Old 09-05-2015, 08:02 AM   #1709
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
Hmm interesting...
So maybe I'll stick with what I have...camber is more important than toe, no?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 09-05-2015, 08:49 AM   #1710
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
You should be able to adjust toe to whatever you need with the oem arm.
Sent from my SM-G900V using Tapatalk
TallTerror13 is offline   Reply With Quote
Old 09-08-2015, 08:49 AM   #1711
Silver Ignition
APEXHNTR
I can but the eccentrics make it a PITA...especially when the camber moves when you adjust the toe and the toe moves when you adjust the camber...aligning the rears of these cars is annoying lol
#1867 of 2500
Old 09-08-2015, 09:09 AM   #1712
TallTerror13
I completely agree, don't get your car aligned on a Monday or Friday. Lol! It took a lot of time to get the rears to the specs I wanted, but by the end of it my mechanic was a pro at it. You just have to find someone that is willing to take that time.
Old 09-08-2015, 12:29 PM   #1713
Silver Ignition
APEXHNTR
I do it myself. I'm a service advisor at a Toyota dealership so I can use the alignment rack whenever I want to
#1867 of 2500
Old 09-24-2015, 10:56 AM   #1714
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Can anyone recommend a good sway bar setup for STX? I feel like I've got my FRS just about dialed in for AutoX, but would like to tame the tail just a bit more in the fast transitions. At the moment I'm still using the stock sway bars, but was thinking about maybe putting a Strano bar up front. Any feedback would be appreciated.
Current Mods: RCE Yellows, Camber Bolts, RPF1 17x9 +35, Hankook RS3 245/40-17, JDL UEL Header, OFT E85 Tune, K&N Filter
smg1138 is offline   Reply With Quote
Old 09-24-2015, 11:03 AM   #1715
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
If you don't have a front sway bar you are NOT dialed in for autoX. Front bar is a simple mod even a C-Street twin needs to be competitive. I would look into dampers as a top priority mod as well seeing what you have.
Strano front bar and stock rear is a good place to start for sure. Also I'm pretty sure E85 isn't legal for STX anymore.
Old 09-24-2015, 11:12 AM   #1716
smg1138
smg1138's Avatar
Is the Strano bar alone considered pretty good, or should I look at something for the back as well? I'm planning to upgrade the dampers next spring for sure. Also, the last I heard, E85 was still legal. When did that change?
Old 09-24-2015, 11:25 AM   #1717
RTR
Drives: monogram raven
Any fuel over %15 ethanol may only be used when specified by the manufacturer. Damn...I thought it was legal too...just looked it up. Page 40 of the PDF version of the rule book
RTR is offline   Reply With Quote
Old 09-24-2015, 11:57 AM   #1718
conedodging
conedodging's Avatar
Drives: '14 BRZ
Strano bar alone will do you fine
conedodging is offline   Reply With Quote
Old 09-24-2015, 04:19 PM   #1719
smg1138
smg1138's Avatar
Thanks for the recommendation. Are there currently any fitment issues with the Strano bar? I was reading through some older threads and noticed that was an issue a couple of years ago.
Old 09-24-2015, 04:22 PM   #1720
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Yeah I want to know too. Otherwise I'll be looking for similar stiffness bars - Whiteline 22mm, Eibach 25mm, Hotchkis 25mm
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 09-24-2015, 04:23 PM   #1721
ka-t_240
HATE This rule. We can't even get good 91 up here.
Why make a street legal fuel illegal, but allow 100octane race fuel!!!
ka-t_240 is offline   Reply With Quote
Old 09-24-2015, 04:23 PM   #1722
ka-t_240
I run the RCE Swaybars on my car, along with RCE T2s.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
