Old 04-01-2019, 08:01 AM   #169
Gunman
Drives: 2019 Mazda Miata RF
Originally Posted by c.klingner View Post
How do I get on the list? I added my info like it said, just making sure I am getting the info in the right spot.
Spreadsheet is editable by anyone, you can add it yourself.
https://docs.google.com/spreadsheets...zow/edit#gid=0
Gunman is offline   Reply With Quote
Old 04-01-2019, 09:23 AM   #170
ka-t_240
I am kind of surprised its in a mass edit format. TOo many chances of someone screwing it up!
ka-t_240 is offline   Reply With Quote
Old 04-01-2019, 06:21 PM   #171
Gunman
OK @CT86, after some discussion, I added myself to the list, lets here from Subaru.
Old 04-02-2019, 11:28 AM   #172
Ichima
Drives: 13' Lightning Red Brz
Vehicle Mileage: 78,000 (mileage approximate but I will update when I can)
Vehicle Make:2013 Subaru BRZ
Vehicle VIN: JF1ZCAC19D1602863
Mileage After Recall Performed: 77,000 (mileage approximate will update when able)
Symptom(s): tapping noise coming from engine when under load (sounds like Valves tapping to me, but dealership keeps saying otherwise)
Failure: they still don’t know
State: VA
Is Dealership Offering Repair: the dealership swears they have checked their work and it was nothing they did wrong. They did have to order shims and some of the valves were loose but they fixed the valve lash and it’s still making same noise. They have returned my exhaust and intake back to stock (exhaust aft of all sensors, and air raid intake with oilless filter.). Dealership is still trouble shooting but have told me since they are sure it has nothing to do with their work I am responsible for paying from this point forward unless they do find it is something related to the valve job, and are charging me $571 to install the stock exhaust and intake on top of it. Also it is worth noting I just spent 5,500 in July at around 69,000 miles for a new shortblock replaced by Subaru (it had an oil starvation issue but I was outside the warranty so he’d to pay myself) and the car was running perfectly fine before I dropped it off for the recall.
I had a very similar incident and was told it was due to the Camshaft and rockers. Dealer offered to fix under TSB 02/151-14R and when they started working on the car, they dropped the oil pan and noticed a massive amount of RTV sealant inside the oil pan. They are now getting in contact with the rep of the first dealership that worked on my vehicle because there was too much RTV used and now clogging oil passages causing oil starvation.
Ichima is offline   Reply With Quote
Old 04-02-2019, 12:02 PM   #173
Ichima
Also, I have updated my entry in the excel sheet to show my vin number for documentation. I have not had my car pretty much since the first couple days in February.
Old 04-02-2019, 12:49 PM   #174
Gunman
Vehicle Mileage: 80,150
Vehicle Make: Subaru
Mileage After Recall Performed: 10
Symptom(s): CEL (p0011 code)
Failure:
State: NC
Old 04-02-2019, 01:13 PM   #175
c.klingner
They are checking injectors as of today. I had mentioned the camshaft and rocker arms to them as that is a possible side effect of loose valves, but again dealership is insisting it has nothing to do with their work and instead keeps checking other things that don’t make any sense, like exhaust, or injectors, or smog box (which is what they called the sound tube chamber that goes to the intake, which I removed because I don’t care if I can hear my intake noise in the cabin) also, they have been troubleshooting my car since 18 February and still don’t know what the actual problem is. Also updated to include VIN on spreadsheet and actual mileage.
c.klingner is offline   Reply With Quote
Old 04-02-2019, 02:06 PM   #176
Ichima
Yeah my car is still being diagnosed since I believe February 9th
Old 04-02-2019, 03:17 PM   #177
Gt86480
Drives: GT86
Vehicle Mileage: 70,000
Vehicle Make: Scion FRS
Mileage After Recall Performed: 6miles
Symptom(s): Engine seized
Failure: Oil pump failure 6 miles after recall work performed
State:AZ
Is Dealership Offering Repair: Dealer replaced shortblock.
Gt86480 is offline   Reply With Quote
Old 04-02-2019, 04:16 PM   #178
Edward_
Drives: 13 ZN6/96 EK4
Adding to this shitshow.
Vehicle Mileage: 50200
Vehicle Make: FR-S
Mileage After Recall Performed: 1000ish
Symptom(s): Small tick on idle at first, became rough idle, then full blown knock
Failure: suspected spun bearing
State: Recall performed at Victory Toyota, Monterey CA. Car is currently sitting at Vancouver Toyota, Vancouver WA.
Is Dealership Offering Repair: under investigation
Edward_ is offline   Reply With Quote
Old 04-02-2019, 07:35 PM   #179
Axelrf
Drives: Red Scion FRS
Rocker shot throuhg valve cover.
I would expect that at some point TOYOTA will stop ignoring the similarities on these incidents. Also that they will accept that the maintenance they are doing to these vehicles, under this URGENT SAFETY RECALL, is in fact putting people in the very same dangerous situation they say it will prevent.
Vehicle Mileage: 42581
Vehicle Make:Scion
Mileage After Recall Performed: 37
Symptom(s): Right side rocker through valve cover.
Failure: sudden loss of power in the middle of the road.
State: Maryland
Is Dealership Offering Repair: Dealer completed repair saying yhat it was "a one time good will" they said, they did not accept responsibility for the failure neithe for any future similar failures.
I guess I'm expected to just drive away with ZERO confidence that the car won't fail again.
Axelrf is offline   Reply With Quote
Old 04-02-2019, 07:38 PM   #180
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
Vehicle Make:Scion
State: Maryland
What dealer in MD? That way I can avoid them.
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 04-03-2019, 07:01 AM   #181
Gunman
What happened to @CT86 's vin column in the spreadsheet? It was hidden, and when I un-hid it so people would know it was there, everything was empty?
Old 04-03-2019, 07:35 AM   #182
maslin
Benz Tech
Drives: 2017 BRZ Premium
maslin is offline   Reply With Quote
fa20, failure, recall, spun bearing, subaru, toyota, valve spring
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 06:21 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-18-2019 11:24 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
PA Monogram Registry! kazetaro NY / NJ / CT / PA 0 06-06-2014 06:49 PM
Another Detonation thread. (DI failure related) Input Please. Thorpedo Issues | Warranty | Recalls / TSB 15 08-02-2013 07:23 PM
