Old 04-22-2014, 01:06 PM   #1709
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@shiv@vishnu I've just updated the firmware on my OFT, including the template from your website, and it's now added a few extra channels like FLKC.
However, when I select FLKC and hit OK (staying within the max 12 channels) it throws up an Error and I'm unable to proceed to view Realtime and log. But when I de-select FLKC, everything works fine.
Fizz is offline   Reply With Quote
Old 04-22-2014, 01:23 PM   #1710
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
We are still working on implementing that channel. Just ignore it for now. I'll make an announcement when it's ready for prime time
Old 04-27-2014, 08:27 PM   #1711
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I Received my replacement OFT yesterday and went right to work on taking baselines of the stock tune with virtual dyno and took a medium sized log of me building up the IAM to 1 before making some pulls to convert to virtual dyno graphs.
http://datazap.me/u/solidone/stock-b...zoom=7427-8432
What does it mean when FLKC goes from 0 to 100? means its sensing knock? If so, i\stock tune sure does knock a lot.
Here are the Virtual dyno results for Vishnu STG 1 vs Stock tune on a near-stock car (dropin filter and wheels/tires)
Not many surprises in terms of power increase. But Y U so rich, Vishnu???
Old 04-27-2014, 09:14 PM   #1712
steve99
There were a few updates you may have missed
you need
OFM version 1.07.1 (note the .1)
Let OFT update on latest OFM 1.07.1 to ver 1.26
Download and apply latest template as well
than FLCK should log correctly
but if your IAM drops to less than one, can see plenty fbck over -1 and a couple over -3 as well as the chunks out of your kc learned pretty well confirms its knocking .
solidONE (04-27-2014)
Old 04-27-2014, 10:31 PM   #1713
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
[ame="https://www.youtube.com/watch?v=rw_F37K79Ow"]FRS N/A dyno Revworks header, OFT - YouTube[/ame]
ok so heres my run, im wondering what is causeing the hp to flat line at 4700- 5000 rpm?? my cross over to full direct is at 5k idk if that has an effect on the smoothness of the transition... also my car will not stay put in the mid 12 as command shows. the longer i drive it the leaner it goes. this run was about low to mid 13s. wth is with this learning curve????
IG-Joey_Soul
Old 04-28-2014, 01:50 AM   #1714
troek
troek's Avatar
Drives: 2012 Toyota 86
Is that just on a tune?
Old 04-28-2014, 02:54 AM   #1715
steve99
Whats your LTFT like, If you maf scaling is out and your fuel trims are high in CL it can transition across to OL at WOT and the gap between commanded AFR and actual AFR can be quite wide.
When you first flash all is sweet as trims are reset, then after a week or so if your maf scaling is off your trims will be high and your AFR off .
Could be a lot of other things as well like exhaust gasket leak throwing off O2 sensor readings.
Old 04-28-2014, 07:55 AM   #1716
regal
I don't understand tuning OL WOT, we used to program to get the heck out of OL ASAP.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 04-28-2014, 10:03 AM   #1717
Grip Ronin
The Mechanic
Grip Ronin's Avatar
well its 7-4% in CL and -3.91 in mode 2 injection till about 3500-5k then drops too.78 and a/f is faily close. i have rescaled the maf in the higher range not the CL. getting the high pressure pump warranty a few months ago wouldnt throw off injector scaling would it??
IG-Joey_Soul
Old 04-28-2014, 11:59 AM   #1718
Kodename47
Kodename47's Avatar
Drives: UK GT86
Don't you mean the other way around?
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-28-2014, 11:31 PM   #1719
1Cor10:23
1Cor10:23's Avatar
Could I get some thoughts on my data log? Greatly appreciate any and all comments
Stage 2 UEL on 94 Octane.
log is here http://datazap.me/u/1cor1023/140428-...0&data=1-11-12
AFR shows rich on WOT, you can see +LTFT (~3.9) at high revs on 2nd and 3rd gear pulls. Another concerning point is the KC going on all over the place causing the IAM to drop to .88 after first 2nd gear pull and then .88 later on in log.
Anything I should be concerned about?
Would appreciate your thoughts if you have a moment @shiv@vishnu
Cheers.
The Following User Says Thank You to 1Cor10:23 For This Useful Post:
Chad86 (04-29-2014)
Old 04-28-2014, 11:46 PM   #1720
troek
troek's Avatar
that graph is super hard to read, try not recording for so long, it will be able to read it easier. your AFR seems fine but i can only jump from like 6000 rpm to 7500 with one mm of mouse movement, lol.
http://datazap.me/u/troek/stage-2-pu...data=1-4-5-6-7
heres my map, 3rd through 6th gear. look how long 6th gear is LOL! this tune is rock solid, i love it.
Old 04-28-2014, 11:50 PM   #1721
1Cor10:23
1Cor10:23's Avatar
Hey Troek, you can zoom in by dragging from one end of the 'rpm spike' to the other and it'll then be a closeup of the pull.
troek (04-29-2014)
Old 04-29-2014, 12:04 AM   #1722
troek
troek's Avatar
Haha thanks! I thought itd be cool if u could do that but i couldnt figure it out.
The Following User Says Thank You to troek For This Useful Post:
1Cor10:23 (04-29-2014)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
