#155 |
Imperfect
Drives: 2025 C8 Z06s and more!
Thanks for making this thread. I've been away from the game for a while but looking to get back into HPDE on a monthly basis.
What's the best option in brake pads and brake fluid to combine with an entirely stock BRZ with stock tires? Longevity and peace of mind are my primary concern. Last time I had the FR-S, I ran with DS2500's and Motul RBF600... Was very happy, unless someone advises otherwise... Please feel free to quote a post, I'm sure this has been brought up or asked already somewhere. Thank you kindly for any assistance possible.
#156 |
Thanks
Brake Pad Manufacturer: Carbotech XP10
Caliper: OEM Rotor Size: OEM Compound: ? Tires: 225/45/17 RE11A Brake fluid: Motul RBF 600 Feedback: This is my second set of these. I had to buy another set because the first set I ran with OEM tires and they wore uneven. I attribute it to not lubricating the contact point in the OEM caliper. For this set I frequently lubed with silicone paste and have even wear on them. I really like these pads. If you don't mind street noise they are great on and off track. But by the time back from track they are squealing so that's up to you. Never had a soft pedal with these pads and fluid but the fluid turns dark after a few track days. I ran 5 days on OEM tires and did a bleed. After the 3 days with RE11A the fluid already darkening. I just installed a AP Racing Sprint kit and bought another set. I have 5 track days line up so I'll be able to post another review in early november with that kit. Scores: Dusting: n/a can't tell I only drive to track and back on them, I wash track wheels after each event Cold bite: 10, makes stock pads feel like you need to bleed brakes Hot bite: not enough experience to rate Modulation: not enough experience to rate Noise: 2 on street, squeal after transfer layer wears off which is by the time you get home from track day 9 on track, no noise on track, makes abrasive sound at low speed paddock Pad Lifespan: 3 days on them (6 hours) looks like they have 1 day in them, probably take a wheel off and check them after second and third session of 4th day Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? no Brake ducts: no
#157 |
Brake Pad Manufacturer: Hawk
Caliper: OEM Rotor Size: OEM Pad Compound: DTC-60 Tires: 245/40/17 Hankook R-S3 Brake fluid: ATE Super Blue Feedback: This is my first set of track compound pads for the BRZ. Once properly bedded, "street" noise was hardly noticeable driving to/from the track, only a slight squeal when coming to a stop with very light pedal pressure. The pads have a huge amount of bite, and after 2 days at the track I still felt like I wasn't using the full potential of the pad and I should be braking later and harder. Scores: Dusting: (1=low-10=high) 7, a lot more dust than OEM pads, although I have nothing to compare to for track pads Cold bite: (1=low-10=high) 5, ok, but much better when hot Hot bite: (1=low-10=high) 10, incredible Modulation: (1=low-10=high) 8, great, the harder you brake the faster they slow you down ![]() Noise: (1=extremely loud-10=quiet) 5, they squeal with light braking en route to/from the track, none while on the track and hard braking Pad Lifespan: (1=short=10=long) ?, too early to tell, i've only had 2 track days on them Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N) N, not that I have seen yet Brake ducts: (Y/N) Y, APR kit Last edited by acj47; 10-17-2014 at 03:18 PM. |
#158 |
Drives: Toyota GT86, Mazda MX-5 NB
Run Ferodo DS2500 in front only and both front and rear configuration.
