Old 04-27-2022, 12:34 PM   #155
Ebush
Drives: 2017 Hot Lava 86
Originally Posted by PulsarBeeerz View Post
It will be interesting to see the FA24D swaps once there are more chassis out there and they come down in price. I don't see the engine ever being as "cheap" as a FA20D. Hmm $7500 really isn't a lot for a swap setup that drops right in and passed emissions vs $12k+ for the Kswap just to make the same power.
I'm into my kswapped 86 for $7000. Usdm k24a2's can be found on eBay for cheap if you look hard enough. I paid $750 shipped for mine, so location wasn't even a factor. Only issue with the motor was stuck injectors. Im using the full kpower kit without ac, and could have come in at less than $7000 if I had been using a clutch that was compatible with the swap. I sold my fa20, act clutch, hks header, perrin over pipe, hks front pipe, and verus aos for $6500.
I think the fa24 will be great for someone that's either a diehard Subaru fan, or someone with a blown fa20 that just wants a oem upgrade.
The k24 swap is definitely on the pricey side IF you have a stock car with blown engine and don't have any parts to sell.
Ebush is offline   Reply With Quote
The Following 2 Users Say Thank You to Ebush For This Useful Post:
Irace86.2.0 (04-27-2022), jmimac351 (04-28-2022)
Old 04-27-2022, 02:18 PM   #156
RedReplicant
Drives: None
I'm into mine roughly $2.5k, but I had a supercharged motor setup with all of the goodies to part. Total cost right now is about $14.5k, but that includes a couple grand of parts that weren't required.
RedReplicant is offline   Reply With Quote
The Following User Says Thank You to RedReplicant For This Useful Post:
Old 04-29-2022, 11:40 PM   #157
PulsarBeeerz
Drives: JRSC BRZ SOLD
No, lie I completely forgot you can sell the current FA20 setup to help cover the cost.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
RedReplicant (04-30-2022)
Old 05-05-2022, 04:10 PM   #158
elBarto
elBarto's Avatar
Drives: Toyota GT86
Originally Posted by BrahmaBull1990 View Post
Not sure if people have been following EMS Tuning:
The engine is running and has been on the dyno.
Facebook video of the engine running
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
The Following 6 Users Say Thank You to elBarto For This Useful Post:
BrahmaBull1990 (05-07-2022), NoHaveMSG (05-05-2022), PulsarBeeerz (05-05-2022), RedReplicant (05-05-2022), Spuds (06-16-2022), Yobiwan (05-06-2022)
Old 05-05-2022, 08:49 PM   #159
FrickingReallySlow
Drives: 2015 FR-S
Pretty awesome, FA20 Heads and FA24 Shortblock!
most likely FA20 ECU since its cracked already. I have serious doubts that the newer gen2 ECU can be cracked to the same point where anyone can load a tune with ODB anytime soon. The GR Yaris ECU apparently needs to be sent in to a tuner to get a tune flashed on there. sort of like a tethered jailbreak in the iOS world.
Hold on to those gen1 ECUs!
FrickingReallySlow is offline   Reply With Quote
Old 05-05-2022, 09:23 PM   #160
soundman98
ProCrastinationConsultant
soundman98's Avatar
with that gauge cluster, i suspect they're running an aftermarket ecu. no reason to run a different gauge cluster if using the gen1 car that comes with a gen1 ecu and gen1 gauges.
The Following 3 Users Say Thank You to soundman98 For This Useful Post:
PulsarBeeerz (05-05-2022), Spuds (06-16-2022), Tatsu333 (05-06-2022)
Old 05-05-2022, 10:29 PM   #161
PulsarBeeerz
With the EPA cracking down on ECU tuning as a whole, it will be interesting to see how it goes.
sato (05-07-2022)
Old 05-06-2022, 01:53 PM   #162
elBarto
elBarto's Avatar
Drives: Toyota GT86
It's using a standalone ECU. They wanted to use a gen1 ECU but it was easier to go standalone atm. Maybe later but I doubt it since it's a track only car.
Old 05-07-2022, 10:27 PM   #163
Four_wheel_drifts
Drives: Whiteout track car; lava donor
Any mention, anywhere, if the main bearing oiling issue is fixed with the new engine?
Four_wheel_drifts is offline   Reply With Quote
Old 05-08-2022, 12:00 AM   #164
BrahmaBull1990
Howdy
BrahmaBull1990's Avatar
Drives: 2020 BRZ PP
Awww the days of Pawnage Tool for the original iPhones and iPods. I used to do it at school and charged $10 haha
There's a point at 7,000 RPM... where everything fades. The machine becomes weightless. Just disappears. And all that's left is a body moving through space and time. 7,000 RPM. That's where you meet it. You feel it coming. It creeps up on you, close in your ear. Asks you a question. The only question that matters. Who are you?
BrahmaBull1990 is offline   Reply With Quote
The Following User Says Thank You to BrahmaBull1990 For This Useful Post:
meWant (06-22-2022)
Old 06-16-2022, 09:26 AM   #165
Conti93
Conti93's Avatar
Drives: '02 Speedster n°586 - '23 GR86
Eh, 299,8Nm at 4582rpm from a 2,4 liter?
We're in race engines territory, I highly doubt that's accurate...
Still, out of curiosity today I asked a local Subaru dealer in Italy if I could order the OEM shortblock for the 2022 BRZ which is NOT sold here (thank you EU), and surprise surprise, I can order one for a little less than 2500€ VAT included
I've tried emailing EMS Tuning to no avail, who knows if they used the FA24 upper oil pan and what else is needed... Still, I'm tempted.
Conti93 is offline   Reply With Quote
The Following User Says Thank You to Conti93 For This Useful Post:
Spuds (06-16-2022)
Old 06-16-2022, 09:44 AM   #166
Kylejc1219
Was waiting to get more info on this tread before I decided to pull the trigger on doing a short block but looks like this is going to need more time. Quick question for anyone who would know, would there be any benefit to using a fa24 timing cover/oil pump on the fa20? I figured at the very least it wouldn’t hurt but maybe there’s fitment issues? I kinda doubt it, seems like the parts are similar enough. Hoping the new part improves some of the infamous oiling issues.
Kylejc1219 is offline   Reply With Quote
Old 06-16-2022, 09:57 AM   #167
Conti93
Conti93's Avatar
It seems the only FA20/24 hybrid functioning atm is the EMS Tuning one, which didn't disclose much detail. Like nothing of it. Zero, except for a dyno pull which is fishy for a 2,4l running on 98 RON gasoline.
For the timing cover if you plan to use the stock first gen ECU you need to verify if the cam angle sensors are in the same place at least.
Old 06-16-2022, 12:57 PM   #168
FrickingReallySlow
Drives: 2015 FR-S
Lets revive this project people! @Opie have you asked if they can sell you a shortblock now? or let someone with a 2022 GRZ order one for you with their VIN?
I think the major question is the still the machining of the head cylinder volume to get it back to the right compression
The Following 3 Users Say Thank You to FrickingReallySlow For This Useful Post:
alphasaur (06-16-2022), Spuds (06-16-2022), T-Steve (06-17-2022)
FA20 vs FA24 Zata Engine, Exhaust, Transmission 15 06-01-2023 11:18 AM
FA24 In-Depth Look Kona61 GR86 General Topics (2nd Gen 2022+ Toyota 86) 36 10-11-2021 09:27 AM
Second Gen Swap? FA24 AutoNewb Engine Swaps 86 07-06-2021 11:55 AM
FA24 Mix n Match RiceCracker86 Engine, Exhaust, Transmission 1 04-18-2019 04:59 PM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 01:33 AM
