Old 08-21-2014, 07:09 AM   #169
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Annnd again an update on my P0351, tracked it yesterday and guess what...
Not DTC AT ALL !
So look like swapped the coil and heat protected them "solved" my problem.
It's great to make a track session without this damn light on.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 08-26-2014, 08:21 PM   #170
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
New one! P0353, days before Nationals!
I had a friend in parts pull strings to get one in house, getting it changed Saturday morning.
Crap.
Same behavior as previous, got it during ~80% throttle, 2-3 shift around 5500rpm
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 08-31-2014, 09:53 AM   #171
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by ATL BRZ View Post
New revised part # OEM coil arrived.
I thought about getting some gold heat tape and putting some on the top part of the coil that is exposed but I don't have any and it would take a few days to order and ship, and I wanted to fix the P0351 as soon as possible.
Only one 10mm bolt holding it in. I just replaced it myself rather easily in about 20 minutes. Removed the three 10mm bolts holding in the ECU on the black fuel rail cover carefully after stuffing some shop towels below to catch any dropped bolts. Zip tied the box out of the way on the strut brace so it doesn't slide into anything. Then I grabbed the coil and pulled it straight out and then up to get the whole thing out. Pressed the connector down and pulled it off and the new one went back in just as easily. Just need patience and dexterity and it's pretty painless. The drivers side coils wouldn't be as easy, though, since there's more stuff in the way.
I put everything back the way it was and secured all the bolts before starting it again. Then I went for a drive and got everything nice and hot before doing a couple WOT pulls to redline and all is well. No more CEL.
I noticed the part # ends in 651. Most of the discount parts suppliers list the coil with part # ending in 650. Has there been a factory change ?
I still haven't addressed this yet as I have no track time in the short term and there are no issues with street driving
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 08-31-2014, 10:39 AM   #172
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Yes AFAIK the part number has been updated but I don't know if the part has actually been revised or not. I would assume so.
Old 08-31-2014, 03:06 PM   #173
Kido1986
Dodging cones
Kido1986's Avatar
My number 3 was replaced and the car made a noticeable improvement.
Just in time to load it up and haul to Lincoln, where I am now
Old 09-01-2014, 11:35 PM   #174
romin
romin's Avatar
Drives: BRZ, STI, 535, Tiffin Allegro
The saga continues....
3/13 - I replaced all of my coils with Okadas after my cylinder one factory coil failed with P0351 code.
2/14 I replace my cylinder one Okada coil after getting the P0351 code again.
This weekend, after running on a hot track, the P0315 code popped up again.
9/14 I replaced my cylinder one Okada coil again.
I'm averaging 7 months per coil now on cylinder one.
romin is offline   Reply With Quote
Old 09-11-2014, 11:02 PM   #175
TimDing
TimDing's Avatar
Drives: Storm Black Manual 86GTS
Put a call in with my local stealership to see if I can get one of each and compare. Will update if I have any luck.
TimDing is offline   Reply With Quote
Old 09-12-2014, 01:01 AM   #176
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
This sounds like it could be the plug itself? Have you tried replacing the plug or harness, or at least confirmed the coil was bad by swapping with cylinder 3, or even a buddies car?
Gords_zenith is offline   Reply With Quote
Old 09-12-2014, 02:44 AM   #177
sickmint79
Drives: bmw
has the gold tape helped?
sickmint79 is offline   Reply With Quote
Old 09-12-2014, 06:25 AM   #178
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Data point
Coil pack #1 lasted for 2.5 track events. Coil pack #2 lasted 1.5 track events.
celica73 is offline   Reply With Quote
Old 09-13-2014, 12:15 AM   #179
romin
romin's Avatar
I swapped the cylinder one plug once already, when my DI seal failed, and the coils continued to fail.
I haven't tried swapping coils across cylinders yet but have kept all of the "bad" ones.
Old 10-02-2014, 06:44 AM   #180
xclusive_brett
xclusive_brett's Avatar
Drives: 08 scion xb
Had P0353 last week and P0351 today... Looks like I will be replacing coils.
40k miles, OFT e85 tune, intake, catless front pipe, exhaust, pulleys
xclusive_brett is offline   Reply With Quote
Old 10-12-2014, 07:10 PM   #181
BRZ-One
Drives: 2013 Subaru BRZ
DTC - PO351
I am also experiencing P0351 CEL.
N/A, EcuTek Tune, catless header & midpipe
Tracked the car in June @ Sebring for the 1st time.
On the 4th of 5 sessions the code came up. Cleared it with Ecutek @ the track and ran the 5th session without recreating the code.
Tracked the car again 10/11, after the warm up session it came up once again.
I went ahead and cleared it and it came up every session throughout the day.
The car appeared to be running fine, AFR was in range...
Car has 40k miles & only 2 track events...
From what I'm reading, I think I'm going to try new plugs & a new OE coil...
Probably take a spare with me to the track...
I like the idea of the Aluminum ECU bracket, will probably try that out as well...
I will post my results...
Seeing how the exhaust is only a few inches below these 1 & 3 coils, I'm going to try a pipe shield, found this:
http://www.designengineering.com/cat...um-pipe-shield
I am however concerned about the injector issues, but I haven't encountered any fuel or injector DTC's...
Thanks
BRZ-One is offline   Reply With Quote
Old 10-12-2014, 09:55 PM   #182
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
FYI there is a 652 part number now. I've been using a pair in my car for several thousand miles and a pair of track events. Wrapped mine in gold tape.
http://www.ft86club.com/forums/showp...0&postcount=78
F1point4 is offline   Reply With Quote
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
Shutting off your "key-in-with-door-open" beeper -- it's very easy avusblue Cosmetic Modification (Interior/Exterior/Lighting) 2 08-13-2012 05:29 PM
