Old 05-18-2013, 01:45 PM   #155
swift996
swift996's Avatar
Well a little disappointed but took the car to the dyno.
Dyno Dynamics:
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-18-2013, 02:42 PM   #156
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
I thought you had put higher numbers on a different dyno?
TRD_07 is offline   Reply With Quote
Old 05-18-2013, 11:02 PM   #157
IloveBaldEagles
IloveBaldEagles's Avatar
Drives: Gray.
I had to leave early, was supposed to be at work when I stopped by this morning. Wanted to personally see the dyno pull. What number range were you expecting ?
I am very insecure. I have no friends. I want people to love me
Old 05-19-2013, 09:18 AM   #158
swift996
swift996's Avatar
I did 180whp on a dynojet. I was expecting somewhere around there. I was just disappointed because there was a bone stock BRZ there that put down 156-159whp.
Old 05-19-2013, 10:18 AM   #159
swift996
swift996's Avatar
Here was the bone stock plot:
http://i271.photobucket.com/albums/j...pseb93d08e.jpg
It seems weird that my torque number would be lower. The only change I did was lower the car about 1.2"
Old 05-19-2013, 10:30 AM   #160
IloveBaldEagles
Drives: Gray.
Not an expert but could lowering have an effect on tension? If tension on the hub is changed then the force factor pushing down on the wheel will have an effect on it spinning. This is where either lighter wheels come in or the height needs to go up by about half an inch.
Old 05-19-2013, 05:33 PM   #161
swift996
swift996's Avatar
It might have, I know my buddy who runs stock cars said they play with that to get a certain reading.
Old 05-19-2013, 05:36 PM   #162
swift996
swift996's Avatar
I'll be ordering my tires either tomorrow or the next day and get them mounted and put on.
After having the R2s for a couple days my takeaways:
- Turn in is much better
- Seems a little bouncy on the streets around here (even with little compression/rebound)
- The car just goes, tires are showing the weakest link - they break traction much easier
I rigged up the reservoirs, wrapping them in some padding and zip tying them to the strut tower. I might try and build a custom bracket to have them clean under the engine bay, until then this works for now.
Sitting low:
Old 05-24-2013, 08:27 PM   #163
swift996
swift996's Avatar
Update -
So I got my Dunlop Direzza D2s in. I had NTB try and put them on but they had an ancient machine and were afraid they'd mess up my rim. They were having an issue getting it on. So I have an appointment at Merchants tomorrow morning.
I also fixed the noise from the coilovers. I tightened the top nut. The driver's side front and passenger's side rear were a little loose. I also raised the car about 2 threads to add more pre-load.
The car is sitting just a little bit higher, but no more clanking from the front:
Lotus Evora trying to flex:
Old 05-24-2013, 09:31 PM   #164
delusional
B R Z
delusional's Avatar
Drives: BRZ 6MT Limited
Originally Posted by swift996 View Post
I just threw it on and took it for a spin. It has a nice rumble at idle, but around 3-4k rpms some rasp starts to come on. It's a good amount louder than stock. Sounds similar to adding a cat back. It's hard for the butt dyno to work properly with the added noise, so I'm not sure if the car is quicker. The nice thing is if you're soft on the accelerator or cruising it still sounds stock. I'll leave it on for a couple of days and see if I want to keep it. I need to figure out if I'll keep it on for the dyno next saturday or not.
did it rasp with just uncatted front pipes or with uncatted front pipes and the muffler delete?
delusional is offline   Reply With Quote
Old 05-24-2013, 11:03 PM   #165
swift996
swift996's Avatar
I never put the muffler delete on, it was with just the uncatted front pipe. I think it's due not only to the removal of the cat but also the OEM front pipe has a resonator on it.
Old 05-26-2013, 12:43 PM   #166
swift996
swift996's Avatar
Update:
So after NTB couldn't mount them Merchant's tried and apperently my wheel broke their machine. So I loaded up the rims and tires (yes 4 fit!) and went to Tires Plus. They mounted them no problem but my car was too low for their lift. I took them home and installed them myself this morning. I was out at Shenandoah Raceway all day yesterday helping a friend run late models. I unfortunately had to raise the car in the rear just a little bit more to play it safe. The car is probably back to about stock height but the wheel gap is gone.
The car has great turn in and excellent grip. I only took it for a quick spin so it will take a little time to get use to. The staggered fitment changes the dynamics of the car a little bit, but wow it's fun.
I plan to have the car aligned the middle of the week and run a little negative camber up front.
OEM vs my rear:
With the BBS center caps on:
Nice little shot:
For a bunch more photos:
http://www.ft86club.com/forums/showp...4&postcount=25
Old 05-26-2013, 03:26 PM   #167
f0rge
head of infinite swagger
Drives: 2013 FR-S 6MT
car looks badass
2019 Golf R 6MT - current daily...I need another coupe
2008 Civic Si - winter beater
2000 Silverstone M5 6MT - SOLD
2013 Ultramarine FR-S 6MT - Car Journal - SOLD
2004 AlpineWhite M3 6MT - SOLD
f0rge is offline   Reply With Quote
Old 05-26-2013, 08:10 PM   #168
swift996
swift996's Avatar
2013 BRZ Limited (black) Epictetus Cars for Sale/Trade 2 11-14-2012 11:38 AM
My crystal black brz limited chadz Member's Car Journals 37 09-12-2012 06:26 PM
BRZ, Black, 6MT, Limited...DELIVERED! boarder1995 BRZ First-Gen (2012+) — General Topics 3 06-14-2012 04:03 PM
Need a black AT Limited trim BRZ! jaytaurus Northwest 4 05-18-2012 05:29 PM
