Old 07-13-2013, 07:31 PM   #169
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Could be a connection issue, but as previously mentioned, swap the ballasts and see if it follows. If it does, contact TRS and have then send you a new ballast.
Sent from my Nexus 4
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 07-15-2013, 10:20 PM   #170
RealShkillz
The White Pearl
RealShkillz's Avatar
Drives: '13 Whiteout FR-S M/T
I got a question,
Now I didn't go the root of getting new projectors, instead I'm just using the stock projectors and running the TRS HID H11 kit. I also got one of the relay harnesses that has ground at both ends, neither of which could reach the battery, but I'm wondering where to bolt them to the car to get a good ground effect.
Does anyone have any pictures of where they grounded their kit in the engine bay? I realize I could use any hole in the metal work but then I will have to go find some self tightening bolts to seal that connection, and I'm looking to re use some already stock bolts if possible.
Any help is great!
RealShkillz is offline   Reply With Quote
Old 07-15-2013, 10:45 PM   #171
Yruyur
Yruyur's Avatar
The bolt holding the horn works great.
Sent from a Motorola DynaTAC 8000X
Old 07-15-2013, 11:02 PM   #172
RealShkillz
The White Pearl
Would you happen to have any pictures? and is that for the driver side or passenger side?
Old 07-15-2013, 11:31 PM   #173
Yruyur
Yruyur's Avatar
I may have posted in this thread not sure. Dont have the pics anymore.
Old 07-27-2013, 12:45 AM   #174
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
Has anyone had this problem or know what it could be. @Yruyur came by to check out the lights and help level them. As soon as he pulled up we noticed my weak output. Also the glare above my cutoff is terrible.he has 6000k and i have 4300k but still my halogen bulbs were brighter. Please help
Mine:
His:
FR-Shadow is offline   Reply With Quote
Old 07-27-2013, 01:19 AM   #175
retrosmiths
Drives: Scion FR-S Whiteout
Improperly seated bulbs is my first guess.
Second would be bad bulbs.
Then, ballasts.
-Sent from outer space
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
Old 07-27-2013, 01:20 AM   #176
FR-Shadow
FR-Shadow's Avatar
Then, ballasts.
Yea i think tomorrow ill check to make sure the bulbs havent shifted.
The Following User Says Thank You to FR-Shadow For This Useful Post:
retrosmiths (07-28-2013)
Old 07-27-2013, 09:33 AM   #177
FR-Shadow
FR-Shadow's Avatar
Just re grounded them and checked the bulbs everything is still the same. i really dont want to bake these headlights again.
Old 07-27-2013, 10:07 AM   #178
Yruyur
Yruyur's Avatar
Can he get another brand bulb from a local place and try those?
I would think the power ouput issue would more likely be a single point of failure instead of two things. Meaning it has to be a single wire that attaches both, a single fuse that attaches both instead of both bulbs or both ballast being defective. Hmmm
Old 07-27-2013, 10:28 AM   #179
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I don't think it's bad power only because of the glare. You're 100% positive the bulbs are seated properly?
If they are, shoot TRS an email with a picture and see what they say. Hopefully they can send you new bulbs overnight or something.
@Yruyur - since you're near @FR-Shadow, do you think you can take one of your bulbs out and put it in his headlight? That would help narrow down possible causes.
As far as local replacement bulbs, I've never this seen style of bulb for sale in a brick and mortar store.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
Old 07-27-2013, 10:42 AM   #180
Yruyur
Yruyur's Avatar
I can try one of my bulbs. Just as long as it doesnt kill mine
We do have some ricer places around here that sell bulbs and drop in kits.
Old 07-27-2013, 11:06 AM   #181
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Then they probably would have the correct bulb in stock. I'd still try one of your bulbs before spending on the money on them, just in case (if its possible to).
Parting out HERE
The Following User Says Thank You to civicdrivr For This Useful Post:
Yruyur (07-27-2013)
Old 07-27-2013, 11:49 AM   #182
FR-Shadow
FR-Shadow's Avatar
Ill pop off the back cover and post a pic of the bulb. Bad thing is those clips are not easy when the headlight is off the car. I cant imagine working with that clip with the headlight on lol.
Morimoto Retro-Quik Xenon Retrofit System for FR-S Xenocide117 Cosmetic Modification (Interior/Exterior/Lighting) 63 07-18-2014 07:37 PM
The Retrofit Source Bi-Xenon FR-S Retro-Quik Conversion Andrew @ TRS Exterior Parts - The Rest 84 07-23-2012 09:43 PM
OEM Fog Light install! ON and working! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 38 07-04-2012 07:11 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 06:07 PM
Five axis limited retro Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 28 05-18-2012 03:16 PM
