11-20-2017, 12:18 AM | #17865 |
The Dictater
Drives: '13 Red Scion FRS
11-20-2017, 12:38 AM | #17866 |
The Following User Says Thank You to humfrz For This Useful Post: | Spuds (11-20-2017) |
11-20-2017, 12:52 AM | #17867 |
Wes
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | guybo (11-20-2017) |
11-20-2017, 01:10 AM | #17868 |
The Following User Says Thank You to humfrz For This Useful Post: | Dadhawk (11-20-2017) |
11-20-2017, 05:10 AM | #17869 | |||
Huge E85 fan!
Drives: 2016 Scion FRS
Because Racecar. Quote:
Grab a gallon of milk. Hold it close to your body and pivot. Hold it out at arm's length and pivot. Which way is easier to pivot? |
11-20-2017, 08:57 AM | #17870 | |
That strap ain't doing shit in a crash. Hell, it isn't even well done for the little bit of security it could provide. It has several twists in it that prevent full force from being applied, the limited points of contact are putting very little actual pressure on the wheel, the long gaps on each side are going to permit lateral shift even under light driving conditions, the single strap will just act as a pivot point to flip the wheel in the event of a crash and the ends appear to be rubbing against the raw steel edges so even if it would hold it they won't last long. Without doing the math I would guess that at speed that spare would have an impact force of someplace around a ton. Are the head rests tested to sustain a tone of impact? For a short term situation it may be within the realm of acceptable risk but driving around like that all the time in order to get a change in weight that would probably not even be measurable is foolish. Like I said it is his neck (or his wife, kids, friends) at risk not mine so if he wants to drive around like that "'cuz racecar" I don't care. Other people however need to understand just how dumb a move it is.
11-20-2017, 10:25 AM | #17871 | |
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
Drove for the first time as a poser!
Today I took my 2013 out for the first time sporting an OEM 2015 shark fin...
I guess that makes me a poser!
The Following User Says Thank You to nextcar For This Useful Post: | Tcoat (11-20-2017) |
11-20-2017, 10:31 AM | #17872 | |
1st86 Driver!
You should put some type of abrasion protection on the metal edges where the straps cross as well. That is definitely going to be a weak spot. As far as the minimalist delete, @guybo did accomplish that, although I'm not sure it gives quite the benefit you think it does. Honestly just removing the spare and leaving everything else in place would most likely mathematically provide you nearly the same result given where they each sit on the arm. The seats are much closer to CG, so the removal of their weight has less impact then removing the spare, which probably has about the same amount of weight but is further out. You've also raised your center of gravity slightly with the removal of the seats since most of their weight is below CG and placing the tire higher up, for what it's worth.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
11-20-2017, 11:45 AM | #17873 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (11-20-2017) |
11-20-2017, 12:19 PM | #17874 | |
However, in my case, I wouldn't worry about the tire moving forward ...... because, in a rear moving crash, the tire would move to the back of the car ...... humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Tcoat (11-20-2017) |
11-20-2017, 12:37 PM | #17875 | |
Drives: frs
11-20-2017, 01:35 PM | #17876 | |
11-20-2017, 03:42 PM | #17877 | |
Huge E85 fan!
So you're saying I should put it back in the back bolted down? |
11-20-2017, 03:45 PM | #17878 |
Yep. Or see my other option.
Could just do away with it since you don't have a jack anyway.
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
