Old 09-30-2013, 01:50 PM   #169
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
Originally Posted by DrDuquette View Post
Are you going to offer a different muffler delete for the people that want a cat back or cat delete version? Reason I'm asking, is because then you could get rid of that silly bend to the left of the car and have a more direct and equal length pipe to each side if the car.
Also, is it true that for aero reasons, we might want to fill the space where the muffler used to be? I could see some nice piece of CF of Alluminum underbody panel.
Not sure if berk has any plans for creating a dual exhaust out of the muffler delete.
From what I have heard there MAY be a piece that will allow the muffler delete to convert into a full catback! But you didnt hear that from me!
To be honest, the muffler may act as a slight "aero" component, but it doesnt cover ALL the space in the area, so it isnt really a "diffuser" as people are confusing. On top of that, you dont get full benefits of a diffuser if you dont have a full flat underbody that directs most of the underbody air to the diffuser. So to answer your question, I don't think it matters that much, because it doesn't fully cover the rear end.
Thanks,
Michael
Corner3garage is offline   Reply With Quote
The Following User Says Thank You to Corner3garage For This Useful Post:
DrDuquette (10-01-2013)
Old 10-09-2013, 09:27 PM   #170
Corner3garage
Drives: FR-S & BRZ
Looks like we have to out the next batch too. LOL!
Old 10-11-2013, 07:17 AM   #171
Admired
Drives: 2013 Scion FRS
With that 14" magnaflow resonator you guys say it will reduce drone but what about rasp? I am getting some bad rasp when accelerating usually around 4th gear or when the car lugs.
Admired is offline   Reply With Quote
Old 10-11-2013, 10:15 AM   #172
blkwrxwag
Drives: DS FRS
This is my Mach V with a resonator - no drone or rasp...
[ame="http://www.youtube.com/watch?v=uCzj3lXnzvE"]Mach V Dual Outlet Muffler delete with custom resonator - YouTube[/ame]
-Max H.
blkwrxwag is offline   Reply With Quote
Old 10-11-2013, 05:27 PM   #173
Admired
What size is the custom resonator? You think the 14" magnaflow will reduce most of the rasp or go bigger? Im fully catless with headers and muffler delete with excessive rasp but love the sound otherwise I just want to eliminate as much rasp as possible,
Old 10-11-2013, 05:33 PM   #174
blkwrxwag
Drives: DS FRS
Mine is 18" - I can't speak for anything else as it's the only one I tried.
-Max H.
Old 10-11-2013, 05:34 PM   #175
Admired
Thanks. How much did it tone the sound volume down? Or did it just get rid of rasp/drone?
Old 10-11-2013, 05:35 PM   #176
blkwrxwag
Drives: DS FRS
It just got rid of all the drone. Mine never rasped since the rest of the exhaust was stock.
-Max H.
Old 10-11-2013, 05:38 PM   #177
Admired
Do you think a muffler would better reduce rasp than a resonator?
Old 10-11-2013, 05:42 PM   #178
blkwrxwag
Drives: DS FRS
The resonator only helps with drone caused by the crossover tube. I think the rasp comes from being catless, and you'll need a muffler somewhere before the muffler delete to help with that.
-Max H.
Old 10-11-2013, 05:56 PM   #179
Admired
I saw someone on the previous pages put a 14" muffler between the tips. Does this muffle both sides or just the passenger side. I am thinking about this but maybe I need a bigger one because im fully catless with headers. Also could a muffler be fabricated on the stock midpipe? If so is it a 2.5"? I'm hoping most rasp will be gone without sound loss.
Old 10-11-2013, 05:57 PM   #180
blkwrxwag
Drives: DS FRS
It only muffles the passenger side tip, which is why I don't think it will help with the rasp.
-Max H.
Old 10-11-2013, 06:05 PM   #181
Admired
Hmmm, so you think a 18" length muffler with 2.5" inlet and outlet on the midpipe will work?
Old 10-11-2013, 06:06 PM   #182
blkwrxwag
Drives: DS FRS
I think it would certainly help a lot. In addition to that, you still need a resonator on the crossover to get rid of drone.
-Max H.
Berk Technology Muffler Delete jeebus Engine, Exhaust, Transmission 31 12-22-2014 03:34 PM
Dual exit muffler delete Hardrock4445 Engine, Exhaust, Transmission 22 02-13-2013 08:41 PM
Berk Technology Dual Exit Muffler Delete jeebus Engine, Exhaust, Transmission 7 10-16-2012 09:38 PM
Mach V BRZ / FR-S Muffler Delete Pipe REVIEW Turn in Concepts Engine, Exhaust, Transmission 1 10-16-2012 11:15 AM
