Old 02-23-2016, 12:07 PM   #155
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Glad to know. I was assuming that it wouldnt really be worth it. I was aware of cold start issues, since i have ran E85 in 5 different vehicles over the last 5 years.
But as Pavel says. More isnt always better, sometimes its just more.
Thank you gentlemen.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 02-28-2016, 05:30 AM   #156
SoCalArgento
Drives: 2014 Argento FRS
PM'd
SoCalArgento is offline   Reply With Quote
Old 02-28-2016, 10:04 AM   #157
bhmax
Drives: 13 BRZ, 17 Focus RS
Someone hinted in another thread that by using O2 input as opposed to evap may make cruising mpg worse. Any truth to that?
bhmax is offline   Reply With Quote
Old 02-29-2016, 04:17 PM   #158
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
None, whatsoever. Rear o2 fuel trimming is disabled in the majority of our tunes anyways.
Sincerely,
Zach
Old 03-07-2016, 10:51 PM   #159
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
PM, bunch of questions. Thanks!
gdrider77 is offline   Reply With Quote
Old 03-07-2016, 11:29 PM   #160
steve99
Sincerely,
Zach
Sure you can disable it
So what is the function of the rear 02 trim ?
why is all that code in ecu ?
"Closed Loop Fueling Target Compensation (Rear O2) Limits (Max)" – This is the max closed loop fueling
target adder based on rear o2 input. The factory default is set to an extreme value so that the limit never
comes into play. However, this can be set to zero to eliminate this compensation on the positive side.
• "Closed Loop Fueling Target Compensation (Rear O2) Limits (Min)" - This is the min closed loop fueling
comes into play. However, this can be set to zero to eliminate this compensation on the negative side.
• "A/F Learning #3 Limits (Max/Min)" - These are the max and min values for the long-term fuel trim based on
rear o2 input. The factory defaults are set to extreme values so that the limits never come into play. However,
these can be both set to zero to eliminate the influence of the rear o2 based long-term fuel trim.
· "A/F Correction #3 Limits (Max/Min)" – These are max and min values for the short-term fuel trim based on
these can be both set to zero to eliminate the influence of the rear o2 based short-term fuel trim.
· "A/F Correction #3 Adder (Increase) A", "...(Increase) B"), "...(Decrease) A", and "...(Decrease) B" – These are
the adders to the short-term rear o2 based fueling correction. Setting all four to zero will remove the influence
Old 03-08-2016, 11:44 AM   #161
DeliciousTuning
A bit more in depth, sure. As I said before, all of these compensations are disabled in our Flex Fuel tunes.
-Zach
Old 03-10-2016, 04:52 PM   #162
brzaapi
CAR-AHOLIC
brzaapi's Avatar
I dont believe I have seen this question as of yet. But since I just went back to 91 (supposedly no ethanol, straight 91) i noticed that the app still displays 10% ethanol and never goes lower.
Is the 10% the lowest limit on ethanol?
Not that i really give a damn about ethanol content below 10%. I just want to make sure everything is running correctly. Especially before dyno day tomorrow.
Daily: Audi TT RS
Old 03-10-2016, 05:01 PM   #163
DeliciousTuning
10% is typically the minimum amount of ethanol put in today's pump gas fuel. Just about every fuel in the US now has at least 8-10% ethanol in it. There are special pumps in some states that have ethanol free gas, but they're few and far between!
Sincerely,
Zach
Old 03-10-2016, 05:05 PM   #164
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Sincerely,
Zach
True. But should the app show below 10%, or is 10% the limit?
Daily: Audi TT RS
Old 03-10-2016, 05:41 PM   #165
DeliciousTuning
The APP has no limits; it will go from 0% all the way to 100%.
Sincerely,
Zach
Old 03-10-2016, 05:46 PM   #166
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Cool beans. Thank you sir. Lets me know what "100% gas - no ethanol" is worth at the gas station. Worth about as much as E85 actually being 85% ethanol.
I love the flex fuel kit, and being able to read the ethanol content is great....but the
app is always giving me bad news on E content.
Ignorance was bliss.
Daily: Audi TT RS
Old 03-10-2016, 06:14 PM   #167
DeliciousTuning
Those ethanol free gasses aren't that great anyways
-Zach
Old 03-10-2016, 07:00 PM   #168
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Oh I agree. I love ethanol. It's just the principle of the station charging more for it, while they advertise 100% gas.
Daily: Audi TT RS
Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps DeliciousTuning Software Tuning 1213 06-17-2025 04:02 PM
200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) DeliciousTuning Software Tuning 156 07-01-2014 08:37 PM
Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU DeliciousTuning Software Tuning 19 12-07-2013 12:01 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
