Old 11-27-2013, 12:57 AM   #155
ayau
Drives: Some rust bucket
Originally Posted by aCab View Post
Did I miss a complete parts number list? Just had warranty work denied on my DI seals, so I have to do them myself. Anyone have an SST tool I can borrow? I'll pay shipping.
Why did they deny you? For tracking your car?
Old 11-27-2013, 07:39 PM   #156
Dan@AWD
Drives: 2013 Argento FR-S
Originally Posted by Dezoris View Post
You already swapped the direct injectors on 1 and 3? Did you do compression tests?
if you did I would only suggest replacing the opposing cylinder coil and DI. You have a stable flash or you on oem ecu tuning?
One of my plugs died. All fixed.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 11-27-2013, 07:41 PM   #157
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
so the plug was the reason for the code ?
Old 11-27-2013, 08:12 PM   #158
Dan@AWD
Yes
Old 06-06-2014, 12:32 AM   #159
Tico
Drives: Toyota GT86
Most useful information I've found on the Net ever
I can't begin to express enough gratitude for this info. I live in Peru, and I got the popping noises and P0352 coil errors after tracking. Local dealer was clueless. So I had to hunt for info and found this thread. Then I went to the dealer again and explained the whole thing the best I could to them, and they have now discovered the blown seal and failed injector and will honor the warranty. First case here. The bad news is there are no replacement parts whatsoever in stock in the entire country (only 60+ GT86s sold here), so it's gonna take a while to get the car back into shape. While I was researching, I ordered some Okada coils thinking that was the main issue. Not so sure they will be necessary now, but maybe they won't hurt either. I haven't modded anything in the engine, as I was playing it safe during my first year of ownership, and have only modded wheels, tires, catback exhaust, and KW V3 suspension. Gonna have to wait before installing LCAs and Camber plates until later.
Awesome info, great video and excellent follow-up posts, folks. Can't thank you enough. I really enjoy tracking this car.
Tico is offline   Reply With Quote
Old 06-11-2014, 12:34 AM   #160
whataboutbob
AutoX-10/10ths every run
Add me to the club. Car goes in Fri to see what happens.
Build thread:Here
Old 06-11-2014, 10:14 AM   #161
suaveflooder
You the first automatic?
suaveflooder is offline   Reply With Quote
Old 06-11-2014, 11:24 PM   #162
Dezoris
Dezoris's Avatar
Glad to see it helped hope you are back on road soon.
You having issues with popping?
Old 06-12-2014, 12:58 AM   #163
whataboutbob
Yep. Almost 57K now, 20K+ SC'd. Just ordered the tool. Going to the dealer Fri to see what happens, honestly planning to fix it myself. Car is currently parked, driving my Tacoma for now.
Thanks for the video (and associated work), I'm sure I'll be watching it a few times in the next couple of weeks.
Build thread:Here
Old 06-13-2014, 09:14 PM   #164
whataboutbob
Misfires on 3 of 4 cylinders at about 5K RPMs. Tool on order. Parts will be ordered next week. Possibly first AT to have DI seal failure?
Build thread:Here
Old 06-14-2014, 12:27 AM   #165
Dezoris
Dezoris's Avatar
I'll get back to you tomorrow with parts list.
Probably want to order coils too if you had a ton of heat buildup.
Old 06-15-2014, 05:25 PM   #166
whataboutbob
Will be tearing into the car this week in the eves after work. Will post photos and make some comments as I get into it.
Build thread:Here
Old 06-16-2014, 10:32 PM   #167
whataboutbob
Just to be clear here, I don't have any evidence that this is related to the tune. I did have Bill do a custom 91 tune w the PPE header/overpipe and the 70mm pulley. I had issues with the PPE headers ratlling, and swapped back the OEM parts without reverting back to the 8.58 tune. That may have induced the problems I have now. It is too early to tell at this point.
I'm going out in the garage now to pull the blower and try to get at the DI units.
Details to follow.
Build thread:Here
Old 06-17-2014, 02:34 AM   #168
whataboutbob
So here are some photos from the tear down tonight. I managed to get the IC'd blower off in 1 hour. Not sure what to make of the state of the seals, but I will be replacing them one way or another.
Build thread:Here
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Injector / seal failure or Miss-fire codes.. please post here mad_sb Engine, Exhaust, Transmission 378 04-24-2020 06:33 PM
Direct Injector Leaking Carwhisperer Issues | Warranty | Recalls / TSB 356 03-13-2020 12:35 PM
Direct Injector Failure Poll track_warrior Issues | Warranty | Recalls / TSB 553 01-12-2017 06:12 PM
Direct Injector's Leaking Carwhisperer Scion FR-S / Toyota 86 GT86 General Forum 1 05-11-2013 09:31 AM
