Old 03-07-2015, 11:31 PM   #1681
alpax
alpax's Avatar
Drives: 2013 Subaru BRZ AT JRSC
Hi fellow JRSC owners, I need your help. I already mentioned some time ago that about a month after the SC install I got P0172 fault code - System too Rich (Bank 1), and someone else confirmed they had the same. The code appeared a couple times, then for a while everything was fine. Then it started appearing again. It appears together with a noticeable change in the car's behavior - it becomes sluggish when starts moving, the RPMs on idle are not stable. Recently the engine even stalled when I was backing up from the garage. I tried to clean MAF sensor, as it seems to be one of the common reasons in such behavior. It helped, but only for several days. Then I got the same symptoms: sluggish reaction to the gas and P0172 code. This time together with P117B and P1170.
I did some logging with EcuTek (got it with JRSC kit), here is the data, and here are the graphs:
The second one was taken after I cleaned MAF again:
Can anyone get any clues from this - what the problem might be, and how it could be fixed?
Thanks!
alpax is offline   Reply With Quote
Old 03-08-2015, 04:15 AM   #1682
Do you have any vaccuum leaks?
Old 03-08-2015, 04:26 AM   #1683
sw20kosh
Drives: 2013 Black FR-S
Those fuel trims look off to me.
Old 03-08-2015, 08:15 AM   #1684
autograph
autograph's Avatar
Drives: 6MT Hot Lava
thanks to @ScionOfHorus @enivid @dp1 @Lone Starr and @CSG Mike for your input guys. looks like ill be going with 225's once my stock tires wear out :P
autograph is offline   Reply With Quote
Old 03-08-2015, 08:30 AM   #1685
enivid
enivid's Avatar
Drives: WRB JR BRZED
Attachment 104071
Attachment 104072
Thanks!
I battled similar issues. Fuel trims were terrible. Car almost died a few times, sluggish behavior, etc. I spent 6 months trying to figure it out. Finally found it was the God damn maf oring. It just became stretched out and leaked.
enivid is offline   Reply With Quote
Old 03-08-2015, 01:07 PM   #1686
lastexile1987
lastexile1987's Avatar
Drives: Lightning Red '13 Limited BRZ
Guys, I need some real help. I just had my sc installed over the weekend (professionally installed). Today while running some errands, the oil light came on and as soon as I parked, the engine bay started to smoke. When I opened the hood, there was fluid all over the engine and fluid leaking. Based on the oil indicator and the low oil level on the dipstick, I'm assuming the oil lines were not put on properly. I am not any kind of expert on this type of thing and this is the first time I've dealt with anything like this, so this is just my best guess. What do you guys think happened. If you need more info, I'll try and provide what info I can.
Also, the exhaust manifold was smoking but that has stopped since. I'm afraid of taking the car to any of the local oil places (jiffy lube, etc.) In case something happens again.
lastexile1987 is offline   Reply With Quote
Old 03-08-2015, 01:08 PM   #1687
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
Did you have an oil cooler installed with the sc?
ScionOfHorus is offline   Reply With Quote
Old 03-08-2015, 01:10 PM   #1688
lastexile1987
Yes the oil cooler was installed with it. I've driven the car a few times since I got it back yesterday, and this only just happened
Old 03-08-2015, 01:11 PM   #1689
ScionOfHorus
Check the lines on the cooler, see if they popped off. Hopefully they were just not put on properly.
Old 03-08-2015, 01:20 PM   #1690
lastexile1987
I don't see any lines on the cooler loose. If it adds any info, it is the right side of the engine that got fluids on it. The left side is clean. Don't know if that narrows down possibilities.
Old 03-08-2015, 01:22 PM   #1691
lastexile1987
Should I turn the car on for a moment to see if more liquid comes put or will that just make it worse?
Old 03-08-2015, 01:22 PM   #1692
ScionOfHorus
Follow the lines with your hand and feel for any loose connections or holes on all the oil lines
Old 03-08-2015, 01:22 PM   #1693
ScionOfHorus
If you have no oil you don't want to turn it over.
Old 03-08-2015, 01:24 PM   #1694
lastexile1987
Got ya. Won't do that...
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
