View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 334 79.15%
No (Please only vote after you have 300 miles or more on the odometer) 88 20.85%
Voters: 422. You may not vote on this poll
Old 09-09-2012, 02:09 AM   #155
JollyJON
JollyJON's Avatar
Drives: DGM Subaru BRZ
The chirping began in my car at 300 mile and continued until I moved to Oklahoma from Dallas. Once I started pumpin no ethanol gas at 1500 miles, I've never heard the chirping again.
JollyJON is offline   Reply With Quote
Old 09-09-2012, 03:33 AM   #156
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
Chirp started today at about 550 miles... Still faint.. 91 Chevron CA blend.
Norkoastal is offline   Reply With Quote
Old 09-27-2012, 02:27 PM   #157
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
So I'm am schedualed to have my fuel pump replaced next week, I had a concern after reading the 5009 page repair manual I found on here. So I called the service manager to micro manage and inquire.
Q1 Did they order all the support parts required to replace the pump?
A1 Yes, SOA told them everything they would need to replace the pump since my dealer said it would be the first one they ever did. (wish me luck)
Q2 Since I am still waiting on the ECU from the TSB is it possible that my old ECU will not communicate with TechStream to set the correct PSI for the new fuel pump?
A2 I don't know but that is a possibilty. I will call SOA and see if the TSB on the DLR is more of a TechStream issue than just customization or mainly a Techstream communication issue.
This is where I pray a Toy Tech might chime in define if the TSB is related just to customizations and Other TechStream connectivity?
Spartan65 is offline   Reply With Quote
Old 09-27-2012, 03:53 PM   #158
Bfly
Bfly's Avatar
Drives: BRZ Limited
Experienced chirpping at EXACTLY 300 miles. This was after my first fill up so I'm sure it has to do with the gas. I filled up with premium unleaded at Dillons.
Bfly is offline   Reply With Quote
Old 09-27-2012, 04:36 PM   #159
soconfoozed
Drives: 2013 BRZ Limited 6MT WR Blue Pearl
I called my CSR at SoA today noting the Scion TSB, but she hasn't called me...they leave in 30min. Time to bug her, I suppose.
soconfoozed is offline   Reply With Quote
Old 09-27-2012, 05:35 PM   #160
ML
ML's Avatar
Drives: 13 White MT FR-S
I was told today by a Scion/Toyota mechanic that this is from the 3000psi Fuel pump, and is completely normal.
Old 09-27-2012, 08:07 PM   #161
dsgerbc
Drives: BRZ(sold), STI
Shove the printed TSB into his lying face. If you do - stand by and watch him work just in case
dsgerbc is offline   Reply With Quote
Old 09-27-2012, 08:23 PM   #162
Spartan65
Spartan65's Avatar
SO the Service manager just called me from Beaver Scion to let me know the ECU from the DRL TSB does not control the fuel pump through tech stream, So my car goes in on Wednesday for the new fuel pump. They will not give me a TSB to share with you all, but if it gets printed on my receipt, trust me I'll be posting it here.
Old 09-27-2012, 08:51 PM   #163
NeedsmoreCowbell
toyotas are practical :)
NeedsmoreCowbell's Avatar
Drives: Hot Lava FRS
New fuel pump heyyyyyyyyyy! Rejoice!
What will this new pump sound like ? Maybe a tweet? perhaps a hiss! or fap ! A noise less boring and sleep orienting.
NeedsmoreCowbell is offline   Reply With Quote
Old 09-28-2012, 01:15 PM   #164
vagvoba
Drives: 2013 BRZ Limited 6MT WRB
Not the injector
My BRZ has about 2.8K miles on the odometer and indeed it's been chirping since fairly early on.
It doesn't personally bother or annoy me as long as it's not bad for the car. Sports car engines sometimes make some very weird noises. They are not made for GT cruising so the engineers don't pay that much attention to it. Also, the BRZ has a special engine. It's naturally aspirated but still delivers 100hp per liter. That's similar to other sports cars like the BMW M3 and Honda S2000 but with much, much better fuel economy. That requires some serious mechanical hacking.
However, I don't think it's the injector's noise since the chirping frequency doesn't change linearly with RPM. You can test it by letting your car idle while paying attention to the chirping frequency and then slightly increasing the RPM. The chirping frequency will not change. If you rev the engine significantly higher the chirping usually stops or just becomes less audible.
vagvoba is offline   Reply With Quote
Old 09-28-2012, 01:50 PM   #165
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I originally voted No, but I finally opened my hood and mine does in fact chirp, but it isn't something that I notice from inside the car. I would have to hear a silent one to say that it isn't normal.
Old 10-02-2012, 07:03 PM   #166
Spartan65
Spartan65's Avatar
SO my car went in for a fuel pump and this is the car they loaned me to drive. Jennifer in service called and said it should be done by 4:00pm but was unsure as they have replaced on as of yet. Well it shouldn't be that hard to replace, I verified they had all the parts recommended on the TSB in stock.
Old 10-03-2012, 08:09 AM   #167
Dorb
Drives: 16 LM STI/13 LM BRZ/04 AVALANCHE
Come on you guys are freaking me out when I hear this. I always said I would never buy a new car the 1st year it comes out to allow them to work out the bugs - in this case a cricket. But I really,really want this car.
Dorb is offline   Reply With Quote
Old 10-03-2012, 10:07 AM   #168
jeebus
Drives: 2015 Mustang GT (on order)
it's just a minor annoyance.
jeebus is offline   Reply With Quote
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Engine idle chirping (cricket) noise poll. Hanzo Issues | Warranty | Recalls / TSB 5031 05-18-2017 09:41 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
