#169 | |
Kuruma Otaku
Because titanium. |
#170 |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
Awesome, would love to hear it... Being an Engineering student I'm always looking to expand my knowledge
#171 | |
Drives: Ms. Daisy
Edit... doh it logged me out so I replied to an old post... lol
BRZ before hoes
#172 | |
Kuruma Otaku
But since you're an engineering student, I'll give a few ideas for you to look into. 1.) Airflow:Valve lift. Given that a valve lifted over a certain limit (.25D or something, I can't remember the exact ratio at the moment) will no longer be a restriction to airflow, why do some performance cams exceed that limit? 2.) Valve angle, overlap and interference. This is something to do with the 45 degrees valve angle of the Toyota 'G' heads. This isn't great. Can you think of why? 3.) In both the hi-po multi-valve motorcycle AND 2 valve domestic performance headwork, there is now a trend to sacrifice some airflow in exchange for more velocity in extreme performance heads. Why? If I'm not too hung-over tomorrow, I'll expand.
Because titanium. |
#173 |
Drives: '06 AM V8V Coupe
Point 1 is just false, there is always restriction, depending on design whoever is making these high performance cams thinks they can flow even better. That's all I can see at the moment, there may be another reason.
#174 |
Supra Owner
1) ^ I agree, I don't think there is ever NO restriction on air passing around the valve, BUT there is a point where the available flow around the valve is more than the available flow through the intake/exhaust port... At which point I would guess there is almost no benefit to going with more lift, and there may even be a detriment - as it means the air would slow down as it reaches the valve...
As for the reason that performance cams exceed that limit, I'm not sure.. maybe more lift allows a slightly smoother airflow and therefore more mixture into the cylinder. The only other reason I can think of is that because the cam lobes must be smoothly curved to lift and lower the valve smoothly, the cams are 'overshot' to allow longer for the valve to be at the point where it is no longer a restriction. (i.e. the point where there is no restriction is not at the vertex of the lobe, but some points before and after that, and anything between those points will flow with no restriction). 2) I have very limited knowledge in this... I have thought about what valve angle would produce the smoothest flow entering/exiting the cylinder, but haven't come up with any definitive answer. I know there is an angle that is the most efficient for each specific cylinder, but if I was to try and apply that as a generalisation, I'm sure I would be wrong. I would love to hear more about it though! ![]() 3) Also guessing a lot here... Maybe the higher velocity causes a higher pressure in the intake port/runner when the intake valve closes, and this higher pressure area could either help to force air back into the cylinder when the valve opens again, or could help to slightly pressurise the plenum in order to force more air into other cylinder's when the valves for other cylinder's open? However, I'm not too sure about the travel of pressure in the plenum (speed of sound in air) compared with the speed of the valves opening and closing, and whether or not the valve for the cylinder would open before the pressure wave has a chance to travel back out into the plenum, down another runner, and into another intake port...
#175 | |||
Kuruma Otaku
1) Bingo. Maximum valve lift (and any flow associated with it) is instantaneous, only at the apex. So extra lift beyond the flow limit, allows the valve to be at maximum flow for longer. Quote:
Hope that gives you some things to think about...
Because titanium. |
#176 | ||||
Supra Owner
![]() Quote:
Obviously different combustion chamber shapes prefer different angles for the valves to produce the best airflow for the cylinder, but is there any generalisation that can be applied to that? I would assume that having the valves at very small or very large angles to the perpendicular of the piston travel would be detrimental to performance, but to hear that sports bike's use ~20 degrees kinda throws that out a little...Quote:
#177 | |
Kuruma Otaku
Because titanium. |
#178 |
Supra Owner
The only variable lift system I know how it works is Toyota's valvematic... And that seems reasonably simple...
Having a look at Fiat's MultiAir now...it's pretty cool, I have wondered why manufacturers haven't used more electronically-controlled valve systems, but it seems like they're finally getting into it now... Still, that's a pretty complicated system, and it will also take me some time to fully get my head around it!
#179 | |
GL 86!
Drives: Maybe FR-S... maybe not
It's kind of like the Fiat MultiAir system except they don't feature a camshaft with profiles for valve actuation, instead the computer controls a valve for pressurized lubricating oil for valve actuation based on crank angle and other sensors with pneumatic valve return. The sensors tell the computer the appropriate time for engine fuel injection and valve actuation. However you can play around with valve lift, duration, timing, as well as injector timing and pulse width, off of a base map for; fuel efficiency, power or tweaks for optimization and engine longevity. |
#180 |
Supra Owner
Wow... saves the need for having specific 'performance' or 'efficiency' cams and just gets rid of cams all together XD
#181 |
Except that kind of system sounds like it consumes quite a bit of power compared to cams...
#182 |
GL 86!
It does, but power and torque are not primary issues for this particular engine, emissions and maintenance are.
I don't think you'll would see this system adopted by the automotive industry. It's just an interesting tidbit I thought I'd share. |
| Joke Thread | VenomRush | Off-Topic Lounge [WARNING: NO POLITICS] | 27 | 07-09-2011 01:44 AM |
| The Music Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 03-28-2011 12:35 PM |
| engine swap thread | aspera | Engine Swaps | 231 | 03-15-2011 06:10 PM |
| FT-86 to debut new GPS-track day technology for use on track and GT5! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 01-30-2010 12:30 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 11:59 PM |
