Old 07-24-2019, 05:21 PM   #169
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by churchx View Post
steverife: if mis-gearing is very common, and one happens to be lingering at redline too often/too long on most tracks one drives at .. imho different FD/gearing should be considered, no?
gearing change is only for those that run for fun or are otherwise not competing in classification based on vehicle spec, i.e. STX, etc.
if you change your gearing for autocross purposes, they'd classify you with one of the unlimited cars and then you're stuck running against cars with full slicks and aero. then the bigger question is, why autocross?
part of the "redline too long" on autocross courses is the course itself, it's temporary and often changes based on the venue. depending on who is designing it and the length between corners, for some cars it's an unfortunate reality that you'll be stuck at redline on some gears. it's sort of a tactical decision but each driver will approach the course differently... but this is uniquely an autocross problem. the same setup on a car can yield vastly different driving on the same venue if the course changes.
for open track days, gearing change is fine.
Old 07-24-2019, 05:33 PM   #170
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by Tokay444 View Post
If you don’t think oil feeding/pressure and engine longevity at revs aren’t related, I’m not sure how to help you.
I just got back from an invite only Toyota Canada Track day, using my car the way they intended, and test driving the new Supra.
We are getting off topic but what do you think the solution is? I've seen engines that the casual enthusiast considers bulletproof F20c, K20A have oil issues issues as well in the upper revs.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Tokay444 (07-24-2019)
Old 07-24-2019, 05:40 PM   #171
churchx
churchx's Avatar
Drives: 2014 GT86
mav1178: i wonder if higher redline can be made a bit less dangerous if ecu tune gets modified to not get max power if past stock redline, but to gradually reduce it .. yes, at high rpms oiling gets inadequate, but if you require from 8K rpms only eg. 30% of max power, that should reduce a bit wear/risks, and still be more effective then bouncing off limiter at 7.4K?
Old 07-24-2019, 06:54 PM   #172
Lantanafrs2
Drives: 2013 frs red
Toyota figured out how to rev it higher 5 years ago. Maybe only for a few laps though lol
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 05:02 PM
Delicious Tuning RallySTI User/Vendor/Sponsor Reviews, Feedback, Comments 2 12-02-2017 05:19 PM
Delicious Tuning needs your help! DeliciousTuning Off-Topic Lounge [WARNING: NO POLITICS] 0 08-14-2017 09:33 PM
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) DesertFrs Northern California 14 04-24-2014 04:15 AM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
