07-21-2013, 10:54 PM | #155 | |
Drives: 2013 WRB BRZ Limited
07-21-2013, 11:13 PM | #156 |
AutoX-10/10ths every run
Yes. I also have the Whiteline camber bolts on my setup.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | console_cowboy (08-02-2013) |
07-22-2013, 02:37 AM | #157 |
Drives: 2013 Hot Lava FR-S 6 MT
I'm curious about these top mounts ... I just put in some RCE Tarmac IIs, and they reuse the stock top mounts, which I have to be honest, is not ideal in my mind having seen how it all goes together. These look like a much better solution to a coilover assembly than reusing stock tops ...
Have the issues been fixed with these yet? What are some alternative top mounts if these aren't fixed yet? |
07-22-2013, 11:59 AM | #158 |
Drives: 2013 FRS Asphalt
I had a koni yellow blow this weekend. Not sure if the top hats binding and popping caused the issue or not. Sent Jan a email as they were going to send me another set that I passed on since my setup was working so well. Then the koni blew now I'm ready to try the washers.
2013 Scion FR-S AT Picked up 5/30/2012
The Following User Says Thank You to feldy For This Useful Post: | whataboutbob (07-22-2013) |
07-22-2013, 01:03 PM | #159 | |
Are you on Konis to?
07-22-2013, 03:13 PM | #160 |
No. Still running the stock guts on the struts.
07-22-2013, 10:32 PM | #161 |
Seņor Member
Can anyone tell me what the number on the Koyo bearing is? And is it just pressed into the steel insert?
I sell bearings for a living and i'm curious if an uprated bearing could be pressed in to replace the one that ships from whiteline.
1974 TA22 Celica
2013 86 GT |
07-22-2013, 11:14 PM | #162 |
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] Last edited by whataboutbob; 07-22-2013 at 11:42 PM. |
The Following User Says Thank You to whataboutbob For This Useful Post: | Turdinator (07-23-2013) |
07-22-2013, 11:55 PM | #163 | |
Seņor Member
This leaves me wondering what the stock strut tops have in the way of a bearing. EDIT: It doesn't look like the bearing in the whitline top is easily replaced looking at that picture.
1974 TA22 Celica
2013 86 GT Last edited by Turdinator; 07-23-2013 at 12:08 AM. |
The Following User Says Thank You to Turdinator For This Useful Post: | whataboutbob (07-23-2013) |
07-23-2013, 12:25 AM | #164 |
Here is a shot of the factory ones. 6302RS.
07-23-2013, 12:29 AM | #165 |
Notice the dents on the factory dust seals?
07-23-2013, 01:02 AM | #166 |
Seņor Member
Interesting! Thank you again for the photos. It is the same bearing so the whitlines should be fine. I would argue that the RS seal is better than the Z sheild in this application but i doubt its the source of the problem. The dents in the seal aren't something i want to see in a stock setup tho. My next line of thought is that the additional camber/caster is either putting too much misalignment through the bearing or is increasing the loads on the bearing. Or both.
Either way it doesn't look like there is a quick fix for existing owners of these. Hopefully whiteline finds a fix soon.
1974 TA22 Celica
2013 86 GT |
07-23-2013, 09:26 AM | #167 | |
Drives: Black 2013 FRS
07-23-2013, 09:39 AM | #168 |
Seņor Member
Just a thought before i nod off, for those running KWs etc, you could potentially put a small needle thrust bearing between the conical washer and the spring top thing to stop any binding. I can check tomorrow at work what size is available. It would raise the front of the car about 3 - 4mm (roughly 1/8") but I doubt anyone would notice.
1974 TA22 Celica
2013 86 GT |
Similar Threads | ||||
upgraded mounts? | 7thgear | Engine, Exhaust, Transmission | 19 | 01-11-2013 11:31 PM |
Buyer Beware: Motor Mounts | cobrabyte | Engine, Exhaust, Transmission | 5 | 01-04-2013 08:14 PM |
Autocross Camera Mounts? | fritzy | BRZ First-Gen (2012+) -- General Topics | 7 | 08-03-2012 10:48 PM |
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports | Font Motorsports | Interior Parts (Incl. Lighting) | 2 | 07-03-2012 06:43 PM |
Dash Mounts for gadgets | smbrm | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-28-2012 07:07 PM |
