#1737 | |
No more caltex for me. Will try BP and reduce the timing if it still ![]() Thanks Wayno |
#1738 |
Drives: Q5 + BRZ + M796
https://datazap.me/u/jirace/wot-pull?log=0&data=29
Tuning with DT. He said I might be running into fuel supply issues so I’m running lean. I’m guessing it isn’t correctable through tuning so that is why he is saying it is on my end. I just wanted a second opinion. I’m running an 85mm pulley which is like 11.5psi on a Harrop supercharger. Most hit about 275whp which I thought the stock fuel system could handle.
#1739 |
Seems like the fuel rail is getting consistent pressure so the fuel pump n regulator must be good but the direct injectors seem to be taking over and the ports are flatening out, and that is most apparent with the “fuel injection pi ratio”, if i am understanding it correctly. This is the ratio of port to direct injectors, right?
#1740 | |
Drives: UK GT86
PI ratio is the % of PI.
.: Stealth 86 :.
#1741 |
Check you DI computer under bonnet is securely grounded via all monuting bolts
Why does fuel ethanol % log/ read 0 if your on E85 ?? Check low pressure fuel pump pressure should be around 45psi you will need to Tee into low pressure fuel line. Although some delicious flex kits do measure low pressure fuel pressure. Remove fuel filter and check its not blocked (in tank filter), had an NA guy with similar issues had blocked fuel filter, he used some weird fuel additive and it turned to jelly in tank blocking fuel filter, don't use additives with E85 |
#1742 | |
I was considering the fuel filter being clogged. I think I am at 66k miles, which isn't a lot. I usually use Chevron or Shell, but I don't know about the previous owner, but I am willing to consider it could be the fuel delivery. I feel like if it was the injectors then the engine would throw a code or idle rough. It could be the fuel pressure regulator. I don't have a fuel pressure gauge, so I'll have to look into something to test these things. Here is another log. This time with the 95mm pulley (7.5 psi). It felt smoother and the pulls in any gear at any rpm feel smoother, yet the best response, whether with the 85mm or 95mm pulley, seems to be for just a second or two when I am cruising, but higher in the revs and gun it. But it quickly loses its power and pulls less like it got rich or lean or something. I dunno. Repeat WOT 85mm pulley https://datazap.me/u/jirace/repeat-w...?log=0&data=29 WOT 95mm pulley https://datazap.me/u/jirace/3rd-gear...og=0&data=8-29
#1743 |
Drives: brz 2017 hksv2
maybe PI too high? it seems to max out at 26ms.. that seems too high, and DI seems to have still room to augment it.. try to reduce PI ratio maybe?
#1744 | |
yeah same deal port injector pulse width way high , something weird going on shouldn't need that much pulse width to deliver fueling on petrol you don't want to go ober about 15ms port and about 6ms direct |
#1745 | |
Drives: Toyota GT86
#1746 |
I had a similar afr behaviour when i was trying scaling my port injection, and tried 100% PI. I m NA so obviously i have lower values of everything but when my port injection went over 18ms of opening, afr got weird
Since your DI isnt maxed out i would just try to just add more DI, and then maybe it s time to buy bigger port injectors? |
#1747 |
I should clarify that DT is doing all the tuning, so I was posting here to see if anyone else has had a similar log and disgnosed the mexhanical problem because that is what my tuner believes is the case. The evidence seems to support that position. I’m leaning towards it being an issue with the fuel filter. I’m under the impression that the whole fuel pump assembly would need replacing, and that it is a bitch to do, nor is it cheap, so hopefully I can survive on the large pulley for now.
#1748 |
Ok but.. 26ms of port injection is extremely high and dangerous, you can t keep it like that
The other logs you posted where port injection ms opening is lower than 20ms have no afr issue |
#1749 |
Drives: Toyota GT86
Yes, I got that part. Hence the suggestion to log the custom maps as the PI ratio is variable:
https://datazap.me/u/jirace/repeat-w...5&mark=519-541 That's not the case in the stock tune, so the only way that can happen is through custom tables. In the stock tune the PI ratios are fixed. Maybe it's a hardware issue, but as KN47 said AFR is correcting itself (somewhat) above 7000 rpm. If it was a lack of fuel, it would be to expect that it would get worse with higher rpm. Logging the custom maps might help DT to diagnose if there is an issue with the tune. Looking in the Ecutek manual, they recommend max DI injection of 5.5 ms and not less than 1 ms from injection end of DI to spark. You have 4.8ish ms and over 4 ms from end of injection to start of spark. Maybe the DI is capable of delivering a higher percentage of the total fuel.
#1750 |
My tuner said on the low boost pulley there has been no fuel problems so that is good but it doesn’t answer what the cause was. Im thinking fuel delivery from an old fuel filter. I am at 63k.
I appreciate the advice. Unfortunately the tuning part of things is out of my hands. Only the mechanical stuff can I improve.
| RGM Supercharged 86 performance data | TheGooseman | AFRICA | 14 | 12-13-2014 01:15 AM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 12:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 09:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 04:57 PM |
| ECU Data Logger | Motordyne | Engine, Exhaust, Transmission | 5 | 07-18-2012 09:27 AM |
