go_a_way1, MisterSheep
Old 11-04-2017, 01:07 PM   #17725
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I flushed my brake fluid and converted over to Motul. I didn't think the brakes would bite more with Motul, but what a difference. The brake pedal feels a little different, but not by much.
Old 11-04-2017, 01:35 PM   #17726
Decep
Drives: 2013 FR-S Series 10
more likely due to getting any air bubbles out of your lines than the brand of DOT4.
The Following User Says Thank You to Decep For This Useful Post:
humfrz (11-04-2017)
Old 11-04-2017, 02:55 PM   #17727
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
this is the reason
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 11-04-2017, 03:02 PM   #17728
Lakitu
Lakitu's Avatar
Drives: 2017 Halo 86
What?
Exactly what do you classify as "cruising speeds"?
I can literally drive around in 1st gear round my neighborhood at 20mph and it is just at 3K. Whereas before, that was 2nd gear. 1st gear was super touchy in that 20mph would have it at 4.5K (aka: revving high and loud, but not going anywhere quickly! therefore, needing to shift to 2nd as quickly as possible). I know this entirely because everyday on my work commute I have to drive at 15mph around a school zone, and I am in 2nd gear at under lower 2K~ RPMs.
It's so weird!
Lakitu is offline   Reply With Quote
Old 11-04-2017, 03:09 PM   #17729
Lakitu
Lakitu's Avatar
Maybe you should have gotten the OFT tune ?? .......
humfrz
Mixed up the name of the device (OFT) and the tune folder name (OTS)
Old 11-04-2017, 03:12 PM   #17730
Teseo
Drives: frs
It's so weird!
Let the car settle up, will take a while. Something like 600 miles
Old 11-04-2017, 03:24 PM   #17731
humfrz
Now, THAT is an example of ..........___________________.
humfrz
humfrz is online now   Reply With Quote
Old 11-04-2017, 03:27 PM   #17732
humfrz
Well, OK ....... but, where did OTF enter the picture ....... ?? ......
(jest ah messen wich ya)
It's a slow day ........ no granddaughters here today ........
humfrz
Old 11-04-2017, 03:34 PM   #17733
Lakitu
Lakitu's Avatar
humfrz
Old 11-04-2017, 04:07 PM   #17734
humfrz
You're a good sport, Lakitu.........
I hope your car's engine adjusts to the new tune ......
humfrz
Old 11-04-2017, 07:26 PM   #17735
Decep
It's so weird!
uhhh doesnt sound right. maybe your ecu/tach still need to calibrate etc. i had to flash mine twice because i goosed it too quickly after first tuning it and ecu didnt seem to learn, gas pedal always had a dead zone that wouldn't go away. light driving after reflashing cured it.
Old 11-04-2017, 08:39 PM   #17736
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Got my quickjack working. I got the 5k lb unit.
BirdTRD (11-04-2017)
Old 11-04-2017, 08:53 PM   #17737
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
I'm this close to pulling the trigger on the same set. Did you get the 120vac or 12vdc power option?
BirdTRD is offline   Reply With Quote
Old 11-04-2017, 09:06 PM   #17738
Sapphireho
Famous Potatoes
Sapphireho's Avatar
110 plug in the wall. The assembly and priming/bleeding was a pain, but one time.
