CSG Mike, gramicci101, grant86, GrimmSpeed, JDLAutoDesign, JRitt, KCMachine, King Tut, MillersOilsUS, PERRIN, phastafrican, Racecomp Engineering, Raceseng, Roadcone, Sportsguy83, UltramarineLuck, VerusEric, Wonderbar, Xero-Limit
Old 11-09-2016, 12:48 PM   #1765
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
Originally Posted by ATL BRZ View Post
Installed a Koyo high pressure (1.3 bar) radiator cap. This should help improve the pressure in the cooling system to make it more efficient.
Does this really help anything---or is there sarcasm afoot?
Like coolant bearings and headlight fluid?
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
Old 11-09-2016, 08:54 PM   #1766
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The stock system does exceed the 1.1 bar of pressure that the stock cap is rated for, that is why there is an expansion tank and you can view changes in the volume of coolant in the tank at normal running temps. If the system didn't exceed 1.1 bar there would be zero reason for the expansion tank because its the expansion that is raising the pressure.
The higher the pressure you can run in the cooling system, the less likely your coolant is to boil. A higher pressure cap can be very handy, not only to keep the coolant in the system, but also keeps it off the track and your tires if you get severe boiling for extended periods of time. The 1.3 bar cap will raise the pressure by containing more coolant in the system and releasing less into the expansion tank.
Subaru didn't fit a 1.3 bar cap because a 1.1 bar gives plenty of boil over protection for a street driven car and its a standard part for all their other cars. If you're regularly tracking your car like I am in an area that doesn't see temps much below freezing and want to run a 70/30 water/coolant mix, then a 1.3 bar cap is probably a good idea.
Old 11-09-2016, 08:56 PM   #1767
ATL BRZ
ATL BRZ's Avatar
On another note I decided to replace my K&N intake filter and put a wrap on it this time. After cleaning the original one 3 times and it kept getting softer and caked with dirt, grime, bugs and rocks every track season I thought it would be a good idea to put a wrap on the new one. It's not restrictive at all and it will hopefully increase the time between cleanings.
Old 11-10-2016, 08:55 AM   #1768
Teseo
Drives: frs
Mate, i want to understand your statement. But you considered the plastic can melted due to track temps? On daily drivers sounds ok to me
Old 11-10-2016, 09:50 AM   #1769
ATL BRZ
ATL BRZ's Avatar
What plastic are you talking about melting?
Old 11-10-2016, 10:31 AM   #1770
Teseo
Drives: frs
The wrap on the filter, is not plastic?
Old 11-10-2016, 10:46 AM   #1771
ATL BRZ
ATL BRZ's Avatar
The wrap is specially designed to extend the service interval of the filter when exposed to the elements (somewhat in my case). They are made from durable polyester material containing a uniform weave. It's made to stop small dirt particles with minimal restriction to the airflow of the filter. It will not melt. It will not even get remotely warm. The filter and the wrap are located on top and in front of the radiator (where the stock snorkel was) and it will have constant airflow going around and through it. You don't see the stock plastic airbox melting from track temps under the hood, do you?
The Following User Says Thank You to ATL BRZ For This Useful Post:
Teseo (11-10-2016)
Old 11-15-2016, 09:58 AM   #1772
ATL BRZ
ATL BRZ's Avatar
It's finally here!
Can't wait to start using it on track.
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (11-15-2016), Teseo (11-15-2016)
Old 11-15-2016, 10:50 AM   #1773
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
It's finally here! Can't wait to start using it on track.
Nice! I am currently in the market for a lap timer. I was going to buy an Aim Solo but you have me intrigued. If I were to buy this instead I wouldn't need my Open Flash Tuner in the car and I would gain a lap timer all in the same device.
Why did you buy this over the Aim Solo or any other lap timer?
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 11-15-2016, 06:28 PM   #1774
ATL BRZ
ATL BRZ's Avatar
I like the price (I got it for $199), the simplicity of the unit itself, the interface with my phone to display lap times and/or OBD data, and the ability to overlay any of the data to a GoPro video easily. To top it off, the social features on Podium look excellent!
[ame="https://www.youtube.com/watch?v=6a9wgjPYBag"]Tour of RaceCapture features - YouTube[/ame]
Old 11-15-2016, 10:55 PM   #1775
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I am quite curious how the RaceCapture works out. At its price point, I have my fingers crossed quite hard!
$199? How?
BatStig is offline   Reply With Quote
Old 11-16-2016, 09:53 AM   #1776
ATL BRZ
ATL BRZ's Avatar
$199? How?
I'll be sharing my data here when I get some! The price was via their Kickstarter campaign which began last December!
BatStig (11-16-2016)
Old 11-17-2016, 12:38 PM   #1777
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
I've reached out to you a few times on PM so thank you for your help! Finally got the chance to click through your entire thread. Really inspires me to get my own build thread up and running. I really wanted to go to GridLife Atlanta since I participate with gridlife often as it's the best bang for the buck in my area and running in gingerman raceway in michigan since it's only a few hours from chicago. But wow, made my work day go by fast and one hell of a build. If gridlife has another road atlanta, I'd love to sit in a session with you and get some tips! LOVE THIS CAR! FI anytime soon? I read you were debating with the jackson supercharger.
pgranberg11 is offline   Reply With Quote
Old 11-17-2016, 03:53 PM   #1778
ATL BRZ
ATL BRZ's Avatar
Thank you!
My debate with the JRSC ended when the Edelbrock/Harrop SC outperformed it on the dyno and on the track in pretty much every application. Lots more usable torque from a TVS 1320 supercharger than even a big C38 Rotrex.
MaximeT (11-18-2016), pgranberg11 (11-17-2016)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 04:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 01:46 PM
