed from the trans side to the shifter and then even pulled it through the shifter mount hole)
2nd Point: Kartboy, are you selling the shift lever boots? I could not find on your site.
3rd Point: Did I mention the Amazing DIY and Product!
Tip#1: GET IT!
Tip #2: Use interior panel removal tools for both removal and re-install of the boot.
(much less harsh than a screw driver or other pointy/sharp objects or even needle nose pliers) Very inexpensive, search www.amazon.com
Best Regards,
-Ooops (PDX)
(No special skills but, a ton of god given common sense, which seems to be in such decline now days?)
Ooops is offline   Reply With Quote
Old 09-20-2013, 10:44 PM   #182
enthennd
wat
enthennd's Avatar
Drives: a potato.
great DIY, I just finished installing mine. The shift and feel is the best thing I've ever had.
I think part of that reason being as soon as I removed that lower shift boot, there was no pin holding the shaft firmly to the shifter. I guess it was causing some sloppiness/notchiness, because now with a pin i picked up at pep boys, the shifter feels 10x better than ever.
enthennd is offline   Reply With Quote
STI Short Shifter Kit Hanakuso Engine, Exhaust, Transmission 37 01-18-2016 08:19 PM
Kartboy Short Throw Shifter!! RallySport Direct Transmission and Driveline 16 04-18-2013 01:18 PM
Kartboy Short Throw Shifter!! RallySport Direct Announcements, Contests, Giveaways 34 03-18-2013 02:18 PM
