Old 06-10-2019, 09:09 PM   #169
Originally Posted by MotoX16 View Post
Bump, any updates?
Still going, fresh motor on the test car!
FunnyGopher (06-25-2019), MotoX16 (06-11-2019), Tristor (06-29-2019)
Old 07-01-2019, 07:18 PM   #170
Quite update.
Fresh motor on car is good. Been getting some street tuning done, but is slow because Ecutek flashes rather slowly, and this is being done organically.
More dyno time coming soon.
The Following 7 Users Say Thank You to CSG Mike For This Useful Post:
chaoskaze (07-01-2019), FunnyGopher (07-02-2019), Iceman (07-11-2019), JBezugs (07-01-2019), TheStig85 (07-01-2019), Tristor (07-02-2019), weederr33 (07-01-2019)
Old 07-01-2019, 07:18 PM   #171
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Quite update.
Yesssss
Old 07-01-2019, 07:59 PM   #172
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '24 CX-50 Meridian
Quite update.
Glad to hear everything is going well. Patiently looking forward to updates!
JBezugs is offline   Reply With Quote
Old 07-01-2019, 08:38 PM   #173
tomm.brz
Drives: brz 2017 hksv2
Quite update.
where is it located the map sensor with this itb? or is it maf based? or alpha N?
Old 07-18-2019, 02:09 PM   #174
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
So... Down time at work has me researching car parts (again) and I just discovered that CSG has a power package option. Dangerous stuff, especially since the ITBs cost as much by themselves as a full exhaust would. That being said... It is tempting. I can't help but wonder how much power you would get out of a full exhaust with ITBs and tuned for E85.
Nevermore is offline   Reply With Quote
Old 07-18-2019, 02:12 PM   #175
That's being actively worked on.
It won't be anywhere near as much as FI, but none of the complexity, and you'll never heat soak.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
chaoskaze (08-18-2019), Nevermore (07-18-2019), Tristor (07-20-2019), why? (07-20-2019)
Old 07-18-2019, 02:17 PM   #176
Jordanwolf
Rice King
Jordanwolf's Avatar
I see we have something in common.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
The Following User Says Thank You to Jordanwolf For This Useful Post:
Old 07-18-2019, 02:23 PM   #177
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Well, I'm one of the very few that's satisfied with stock power, but if I said I wasn't curious about more power I'd be lying. I don't need huge power, but to justify almost $8k in parts I would like to see those numbers, and some big ones.
It sucks haha
Old 07-18-2019, 02:44 PM   #178
ITB's are not about hp/dollar gains, but the change in response and attitude of the engine. If hp/dollar is your objective, a bolt-on supercharger (Jackson, Edelbrock) with E85 will cost less, and double your engine output.
Old 07-18-2019, 03:01 PM   #179
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Oh, no doubt, but I want to stay NA if possible, and like I said, big numbers really aren't my goal. I guess I'm just trying to justify the extra cost since the ITBs cost more than the entire exhaust setup combined. I'm a cheap person by nature so my mind won't allow the splurge without justification. Response time improvement is a tempting factor since I do think the revs need to climb faster.
Old 07-18-2019, 03:06 PM   #180
If you want the revs to climb faster, a light clutch setup will be the way to go. Specifically, an OS Giken.
ITBs dramatically change throttle response.
Try giving your throttle pedal a large momentary blip, and observe the delay between stepping on the throttle, and the revs climbing.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Hawk77FT (07-18-2019), Nevermore (07-19-2019), soundman98 (07-18-2019)
Old 07-19-2019, 11:34 AM   #181
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
It's an auto, so no clutch haha
But I know the lag you're talking about. Getting rid of that is tempting, but I'm not sure if it's worth $3500. I'll keep it tentative for now and definitely will keep following this for more info. The more info I can get the better.
Old 07-20-2019, 07:50 AM   #182
Quasimofo
Quasimofo's Avatar
Drives: 2019 Series Gray BRZ
And this right here is why I hate forced induction. I have never once driven a FI car that has that immediate throttle response that I crave in a fun vehicle.
If it doesn't have good throttle response, might as well slap an automatic on it and let the damn transmission sort it out.
Fingers crossed that this doesn't require a full ecu swap; I don't like having to dodge vehicle inspections 'cause the diagnostic port is a road to nowhere.
Quasimofo is offline   Reply With Quote
The Following User Says Thank You to Quasimofo For This Useful Post:
why? (07-20-2019)
In for the long haul Ultimate NA build thread. celek Engine, Exhaust, Transmission 683 06-07-2020 07:26 PM
TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL Andrew666 AUSTRALIA 8 11-19-2018 05:24 AM
RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** RallySport Direct Transmission and Driveline 92 09-01-2015 01:17 PM
RallySport Direct's Ultimate Interior Thread! RallySport Direct Interior Parts (Incl. Lighting) 45 03-25-2015 02:12 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 06:25 PM
