#155 |
Drives: 2013 Raven FRS
I just got these wheels (17x8 +45) and I need some tips. I got Muteki super tuner lug nuts, but my mechanic said they were a tad too narrow at the base and the wheels would come loose. Also, he recommended I get hub centric rings. So two questions:
1. Which lug nuts will fit perfectly with these wheels? 2. Which hub centric ring size will fit perfectly with these wheels? Any answers will be greatly appreciated!!! Edit: Hub centric rings are 56.1x73. Still don't know what's up with the lug nuts though! Last edited by CombatFetus; 04-23-2015 at 05:53 PM. |
#156 |
Drives: 2017 86
I have the same wheel and use these:
Muteki 32925BP SR35 Series Black 12mm x 1.25" Thread Size Closed End Lug Nut Search Amazon or Ebay. |
#157 |
Hisnamewasrobertpaulson
Drives: 2017 Golf R
i have the titans in hyper black, the lugs i used were muteki sr48 [ame="http://www.amazon.com/Muteki-SR48-Open-End-Nuts/dp/B007N6CG7O/ref=sr_1_3?ie=UTF8&qid=1429825293&sr=8-3&keywords=muteki+sr48+lugs"]Amazon.com: Muteki SR48 Open End Lug Nuts - Burning Blue Neon 12x1.25 48mm: Automotive[/ame]
This is your life and it's ending one minute at a time.
#158 |
Thanks for the replies guys I appreciate it. A couple more questions on the hub centric rings, are they even required? I will be doing a couple track days this summer. And will a 73.1 to 56.1 ring fit a 73mm rim?
Edit: 73.1 fit 73 with a hammer to help
#159 |
Drives: White BRZ Limited
So I forgot to update here. But I bought the 17x9 titans in sports bronze and wrapped them in 255/40 continental DW's fit perfect and love the way they sit and look
| The Following User Says Thank You to Sgtfluffy16 For This Useful Post: | RobertPaulson (08-14-2015) |
#160 |
Drives: 2017 Golf R
the weds in the same size are 14 lbs and the xxr's are around 22-23
#161 |
Drives: 10 Series #974 6m/t
#162 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
link to picture
17x8 +45 with 235/40/17 Toyo Proxes T1 Sport's. Love the set up, better than the 225/45/17 Pilot super sports I was running on 17x7.5's before. Love it, very happy with the purchase.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build Ceramic Coated Gruppe-S UEL/OP Konig Hypergrams RS4 200tw Koni Yellows, Eibach Springs Ferodo DS2500's
#163 |
Drives: 2013 Ultramarine FRS
#164 |
Drives: 2017 ISM PP BRZ
Needle in a haystack question- will an OZ Alleggerita 17x7.5 +48 fit over the Brembos on a 2017 Performance Pkg BRZ? OEMs are the same size but clearance is about spoke design as well as offset of course. Anyone have insight on that particular wheel? It's a used set I've found...
#165 | |
Seρor Member
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | SuperTom (08-22-2017) |
#166 |
Thanks for the help
#167 |
Drives: 2017 Brz
will these clear the brembos?
| Group Buy - Rota Slipstreams or Rota Grid | davidsolarbell | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 12-17-2013 01:04 PM |
| Wheel Directory: Rota Grid 2 17x8.0 +38 | stvrjs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 09-02-2013 05:08 AM |
| Rota SDR in Gunmetal? | zooki | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-10-2012 01:08 AM |
| Wheel Directory Rota PWR 18x9.5 +35 | gabeg86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 10-31-2012 02:38 PM |
