07-12-2017, 08:05 PM | #17067 |
Drives: 2013 FR-S, 2023 BRZ
not sure if any of you guys remember my clutch issues i was having a few months back when i had trouble getting it into gears. Well the problem has popped up a few times since i replaced my clutch but i s happening more now. Ive narrowed down what needs to happen and how its fixed. It only happens if the car has been sitting for a bit and i drive it after the temps have dropped, when the car is off it goes into every gear fine, when its running it wont (as if i have no clutch or am not pressing the pedal) and theres no pedal feeling. After pumping the clutch pedal several times I start to regain feeling in the clutch pedal, that is i finally feel the biting point. My dad whos a mechanic told me it might be an internal leak in the master cylinder which seems to make sense, I guess the temp drop affects the clutch fluid and then me pumping the pedal pushes air bubbles out or something, after pumping it many times the cars drives perfectly normal. Do any of you guys have a second opinion or is my dads guess pretty accurate? Going to buy parts soon so hopefully i can get a second opinion
2013 Whiteout FRS 6MT with a JRSC RS Pulley @ 500ish WHP
2023 Ignition Red BRZ 6MT awaiting boost |
07-12-2017, 11:43 PM | #17068 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Clutch has its own reservoir...
07-13-2017, 12:13 AM | #17069 | |
I'd start by bleeding the system. humfrz |
07-13-2017, 12:19 AM | #17070 | |
At least my 2013 has them separate. humfrz |
07-13-2017, 03:09 AM | #17071 | |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
I too am experiencing this with about 9k on my replacement ACT clutch. Already bled the system, but the problem came back. Slave is going to be next. |
The Following User Says Thank You to dhuang For This Useful Post: | arxm (07-14-2017) |
07-13-2017, 09:26 AM | #17072 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
My bad, one of those times I made an assumption because it's been a pretty common design practice elsewhere. Definitely don't like to misinform.
-O/D
2016 FR-S, Hot Lava |
07-13-2017, 11:11 AM | #17073 |
07-13-2017, 12:31 PM | #17074 |
I had this same issue in my GS-R and it turned out to be a leak in the one rubber hose in the clutch system, that usually connects to the slave cylinder. Check that hose for leaks.
It looks like this: http://www.ft86speedfactory.com/chas...-line-778.html |
The Following User Says Thank You to MJones_RB For This Useful Post: | arxm (07-14-2017) |
07-13-2017, 12:35 PM | #17075 |
Drives: DE5 Integra Type S
Full detail today, wash, clay bar, and a wax! Looks better than the day I brought it home...less the creeping crack on my windshield :P
07-13-2017, 01:56 PM | #17076 |
Drives: 2016 Scion FR-S
I finally lowered my car! Sent from my iPhone using Tapatalk |
07-14-2017, 04:29 AM | #17077 |
Drives: Whiteout '14 FR-S Monogram A/T
Started and completed my headlight blackout!
The Following 5 Users Say Thank You to Alysa For This Useful Post: | Blueboyfrs (07-14-2017), Detroiter (07-14-2017), Kairo (07-14-2017), MJones_RB (07-14-2017), zeal86 (07-14-2017) |
07-14-2017, 09:36 AM | #17078 |
thanks for the suggestions guys, im gonna bring the car into work in the next few days and look for any visible leaks and then im gonna try bleeding the system and go from there.
07-14-2017, 02:40 PM | #17079 |
The Upside Down
Drives: '13 FR-S
Washed my FR-S today. I love how clean and simple (yet sexy) this design is. Makes washing quick and easy.
I also installed Philips Diamond Vision bulbs for the low-beams and chrome amber bulbs for the rear turn signals a couple days ago. |
07-14-2017, 02:40 PM | #17080 |
Drives: 2013 Scion FRS
Joined the sequential taillight club. Really like the look so far.
The Following 3 Users Say Thank You to Kairo For This Useful Post: |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