Brake Pad Manufacturer (F/R): Ferodo / OEM and Ferodo / Ferodo Caliper (F/R): OEM Rotor Size (F/R - IE OEM or specify): OEM Compound (F/R): DS2500 / OEM and DS2500 / DS2500 Tires: Michelin Pilot Super Sport 215/45 R17 Feedback: Great pads for medium to frequent track use. Massive improvement over OEM pads. Very difficult to impossible to bed-in on a public road. You need to generate quite some heat and maintain it for a while, applying the brakes consistently. So the first week before the track day they were very noisy as well. That goes away after proper bedding, and I was actually surprised how quiet they become later. Beware: cold bite seems to be worse than with the OEM pads, which you have to remember using them daily. With DS2500 in the front and OEM pads in the rear I found there was not enough balance. Trail braking would rather result in ABS start working in the front before any rotation happens at the rear. Especially with OEM tires (which I also had for a short while) there was not enough grip in the front compared to how much the brakes can do and the front would just drift out. With DS2500 both in the front and rear, trail braking became easy, and the ABS doesn't go crazy as well. Pads lifespan is pretty good. The pads on the front lasted for four track days and two autoX events. However there is impact on OEM rotors: apparently, DS2500 can withstand much higher temperatures than the OEM rotors, which led to front rotors covered with a kind of "web" - not structural cracks, but some impact on the surface (can post pictures later). The rotors are still fine, but will probably have shorter life. Overall very happy Scores: Dusting (1=high-10=low): 3 Cold bite (1=low-10=high): 4 Hot bite (1=low-10=high): 8 Modulation (1=low-10=high): 5 with front only and 8 with front and rear Noise (1=extremely loud-10=quiet): 9 (after bedding properly) Pad Lifespan (1=short-10=long): 7 Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? N Brake ducts: N |
#159 |
Drives: #1553 10 Series FRS
Thanks to CSG for these
![]() Brake Pad Manufacturer (F/R): Winmax W4 Fronts, OEM rear Caliper (F/R): OEM Rotor Size (F/R - IE OEM or specify): OEM Compound (F/R): W4 Tires: 255/35/18 Federal RS-R Brake Fluid: Torque RT700 Feedback: Super happy with these pads, had them on today for my first track day, great pedal feel, experienced absolutely no fade even with some heavy braking sections. They make some very light noise when lightly applying the brakes but it's not annoying at all. Very, very happy with them. Scores: Dusting (1=low-10=high): 4 Cold bite (1=low-10=high): 4 Hot bite (1=low-10=high): 8 Modulation (1=low-10=high): 6 Noise (1=extremely loud-10=quiet): 9 Pad Lifespan (1=short-10=long): (estimate/actual) Cannot comment yet. Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N)No Brake ducts: (Y/N)No |
#160 |
Brake Pad Manufacturer (F/R): Winmax F/R
Rotor Size (F/R - IE OEM or specify): OEM Compound (F/R): W4 Tires: 245/40/17 Hankook V12 Evo 2 Brake Fluid: Motul RBF600 Feedback: Thanks to @CSG Mike for helping me choose a pad that would work best for me. These brake pads were amazing this past weekend as I did not experience any fade during my (4) 20 minute sessions. After bedding them in, I've encountered minimal noise during city driving, with light squeals during track duty. Scores: Dusting (1=low-10=high): 5 Cold bite (1=low-10=high): 4 Hot bite (1=low-10=high): 9 Modulation (1=low-10=high): 7 Noise (1=extremely loud-10=quiet): 8 Pad Lifespan (1=short-10=long): (estimate/actual) TBD Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N )No Brake ducts: (Y/N) No |
#161 |
Site Moderator
Drives: Stuff
Brake Pad Manufacturer (F/R): Project Mu
Caliper (F/R): Essex Sprint kit front (AP CP8350), stock rear Rotor Size (F/R - IE OEM or specify): Essex Sprint kit front (basically stock diameter), stock rear Compound (F/R): 999 front and rear Tires: Hmm good question, 225/45/17 Rivals and/or 235/40/17 AD08 Feedback: I bought these from @CSG Mike awhile ago but completely forgot to post this review. Sorry about that guys These pads remind me of the CL RC6E I normally run but with a little more pad wear compared to the RC6E. The 6E is an endurance pad though so that's to be expected. These do have more initial bite than the RC6E but it's not crazy high (I don't love pads with a massive amount of initial bite anymore). The