07-26-2014, 08:33 PM | #1709 |
WTF!? i have to cut my dog in to 8 pieces to bring him to Laguna Seca!?
FUCK THAT! FUCK MATH! JIM BEAM! WOOOOOOO HOOOOOOOO! |
07-26-2014, 10:19 PM | #1710 |
Fat on Corn Syrup
Got a track related question? I'll try to answer.
What you did there, I see it. LoL I was under the impression that 'added paddle or electronic shifters' meant anything added above the BTM, which for us would be the automatic transmission that is a factory option as opposed to the manual tranny that comes standard in the base trim model. I would love to not take the points, but I think you're right right, I'll take it up with our chapter director. I also assumed the same to be true of our spoiler, which is oem, but again an option above the BTM which comes without a spoiler. And we did notice rue difference the oem spoiler makes. We had the car for two weeks before the spoiler arrived at the dealer and had already done about 1600 miles with no spoiler. The oem is surprisingly effective. Edit: I should add that we had the spoiler added as a cosmetic detail when we first bought the car, and had no competitive plans at the time. I can't see removing it now as it would feel naked. Sent from a secret volcano base using trained sharks |
07-27-2014, 01:56 AM | #1711 |
Anyone who would argue that the at in the brz is an advantage is doing so purely as a technicality and would be falling under the unsportsmanlike clause in the ccr if I were the RD.
Mike |
The Following 3 Users Say Thank You to AZP Installs For This Useful Post: |
07-27-2014, 03:50 AM | #1712 | |
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
The Following User Says Thank You to ddeflyer For This Useful Post: | kavanagh (07-27-2014) |
07-27-2014, 10:14 AM | #1713 | |
Drives: Used to Drive:Grand-Am GS #54 E36M3
If fluid expansion is an issue, a vent can be added to relieve the pressure. It would be great if a radiator could be avoided short of endurance racing. I'd want to avoid the complexity and noise that a system like this one would have. Last edited by dradernh; 07-27-2014 at 10:57 AM. |
The Following User Says Thank You to dradernh For This Useful Post: | CSG Mike (08-07-2014) |
07-27-2014, 11:29 AM | #1714 | |
-Mike Paisan Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
07-27-2014, 01:29 PM | #1715 | |
Fat on Corn Syrup
07-27-2014, 02:35 PM | #1716 |
Off Topic
Both the aftermarket diff covers on FT-86SF made a point to say that they included ports for temp sensors and fluid coolers. That makes me think that it's not included on the OEM setup.
07-27-2014, 04:32 PM | #1717 | |
Fat on Corn Syrup
Does anyone that knows NASA TT rules know if the spherical bearing in the cam plate will cause a points assessment per suspension rule E.22? Metallic and/or spherical-design replacement suspension bushings +3 (except for pillow ball camber plate joints, sway bar end links already assessed points in E.7) above, control arm spindle/knuckle joints already assessed points in E.9) above, and panhard rod, Watts link, torque arm, and third links already assessed in E.19), E.20), E.21), E.22) above.) Rule E.7 for reference even though it does not apply: Add, replace, remove, or modify anti-roll bars (“sway” bars—front, rear, or both) or end links—may have spherical joints on the end links and/or relocation of the mounting points without additional points assessment) +2 |
07-27-2014, 05:36 PM | #1718 | |
Drives: 2013 Hot Lava FR-S 6 MT
One thing I'll say about suspension though, specifically spring rates if you are looking to make any changes in the future. I had a set of RCE Tarmac II clubsports with 400/400 spring rates. I moved to the KW V3s that have a slightly softer front rate to rear rate (340 Front and 400 rear) and was very happy with the softer front. Turn in was much more precise and though there is a hair more body roll, the steering at speed into corners was fantastic. I know many more people think that you should have stiffer springs up front due to weight distribution, but that wasn't my experience at all. 3 track days since the switch on my coilovers and spring rates, and I couldn't be happier ... I know though ... there are a ton of people that say the opposite ... I can only tell you what my experience has been ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
07-27-2014, 07:03 PM | #1719 |
Drives: 2012 Toyota 86
almost all the time attack cars(86/brz) over here in japan run stiffer springs in the rear too.
07-30-2014, 02:46 AM | #1720 |
Drives: 86 GT
how many track days/heatcycles would RS3's take before they're trashed?
What tread depth is the fastest for said tyres? got a track day in a month and my rs3 are quite low. thinking i should get some new ones and wear them in a bit |
07-30-2014, 12:47 PM | #1721 |
Mike, I just completed my 10th track day last Friday. My lap times are improving and more consistent. I've basically followed the recipe you laid out in your sticky. Now I'm looking for some "next steps" for both car and driver. Goals: 5 or 6 track days per season, my car is a DD so I want to maintain a reasonable comfort level for street driving, I'm willing to mod the car but want to minimize the expense. To date my mods are: RS3's in stock size, RBF 600 brake fluid, CL RC5+ pads, Perrin panel filter, Grimmspeed strut brace, Grimmspeed master cyl brace, Harry's Laptimer for both video and data.
My initial thoughts are crash bolts and alignment, slotted/drilled front rotors, and more track time. Input would be appreciated. |
08-07-2014, 09:28 AM | #1722 |
Thanks
I noticed some tracks require you to have wood under any jacks and jack stands.
I don't know much about quality but I know there are different grades available. If I got a sheet of ply wood and cut it to size for my stands and jack, what grade/quality would I need to support the car?
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
