Old 05-10-2014, 07:29 AM   #155
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Curious why not align for -1.0 to -1.5 up front? Seems you now have a trackish setup so seeing stock camber up front surprises me is all?
Old 05-10-2014, 04:43 PM   #156
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
Slow and steady wins the race as they say. It is on my list of things to do, I currently have no camber adjustable parts installed, so I can't do too much about it at this moment. I'm going to replace bushings and whatnot that will be legal for my autocross class, then tackle camber. Suspension is my priority currently. My limiting factor is my wallet, so I'm going to be focusing on biggest impact first. I also want to do things separately so I can better understand each parts' impact.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
Old 05-11-2014, 12:27 PM   #157
Turkish
Serial Cone Killer
Turkish's Avatar
@Scottemad123
... his name is...
C'THULHU
Old 05-12-2014, 07:21 PM   #158
Turkish
Serial Cone Killer
Turkish's Avatar
So I totally just realized that I never swapped the rear side marker bulbs to LED, just placed an order from @Diode Dynamics to take care of that little oversight.
... his name is...
C'THULHU
Old 05-12-2014, 09:29 PM   #159
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
Originally Posted by Turkish View Post
I believe @MysteryMachine was the one who originally purchased it, and then it passed hands a couple times here in Austin before I painted it and installed it on mine. I scraped the crap out of it last evening pulling out of an awkward driveway downtown, the joys of a lowered suspension!
@FrSnake
nope that was me.
I bought it on ebay for like $60
derp should have kept reading my bad
86-tundra is offline   Reply With Quote
Old 05-19-2014, 04:07 PM   #160
Turkish
Serial Cone Killer
Turkish's Avatar
Video of all 4 runs in yesterday's Autox event hosted by SASCA.
This is video I captured during autocross yesterday, this is my third ever autocross event and I came in 21 out of 45 in novice. My new suspension with lack of camber adjustability contributed to increasing the learning handicap, I went from a pretty decent amount of oversteer (full stock suspension) to serious understeer (shock and springs as only aftermarket modified parts of suspension). I will be doing front top hats and rear LCAs ASAP to counteract that so I can continue to develop as an autocross driver.
[ame="https://www.youtube.com/watch?v=Uf7LsE9ipmI"]SASCA Autocross run 1 of 4 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=rXCRn4r4LH4"]SASCA Autocross run 2 of 4 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=2Nt2ww4yc68"]SASCA Autocross run 3 of 4 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=HPPvcfnRurU"]SASCA Autocross run 4 of 4 - YouTube[/ame]
... his name is...
C'THULHU
Old 05-20-2014, 03:05 PM   #161
Turkish
Serial Cone Killer
Turkish's Avatar
Measured my fenders again today and it looks like my springs have settled an additional half cm. Front OEM measurement from fender to center hub cap was 36cm and rear was 36.5cm, now that the springs have settled they measure at all four wheels 34.5cm, converted to imperial is 0.6" drop in the front and 0.8" drop in the rear.
... his name is...
C'THULHU
Old 05-23-2014, 01:40 PM   #162
Turkish
Serial Cone Killer
Turkish's Avatar
I have a question/request for those following my build thread. After I get my front camber sorted out and get the drivetrain more tightly secured, my next purchase will likely be tires (but not for a while as I need to let funds replenish themselves a little bit).
I am torn between Dunlop Direzza ZIIs (on closeout from Tirerack) and the Michelin Pilot Super Sports (on sale currently) and both are in the same ball park in terms of price for 225/45r17 (~600 for a set of 4). What I want to know is y'alls opinion of each and given those two choices, which would you put on your BRZ/FR-S/GT86?
Thanks in advance!
... his name is...
C'THULHU
Old 05-23-2014, 02:00 PM   #163
Roxy86
Roxy86's Avatar
Drives: Diesel daily / FR-S
Roxy86 is offline   Reply With Quote
Old 05-24-2014, 10:58 AM   #164
Turkish
Serial Cone Killer
Turkish's Avatar
Sent from my SM-G900V using Tapatalk
... his name is...
C'THULHU
Old 05-28-2014, 05:49 PM   #165
Turkish
Serial Cone Killer
Turkish's Avatar
Installed the OEM crash bolts today. I haven't taken a picture of the visible camber angle, but you can tell it has negative camber just by looking at it. Tomorrow morning I'll be taking C'thulhu to get an alignment and will confirm the camber angles. I took a picture of the 16mm bolt next to the 14mm bolt it was replaced by, looks like plenty of room for camber adjustment there.
... his name is...
C'THULHU
Old 05-31-2014, 02:38 AM   #166
Turkish
Serial Cone Killer
Turkish's Avatar
Alignment results are in, -1.2* on both front wheels. That exceeded all my expectations as my stretch goal was -1.0* and my expectation was between -0.5* and -0.8*. On the street the car is perfectly balanced with the car holding a line on a corner at easily 10-15mph faster than with the oem suspension and alignment. This was using the OEM crash bolts. June 8th is my next autocross event and I will give my feedback on my current setup afterwards.
... his name is...
C'THULHU
Old 05-31-2014, 02:40 AM   #167
Turkish
Serial Cone Killer
Turkish's Avatar
Also, last weekend I redipped the front wheels and this weekend I will be redipping the rear wheels, this time I will use more coats so that A) it lasts longer, B) is easier to remove (it is so thin that I can't peel it off, I had to use goo gone which was a ginormous mess), and C) just looks better longer.
... his name is...
C'THULHU
Old 06-06-2014, 04:56 PM   #168
Turkish
Serial Cone Killer
Turkish's Avatar
Swapped out the oil in my transmission on Wednesday. As expected, shifting is a lot smoother and it is now a lot more obvious when I am in gear.
... his name is...
C'THULHU
Call me OLD!!?? DrDuquette Off-Topic Lounge [WARNING: NO POLITICS] 49 07-23-2012 01:45 AM
GOT THE CALL!!!! Plxdjake89 Scion FR-S / Toyota 86 GT86 General Forum 13 07-20-2012 05:54 PM
I got the call..... 2pt5RS Southeast 23 07-09-2012 08:41 PM
What Will You Call Your 86? phm14 Scion FR-S / Toyota 86 GT86 General Forum 52 06-23-2012 09:36 PM