pads are not squishy/soft, they feel like sintered pads (I'm not sure if they are). They were able to take some serious heat as I did try to push them beyond their limits but they turned out to be *very* consistent from lap 1 to the end of a 45 minute session. They break away from the rotor very smoothly (something I also love about the RC6E) when you lift, unlike some of the other pads I've used on this car (cough cough C300..). Due to the firm pedal and consistency these pads provide a good level of confidence in the brakes, and with the Essex Sprint kit I don't see these overheating or failing under any remotely reasonable usage. They are a bit costly, but they are fantastic pads and I'd suggest a set to anyone who is looking for a brake pad that can take some serious heat while staying consistent in behavior and feel. Like the CL RC6e they also didn't crumble as much as the AP C300s. Dust washed off easily enough and pad consumption wasn't terrible. Noise on the street is unbearable but that's common with these brakes and high end track pads.Overall a great track pad IMO. Scores: Dusting (1=high-10=low): 5 Cold bite (1=low-10=high): 7 Hot bite (1=low-10=high): 9 Modulation (1=low-10=high): 10 Noise (1=extremely loud-10=quiet): 2 on the street, 8 on the track - I can never keep these high temp pads bedded in on the street. Pad Lifespan (1=short-10=long): 8/unknown as I've only used ~3mm of pad in 3 days of usage (estimate/actual) Does the brake dust with this combination damage the wheels/paint if not cleaned immediately? (Y/N) N, although it didn't sit for all that long Brake ducts: (Y/N) N
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#162 |
Drives: Scion FR-S
Hi Everyone, I need to buy break pads for the track. My FRS is now only used for track days, and I have about 14 more to go this year. I just did MRLS, and stock is just not cutting it anymore.
I have two friends. One drifts for scion/toyota, one is an NCAA champ and has been racing for 20 years. They both have two different opinions: 1. Drift friend: He said, "Hp Plus or any of the blues ones" from here: http://www.tirerack.com/brakes/brand.jsp?brand=Hawk **Here's the link of choices only for FRS: http://www.tirerack.com/brakes/resul...3&autoModClar= So looks like the "blue ones" are not an option here. 2. Race Friend: He said, "Carbotech F: XP8 and R: AX6" from here: http://ctbrakes.com/pads.asp I have absolutely no idea which to choose. But I need these ASAP. I have read a lot of the posts, and I don't seem to see anything specific about this combo from carbotech and I don't know enough about break pads to analyze the difference between the two and say which is better. My purpose for these breaks are track days only, not really drifting. I may do that once or twice this year, but tracking is my thing. Thanks for help and input you smart knowledgeable car people
#163 |
Some say.....
Drives: 2007 Subaru Impreza 2.5i
The twins get upset with staggered compounds. Use the same front and rear.
I love my Carbotechs. XP10s for the last 3 seasons. Going to XP12 this year unless I bite the bullet and get myself an Essex Sprint BBK |
#164 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
I've got some Project MU HC+ on order, I don't see many people if any posting how they like them so far, anyone else have anything to chime in with?
#165 |
Drives: Toyota 86 GTS
I really liked them for track performance. I've only tried stock and then these. Dusting and noise are an issue for street use afterwards, needs regular rebedding.
#166 |
Drives: GT-86
#167 |
Drives: GT86
#168 |
Drives: '14 WRB BRZ 6MT Limited
Does anyone have a preferred source for OEM rotor blanks? Would be nice to find a cheaper alternative to running down the local dealership.
| Anime Discussion Thread | ERA | Off-Topic Lounge [WARNING: NO POLITICS] | 2698 | 02-14-2024 11:55 PM |
| Gundam Universe - General All Discussion Thread | poormans_LFA | Off-Topic Lounge [WARNING: NO POLITICS] | 273 | 03-23-2014 11:45 PM |
| S2000 vs BRZ at the track: track oriented discussion | CSG Mike | Tracking / Autocross / HPDE / Drifting | 33 | 01-13-2013 06:54 PM |
| Track/Racing Discussion | Allch Chcar | Tracking / Autocross / HPDE / Drifting | 9 | 05-26-2012 04:39 PM |
| Forza 3 vs. GT5 Discussion Thread | Snaps | Off-Topic Lounge [WARNING: NO POLITICS] | 386 | 03-06-2011 12:10 AM |
