#1751 | |
Lowly Cartuber
Drives: 2016 BRZ, 2005 Honda S2000
Got it. That honestly makes the Edelbrock kit very desirable in my opinion. It gives more reason to boost a brand new car and not have to worry about it because they have you (mostly) covered. I'm going to call Edelbrock today and get some more details but i'm leaning towards this kit more and more. Originally i wanted a turbo because it makes higher power easier (more efficient) But the lack of warranty and the fact that i also live in CA makes the decision hard. Also the fact that edelbrock kit can make almost 300 whp with a CARB legal tune honestly just makes the entire thing easier to deal with in the long run. |
#1752 |
Drives: 14 BSP Edelbrock BRZ
The Carb tune is nowhere near 300 whp...
Sent from my Pixel XL using Tapatalk |
#1753 |
Correct. Edelbrock is offering to warrant your drivetrain that Subaru/Toyota will no longer warranty, provided that you meet their requirements.
#1754 | |
#1755 | |
Lowly Cartuber
I dont really know who to listen to...
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
#1756 | |
Lowly Cartuber
#1757 |
1st86 Driver!
Correct, although the supercharger still has a 3 year warranty regardless.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | funwheeldrive (11-03-2016) |
#1758 | |
Drives: none
Evaluating these systems can be very difficult since there are a lot of numbers flying around and it's not always clear what was done to achieve a particular power level. Without running a smaller pulley or installing a FlexFuel kit you're not likely to see anything much beyond the ~250RWHP range. Flex fuel with a stock pulley can push you past 300RWHP. That is the safer approach if you want to keep your engine stock. Flex fuel will automatically back off the power when you go back to regular 91-93 pump gas... Once you install a smaller pulley you're running higher boost no matter what. It's not like a turbo where you can control the boost level on the fly. Really, you shouldn't pay as much attention to peak power levels as much as area under the torque curve. That's what you really "feel" when you drive the car. Unless you're drag racing or doing top-speed runs you're not likely to be out driving around at redline all the time (which is where all these kits make peak power). -Matt |
The Following 4 Users Say Thank You to armstrom For This Useful Post: |
#1759 | |
Lowly Cartuber
Thank you so much for the response. Was getting frustrated lol. So if anything it seems like the proper tune with flex fuel will make the most power. Does that mean Delicious Tuning generally is more aggressive than Ecutek? I was thinking about running flex fuel anyways. if i were to get the Edelbrock kit i'd be better off buying it without the Ecutek license then i assume? Just go straight to Delicious Tuning? The other option i have is to get a non CARB compliant Turbo kit which can easily make 300 whp on 91...but i'd have to remove it in 5 years because California smog checks. Or risk getting a ticket due to random smog checks (that has been a thing). I could also get the edelbrock kit now and then just build the engine at a later date if i really want more power. I think i'd e ok with 250 whp. Especially if it's all down below the torque curve. Thanks for the response.
#1760 | |
Drives: none
Hopefully that all made sense and didn't add to the confusion ![]() -Matt |
#1761 | |
Lowly Cartuber
#1762 | |||
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
Its good that you are doing your homework and asking questions. I would recommend you take a close look at what you really want out of your car. The common phrase "cheap, reliable, fast... you can only have 2" applies. Do you want 300hp? Probably have to go E85, catless, etc. That means you won't be CARB legal and probably won't be as reliable (although there are a few of them out there that are, but then again, they probably spent more $$$ for it)
Exactly what I'm doing, but make sure you retain your cats ie header and mid pipe. |
The Following User Says Thank You to BigFatFlip For This Useful Post: | CSG Mike (11-04-2016) |
#1763 | |
Lowly Cartuber
Hey man thanks so much for your responses in both this thread and our local one. I've kept all my stock parts for just the reason that if i need them i have them. Also for me i'm picking Reliable + Fast. I dont mind spending the extra money for quality and reliability...but we all like to chase that Unicorn of trifection =D. I'm going to be driving a few boosted 86's in the near future to see what i like. However i'm even willing to sacrafice a little bit of how i want it to drive for more reliability. I'm very much thinking of doing what you are doing by going Delicious Tuning with Flex Fuel until my 6 years comes up then switching my headers back and doing my CARB tune.
#1764 | |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Definitely the best choice Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Silverfox For This Useful Post: | sato (11-04-2016) |
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
