Forced Induction Turbo, Supercharger, Methanol, Nitrous |
11-12-2012, 03:49 PM | #169 | |
Drives: 2013 Black FR-S
Then end result is full boost by ~ 4k rpms rather than full boost by 7.5k. No extra fueling parts required. Just a wastegate with a 5, 6 or 7 psi spring. |
The Following User Says Thank You to sw20kosh For This Useful Post: | JoeBoxer (11-12-2012) |
11-12-2012, 04:54 PM | #170 |
Drives: 2006 Subaru Liberty EZ30 S/charged
Wastegate plan seems fine until you realise all the air (mass) you are dumping to atmosphere in order to regulate final manifold pressure has had to be pumped through the supercharger using a LOT of additional effort. Peak power in a regulated system is actually less than with a stock pulley. The chart above shows pressure, be a different story if it showed horsepower, the 18psi with WG shut would like awesome, the stock pulley would make a nice power number and the WG functional would have worst peak power figure of all of them due to the extra work being put into the SC for no gain
Toyota 86 test driver
11-12-2012, 05:59 PM | #171 | |
Drives: MR2
Yes , thats it exactly ! My point being that the kit really should be done this way if it is/was research properly. Done this way you will see an enormous improvement . You are just utilising the SC properly and not wasting it and with experience your first gear will get you so far in front that the turbo guys wont know what is happening while their turbos take time to spool up |
11-12-2012, 06:20 PM | #172 | |
Drives: MR2
Sorry buddy but you are talking nonsense. A SC is an air pump. If it pumps 8 psi at Red Line you will only have 3-4 at 4,000 rpm. If the SC can pump 15 psi at red line at 4,000 it will be pumping 8 psi. As you approach the 8 psi the WG opens and starts to relieve the pressure. Thats what a WG does Here is a WG control used for the ultimate traction, boost by gear Uploaded with ImageShack.us Additional effort ? The bigger the SC the lower the gear ratio , more volume of air pumped less work Have a look at SC specs > shaft spins less > lower temperatures/wear. Stock pulley ? what stock pulley the one that the kit supplier wants you to use so as to lower the overall pressure or the stock pulley that is calculated by the manufacturer that will optimizes the pressure at your set red line. Kits should always be done with collaboration with the FI manufacturer, ALWAYS. If you were building a kit yourself YOU would. |
11-12-2012, 06:58 PM | #173 | |
That Guy
Drives: 2013 asphalt FRS MT
11-12-2012, 07:23 PM | #174 |
Drives: MR2
Except for one thing the bigger SC will be more efficient and spin les
11-12-2012, 07:29 PM | #175 | |
If you want a bit more peak power, just attach a boost controller to the WG and up the boost a pound or two. :happy0180: |
10-19-2013, 04:15 PM | #176 | |
Drives: 2019 MX-5 RF GT-S, 2002 Miata LS
10-19-2013, 06:48 PM | #177 | |
That Guy
All jokes aside, a big thumbs up for using the search function. Clearly you're researching something. Did you find what you were looking for? |
Similar Threads | ||||
Supercharger or Turbo ? | #87 | Forced Induction | 192 | 01-25-2013 10:20 AM |
HKS Supercharger getting closer | gtauto | AUSTRALIA | 166 | 09-03-2012 07:11 PM |
TRD Supercharger anyone?? | poormans_LFA | Engine, Exhaust, Transmission | 48 | 04-27-2012 11:42 PM |
Supercharger for Infiniti G25 | Lottta | Other Vehicles & General Automotive Discussions | 2 | 02-12-2012 09:10 PM |
