Old 04-17-2014, 03:26 AM   #1695
steve99
Originally Posted by solidONE View Post
I was downloading a log I just took onto my laptop and had an accident.
The lower left corner of the touchscreen is now out of whack and I'm afraid to recalibrate the screen. Help me, @shiv@vishnu!
Woah! that looks kinda terminal hope they can send/replace screen.
Old 04-18-2014, 12:00 AM   #1696
gonzo
Drives: frs
Originally Posted by MykeH78 View Post
P.S. The BRZ is aimed at a completely different demographic than the WRX, so that's def no bearing on the decision.
Why have people been saying this?
Fuck if I know what Subaru is "aiming" for but the BRZ and STI attract a pretty similar market. If the BRZ had a turbo that made it close to STI pricing I'd definitely test drive both of them before deciding on one or the other.
gonzo is offline   Reply With Quote
Old 04-20-2014, 07:29 AM   #1697
troek
troek's Avatar
Drives: 2012 Toyota 86
only a few miles on the stage 2 uel tune, but its feeling pretty good. kinda rich though. maybe it will lean up some. plus, if you look close, my boost goes in the positive for a second! lol.
http://datazap.me/u/troek/stage-2-pu...=0&data=1-5-11
Old 04-20-2014, 10:09 AM   #1698
Gilwith1l
Gilwith1l's Avatar
Drives: stock brz. saving my money for ls1
Which ots tune should I use with OEM header / drop in filter / catless front pipe / OEM muffler/ Crawford bpb/ 93 octane
Gilwith1l is offline   Reply With Quote
Old 04-20-2014, 06:54 PM   #1699
steve99
As you have BPB use the new BPB tunes on the bottom of the download page use stage1 93 octane BPB tune for your rom cal id. this is limited to C series at present.
As you have catless front pipe its possible you may be able to run the stage 2 tune BPB , usually this is for persons with catless headers, but some people find they run better on that tune with catless front pipes or high flow second cat.
Check your AFR at WOT on both tunes your looking for high 11 11.6-11.8 shiv targets for safety. If you do decide to run stage2 also check for knock especially at WOT as the stage2 tune runs more advance
Their rearly is not a base tune for your setup so it going to he suck it and see, stage1 is probably the safer option just check AFR at wot and knock correction.
It probably going to need a bit of adjustment either by yourself or you could spring for the $200 and get the OFT guys to do an e-tune.
Gilwith1l (04-20-2014)
Old 04-20-2014, 09:50 PM   #1700
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Hey guys,
So I am pumped to say I just installed my open flash headers and flashed the UEL Stg 2 tune right at the mechanic!
Car is just a pleasure to drive. Playing with the exhaust note brings me much pleasure. The added power really transforms the ride. I couldn't be happier.
here is a log of a 2nd, 3rd and 4th pull
http://www.datazap.me/u/boofneenee/s...zoom=4331-4546
I notice that the ignition advance is gradually being reduced as the rpm's go up. I am assuming this means the ecu is pulling timing? Perhaps this is normal and I am over thinking it. This pattern is the same that I have viewed in my earlier logs while running stage 1 and logs posted by other forum members.
Also here is a log with just the knock correction variable highlighted. Their is knock correction as timing is being pulled up to .6 degrees but it only appears to happen at cruise speed on the highway. Is this normal? I think some knock is inevitable. It was happening with the Stg 1 map I ran as well.
http://www.datazap.me/u/boofneenee/s...og=0&data=1-12
Mods: open flash header, Nameless 5" cat back and air filter. 93 pump gas.
thanks!
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following 2 Users Say Thank You to Boofneenee For This Useful Post:
Chad86 (04-21-2014), solidONE (04-20-2014)
Old 04-20-2014, 11:12 PM   #1701
steve99
The timing reduction is normal, you need to look at kc learned and compare values to "Advance Max A table" however it looks fine no "chunks" out of kc Learned values.
have a read here if your interested
http://www.ft86club.com/forums/showthread.php?t=61820
0.6 FBCK occasionally is pretty inevitable on throttle tip in if it was over 1 start to worry IAM is stable at 1.
Looks a touch rich at WOT shiv targets high 11's (11.8 or so) but don't sweat it. If your really picky you could do the MAF scaling to get the LTFT a bit better (your almost +4%) if that came back 2-3% percent the AFR would be pretty spot on.
Boofneenee (04-21-2014)
Old 04-20-2014, 11:35 PM   #1702
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Hey guys,
thanks!
5" cat back?!
Old 04-20-2014, 11:38 PM   #1703
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
5" cat back?!
5" muffler version of the 2.5 I assume
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Old 04-21-2014, 01:34 AM   #1704
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Hey guys,
thanks!
I'm looking to run a similar setup to yours. But I am thinking to run the Perrin 3" resonated catback. Any adavantages over the nameless catback? I'm running 94 Chevron, do you find your setup no longer has much of a torque dip?
[ame="http://www.youtube.com/watch?v=VOQ0JrxqkUA"]Perrin 3" Catback Exhaust Resonated Sound (Subaru BRZ) - YouTube[/ame]
Chad86 is offline   Reply With Quote
Old 04-21-2014, 08:13 AM   #1705
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
I posted two videos of my setup in the open flash header thread. Go check it out
FRS
Old 04-21-2014, 08:14 AM   #1706
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Thank you for explaining. I hope my Afr will improve over time. I hav put a decent amount of miles on the car since I flashed Friday. Maybe it still needs more time..
FRS
Old 04-21-2014, 06:21 PM   #1707
ZoM
Drives: 2014 Monogram Raven 86
@shiv@vishnu any chance of lc for b series roms soon?
ZoM is offline   Reply With Quote
Old 04-21-2014, 07:10 PM   #1708
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Absolutely. Things just take time and I haven't gotten around to it yet.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
DC2R (04-21-2014)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
