Old 04-18-2016, 08:38 PM   #169
Bykov
Drives: 2014 Monogram FR-S Whiteout
Originally Posted by byun View Post
I'm pretty much at sea level. Wasn't able to get a baseline. Ended up with 236whp mods are JRSC c38 w/ ace header 250 and greddy supreme sp catback.
I think a stock brz on there dyno is around 135-140whp
Based on your gains you are getting exactly as advertised power. Are you on the stock MAP sensor? If you are that probably explains it. It loses resolution after 5 psi I hear. Maybe you are losing boost pressure due to some valve overlap?
Bykov is offline   Reply With Quote
Old 04-18-2016, 08:43 PM   #170
byun
byun's Avatar
Drives: 2015 BRZ CWP
Jackson Racing C38-81 Supercharger - CARB legal
Nope, we upgraded the map sensor. We checked intercooler piping and all hoses that could cause a leak. Everything checks out. Car runs strong, just not getting up to 9psi.
byun is offline   Reply With Quote
Old 04-18-2016, 10:40 PM   #171
byun
byun's Avatar
Figured of the issue. The bypass valve doesn't hold the boost past 7psi.
Had a turbo smart bpv that I had from another car so threw it in and boost is now 9-9.5psi
Old 04-18-2016, 10:43 PM   #172
Hicklinc
Drives: N/a
Was thinking that was low with that header
Sent from my SM-N910T using Tapatalk
Hicklinc is offline   Reply With Quote
Old 04-19-2016, 01:27 AM   #173
SoCalArgento
Drives: 2014 Argento FRS
Wait so the C38 bypass valve won't hold over 7psi?
Meaning it's restricting potential power at 9psi or did I misunderstand?
SoCalArgento is offline   Reply With Quote
Old 04-19-2016, 01:29 AM   #174
Hicklinc
Drives: N/a
My guess would be a faulty unit but I would also like the answer to this
Old 04-19-2016, 09:46 AM   #175
byun
byun's Avatar
Guessing it's just a faulty BPV. I'm sure others are working fine and holding past 7psi.
Old 04-19-2016, 11:56 AM   #176
johan
Drives: '14 981CS, '99 NB1
It's pretty common for those BPVs to fail. They're some cheap Volkswagen crap that JR/KW use on all their kits. Upgrading to a metal unit from a reputable source is a common practice for Rotrex kits on other platforms.
johan is offline   Reply With Quote
Old 04-19-2016, 12:20 PM   #177
I would imagine I've seen more of these kits than anyone else, and I've yet to see a bypass from the JR kit fail without a good reason (e.g. bad removal on a used kit).
If for some reason yours DID fail (never say never), then @Jackson Racing will gladly replace your unit; their warranty is solid.
Old 04-19-2016, 12:39 PM   #178
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I dont imagine theres any easy way to check for improper boost without a gauge or just noticing the loss of power, right?
PandaSPUR is offline   Reply With Quote
Old 04-19-2016, 12:39 PM   #179
byun
byun's Avatar
My kit was purchased new and has a little over 1k miles on it. Still works just keeps me from hitting full boost.
Old 04-19-2016, 12:43 PM   #180
byun
byun's Avatar
I have a boost gauge and also upgraded map sensor so I can see where i'm maxing out at in the logs.
also knew something was up when we were tuning and i was making about 20whp less than similar setups.
Old 04-19-2016, 03:10 PM   #181
You'd need a MAP sensor that can read boost past 20psi absolute, and a tune scaled to that MAP sensor.
Alternatively, an external boost gauge would also catch it.
Most people probably wouldn't notice the loss of power unless they had a fully functional, but identical car for comparison.
Old 04-19-2016, 04:36 PM   #182
PandaSPUR
PandaSPUR's Avatar
So would this be a good reason to get a boost gauge on a SC car then? I usually only see boost gauges in turbo cars.
FS Bay Area: 2013 Subaru BRZ-L SWP 6MT - Jackson Racing Supercharger - 50 state legal spitz Cars for Sale/Trade 3 02-04-2016 11:59 PM
Jackson Racing CARB supercharger+oil cooler LA blahblah Engine, Exhaust, Bolt-Ons 9 12-30-2015 12:33 AM
(SOLD) 2014 Scion FRS (w/Jackson Racing SC - CARB Legal) - $25,000 - Irvine, CA *LongFella Cars for Sale/Trade 27 04-11-2015 12:35 PM
Best CARB legal SC kit? Jackson? Oem reliable block rebuild? Cayman killer? Yui-Chan Forced Induction 179 03-04-2015 07:50 PM
