Old 01-20-2019, 08:46 PM   #17417
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Originally Posted by Grady View Post
Out with the old
In with the new
I hated my ACT. Make sure you have the updated TOB in the kit, as there is no known aftermarket TOB.
Old 01-21-2019, 12:46 AM   #17418
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Originally Posted by Brink View Post
Pothole warnings? Where do I get this?
I'm always running Waze!
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 01-21-2019, 12:54 AM   #17419
dhuang
dhuang's Avatar
Same here. My ACT SB7-HDSS kit made my FR-S lock out of 1st gear about 5k into it. Had an upgraded Verus fork and everything. Never figured out why.
2017 Series.Yellow
2013 Whiteout
Old 01-21-2019, 10:56 AM   #17420
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Same here. We even sent it back to ACT and they tested it and said everything was ok. It is in a box in the garage still like new. The locking out got better with the Verus fork/pivot. I would also have engagement/disengagement problems. Sometimes I would have my foot to the floor and still be creeping forward. Then sometime would go to take off and lifting the clutch with nothing happening, have the clutch half way off the floor and suddenly engage, like you dumped the clutch.
Old 01-21-2019, 03:51 PM   #17421
e30kawi
Drives: CWP limited
Originally Posted by edwardl View Post
Didn't do something to the brz but I got something for the brz. Set of quickjacks!
Those look awesome! Have you had a chance to use them? About how high does it get the car off of the ground? I may have to buy a set.
e30kawi is offline   Reply With Quote
Old 01-21-2019, 05:38 PM   #17422
norcalpb
norcalpb's Avatar
Installed brand new Subaru door lock actuators.
For the past couple months my door locks wouldn't work. I did some research and found out the actuator straight up goes bad eventually.
Install was MUCH easier than expected. It's only held on by 3 bots.
Doors now have a matching lock noise and the door handles have more resistance when pulling, just like new.
Old 01-22-2019, 12:24 PM   #17423
edwardl
Drives: 2018 BRZ
I haven't used them yet as the temperature has dropped to the single digits the last few days. Hopefully if it warms up I can do an oil change this weekend. Their specs claim to raise the car around 18-19 inches
edwardl is offline   Reply With Quote
Old 01-22-2019, 02:59 PM   #17424
e30kawi
Drives: CWP limited
Let me know how it goes and how high they go when you do get to use them please!
Old 01-23-2019, 12:55 AM   #17425
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Installed new REAL leather steering wheel from 86worx.
wolffbite is offline   Reply With Quote
Old 01-23-2019, 10:12 AM   #17426
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
I've been itching for an aftermarket wheel since I switched from my WRX with a DAMD wheel to the BRZ. Is the diameter the same as stock? Can you measure the differences from the stock wheel? Or take a picture with the stock wheel up against the new one?
tehShirt is offline   Reply With Quote
Old 01-23-2019, 11:08 AM   #17427
wolffbite
Just the tip
wolffbite's Avatar
Sure I can do that later tonight.
The specs say it is 355mm vs stock 362mm so supposedly it is a slightly smaller diameter, will confirm with a measurement if I can. The wheel is noticeably thicker all around, and both the smooth and perforated portions of the leather have a light texture to them so it is nice and grippy. The flat bottom is great too.. my knees always hit the original steering wheel when I got in and this gives just enough clearance to prevent that now.
Love everything about it other than the price
Old 01-23-2019, 11:13 AM   #17428
tehShirt
tehShirt's Avatar
Awesome, thank you. Look forward to seeing that.
The price is pretty high, but it's something you use/enjoy every drive so I think it's worth it. I'm debating getting this versus having Sweidit recover my wheel. Leaning towards this though, for the exact reasons you mentioned.
Old 01-23-2019, 01:18 PM   #17429
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
Love mine as well!
Here's a photo I took of both hubs before the swap:
BA9092 is offline   Reply With Quote
Old 01-23-2019, 01:33 PM   #17430
maslin
Benz Tech
Drives: 2017 BRZ Premium
Removed my clutch spring last night, the feel is somehow even worse than before It's springier than it used to be, engages just as (or after?) your foot is off the pedal.
I'll be reinstalling it today.
maslin is offline   Reply With Quote
