#155 | |
Drives: Subaru BRZ Sport Tech Satin White
It's not even about ice racing or even winter driving schools. It happens that the problems this car presents as a winter driver also hinder its ability to be quick on a track but the focus is on discussing why it doesn't drive well in winter and what could be done to deal with this. |
#156 |
I'm still waiting for the list of chassis defects that hinder the winter performance.
#157 | |
An apex is nothing more than the geometric center of the turn, based on the line you're taking NOT the shape of the pavement around you. There are lots of turns where the fast line has the apex in the middle of the track. You're mixing in parabolic entries as well as an early or late apex. Look at this picture... Light blue is a late apex Green is the text book apex Dark blue is an early apex Which line is truly fastest depends on the car, track, where the next corner is and driver, but the text book like is always the starting point. Notice one very important thing about all three lines in that picture? The turn in point, apex and turn exit point are all very close together. The difference is where you feed in more steering and where you're going straighter. If you find you're oversteering out of every corner, you're either driving incorrectly (on the gas before the apex) or taking a line with too early of an apex for your car/setup. There's a 4th option for a driving line that isn't illustrated, and that would be one where you simply follow the inner or outer edge of the track instead of starting from the outside, hitting the inside (proper usage of clipping the apex) then finishing at the outside. That is how you effectively increase the radius of a corner. Compare the radius of the green line in the picture to the radius of the outer edge of the corner. The green line is pretty close to a circular line, but is a MUCH larger radius than the outer edge of the corner. As for what's safer in winter, a late apex is much safer because you're going straighter when you get on the gas. Going straighter means you're asking the tires to provide less lateral grip while you're asking for forward grip. If you're driving the perfectly round text book line you'll be delaying when you can get onto the gas until WAY after the apex or you'll be spinning out.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#158 | |
The result of the defects is a car that oversteers far too readily, most noticably on slippery roads. It is such a silly car in that respect I leave it at home if it is slippery out. It just isn't worth the effort to try and drive it. Hopeless on slippery stuff. Evo long term GT86 is the same even on Dunlop summer tires, new article out today if you have a iPad subscription. All the reports about this car are the same, it oversteers easily. The differences in opinion are whether you like that or not. I don't. |
#159 |
Finally wparsons had looked at a picture which demonstrates what I have been saying all along.
I knew all that but now others can see for themselves how it works. The light blue line shows a tightening radius going in, with minimum radius well before the apex, and increasing radius going out. This is the classic late apex line used with a powerful car and good traction (neither if which applies to the BRZ), or if you are a little uncertain about the bend because you can't see all the way around. This is the slowest entry speed way around the corner because the entry line is the tightest. Combined with the Scandie flick this can even be very effective in a powerful fwd car. The green line is constant radius which is quickest in low powered cars on low friction surfaces, such as in winter. The apex of that line is the geometric apex of the corner, formed by two perpendiculars and a bisecting line from the apex of those perpendiculars to touch the inside edge of the road. This is where the term "apex" comes from even though it is misapplied in reality. The blue line is performed by drivers working backwards, often experienced by idiots and frequently demonstrated by Massa when out braking himself.... This is the "emergency" line, or the holy shit line or the Dipstick line.... |
#160 |
Saying that the car oversteers easily does not mean there is a design defect. The roads were snowy / slippery today when I went to get lunch, so I made a point of taking all the various corners on my route faster than I should have. Getting the rear end to slide was ENTIRELY a function of throttle input at the wrong time. That's not a car defect, it's a driver defect.
That said, since I had all the nannies on as soon as it started to slide they kicked in and the car stayed straight as an arrow. Sent from my Nexus 7 using Tapatalk |
| The Following User Says Thank You to jvincent For This Useful Post: | wparsons (01-17-2014) |
#161 |
Drives: 2013 Raven FRS
Since I live in Los Angeles I've had an especially hard time with the winter driving. Today was like 80F. Brr!
| The Following User Says Thank You to effty_ac For This Useful Post: | wparsons (01-17-2014) |
#162 | |
You should go back and re-read what you've been saying before accusing anyone else of being wrong. You're also wrong on what type of line is fastest, there are lots of times where an early apex is actually much faster depending on the car and placement of the next turn. You calling it the dipstick line is greatly over simplifying the complexity of picking the right line the whole way around a track. Without knowing the layout of the track, the car (and setup) you simply can't call one line wrong. As for which line on low grip surfaces, go look at what kind of line rally drivers take. If you take a text book round line you're going to be waiting a long time until you can get on the gas. A later line will let you get on the gas sooner which will be faster (or safer). Have you ever actually driven on a track, it sure doesn't sound like you have.
Light travels faster than sound, so people may appear to be bright until you hear them speak... flickr Last edited by wparsons; 01-17-2014 at 09:20 PM. |
#163 |
My chevette, samurai, 86 Chevy 2wd, and my ranger all oversteered worse than my BRZ. Do all of those have defects making them unsafe to drive when it's slippery because if they do you better tell the MILLIONS of people driving them.
#164 | |
The samurai were to commit hari kiri rather than admit defeat, odd name for a mini soft reader. Awful and terminally dangerous vehicle completely unsuited to North American driving conditions. |
#165 |
I loved my Sammy
@SmsAlSuwaidiA ranger dangerous really? What do u consider safe? A Volvo a Saab? Sent from my Nexus 5 using Tapatalk
#166 | |
Just about anything is safer than a Samurai, even that pretty hopeless mini pick up, the Ranger. The main thing wrong with the Ranger/B210 was build quality, all pick ups handle fairly poorly. Well, except for the Ford 150 Raptor of course. Now back to the BRZ, which is a very safe car...to have a crash in. |
#167 |
This thread isn't about crash safety its about handling. If you want a safe vehicle buy an s class.
Oh and I never had any issues with build quality in my ranger. Do you like anything? Like are you on antidepressants? I've got an idea, stop driving the car in the winter!! Then we don't have to listen to you bitch about how bad it is. There seems too be way more people that enjoy this car in the snow than ones that hate it. Sent from my Nexus 5 using Tapatalk
| The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post: | wparsons (01-18-2014), ZionsWrath (01-18-2014) |
#168 |
Third rate movie r u sick in the head?
| The Following User Says Thank You to Dipstik-sportech For This Useful Post: | ZionsWrath (01-18-2014) |
| Tags |
| attention whore, can't drive in snow, intellectual masturbation, just won't quit, suberman chronicles xiv, why people hate laywers |
| Selling an AZ car to someone in CA | tracerit | Southwest | 0 | 10-27-2013 12:39 AM |
| Selling AEM intake | swift996 | Mid-Atlantic | 0 | 07-08-2013 10:17 AM |
| Why are they not selling? | roadtrip1098 | New England | 22 | 01-07-2013 11:46 PM |
| Selling my BRZ | Epictetus | Northwest | 4 | 11-14-2012 07:59 PM |
| Selling FRS in Oklahoma | Blckcobra | Dealer Cars | 8 | 05-19-2012 08:41 PM |
