Old 06-24-2018, 09:22 PM   #16913
BreakTraction
BreakTraction's Avatar
I cut my fenders and put the rocket bunny v1 front flares on, will have the rears put on when I get spacers.
Insta/ Youtube: @BreakTraction
BreakTraction is offline   Reply With Quote
Old 06-24-2018, 10:08 PM   #16914
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
took off the yellow fog lights and detailed the car
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 06-25-2018, 11:40 AM   #16915
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
I installed an OEM STi badge, rear diffuser and red TS pinstriping front/rear.
-B
HeresMyMind is offline   Reply With Quote
Old 06-26-2018, 12:33 AM   #16916
spike021
spike021's Avatar
Worked with @JeremyR to install my OEM TRD kouki sideskirts:
I'm not a perfectionist when it comes to paint matches by any means, but I'd have to say the paint is probably about a 95 or better percent match to my body color. Extremely pleased I went for this look.
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 06-26-2018, 01:26 AM   #16917
Brink
Drives: 2017 BRZ
Originally Posted by trippinbillies40 View Post
Installed a sweet new tow hook bike rack by Slambert.
How much does that rack weigh? Looks pretty hefty to put on the slambert, considering it could have a couple bikes added to it. I still have my slambert sitting in a box in the garage, haven't used it at all yet, but I have a Kuat 2-bike rack that's a bit slimmer than what you have there to pair with it.
Brink is offline   Reply With Quote
Old 06-26-2018, 07:45 AM   #16918
trippinbillies40
trippinbillies40's Avatar
Drives: '22 WRB
This isn't the standard Slambert rack. Shawn is developing a new rack system specifically for this application. He's engineering it to hold 100lbs. Each of those Thule racks weighs 15lbs, so that leaves about 35lbs per bike. Will be testing it more to make sure they can hold it.
trippinbillies40 is offline   Reply With Quote
Old 06-26-2018, 11:07 AM   #16919
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
The standard Slambert is designed for a 100 lb tongue weight. So... what's the difference here in terms of how it is mounted?
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 06-26-2018, 08:16 PM   #16920
trippinbillies40
Drives: '22 WRB
Pretty similar, but instead of a square draw bar, you've got two 1.5" pipes being bolted on, so considerably more torque, and then the shear strength of the end of the pipe.
That having been said, I don't think there will be any issues.
Old 06-27-2018, 08:34 AM   #16921
Stang70Fastback
A.K.A. Starlord
I got it wet. I love the second 2x zoom lens on the newer smartphones. Makes close shots of cars much more natural-looking by eliminating the odd proportions you get when taking the same photo from a closer distance with the main wide-angle lens.
Old 06-27-2018, 09:18 AM   #16922
JD001
JD001's Avatar
Drives: Subaru BRZ
What if the setting is unnatural??
Old 06-30-2018, 04:52 AM   #16923
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Black & Yellow
Keeping the Series.Yellow theme intact by tinting the center of the taillights and reverse bar.
2017 Series.Yellow
2013 Whiteout
VINwiki - Changing Automotive History
dhuang is offline   Reply With Quote
Old 06-30-2018, 05:27 AM   #16924
J1Avs
Drives: 2018 BRZ tS
Where did you get your tail light tint from? It looks a bit darker than mine
J1Avs is offline   Reply With Quote
Old 06-30-2018, 02:38 PM   #16925
xenarc
xenarc's Avatar
Drives: 2017 SUBARU BRZ
@Stang70Fastback, that BRZ looks sexy. Those HRE wheels are on point.
xenarc is offline   Reply With Quote
Old 06-30-2018, 02:54 PM   #16926
xenarc
xenarc's Avatar
I ordered a roll of 6mm pinstripe but it's too thin, I had to do a double stripe for the front bumper. I am going to order 12mm and re do it again. For now this is the result:
