Old 02-28-2022, 01:52 PM   #155
spcmafia
spcmafia's Avatar
Drives: 2018 Subaru BRZ
Originally Posted by Wally86 View Post
Did some cleaning and I'm finally getting rid of that dishwasher that came with my house... ten years ago... I've been using it as a shelf in the garage but I bought some shelving to replace it with this weekend.
If you're also looking to get rid of the quick-jack I'll kindly take it off your arms. Save you even more room.
Old 02-28-2022, 02:13 PM   #156
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I can put a sticker on the dishwasher that says quick jack if you'd like
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
The Following 3 Users Say Thank You to Wally86 For This Useful Post:
Dadhawk (02-28-2022), soundman98 (02-28-2022), spcmafia (02-28-2022)
Old 02-28-2022, 03:01 PM   #157
spcmafia
spcmafia's Avatar
Its something /*-*/.
The Following User Says Thank You to spcmafia For This Useful Post:
Wally86 (02-28-2022)
Old 08-14-2022, 08:58 PM   #158
soundman98
ProCrastinationConsultant
soundman98's Avatar
time for a bump!
got a free 18" dishwasher from a customer. sorta an oddball size, so was a long shot when i started looking a few years ago.
was going to be tricky, as none of my cabinets are a standard size. going both ways off the sink, i've got 15", 36" lazy suzan units, and then pair of 37" cabinets.
i went to the left. the plan? remove the 15" cabinet, then cut down the lazy suzan to fit.
cabinet came out simple enough, but turns out my sink "cabinet" is just a facia front panel with a a hacked in raised floor and toekick. wasn't expecting that.
ended up salvaging the removed cabinet side panel to make a sink panel side
then had to pull apart the lazy susan and 're-size' it to make everything fit.
cutting down the rotating assembly of the lazy susan, and marking out how to get the rear panel to re-wrap back around to the front
lazy susan cut down. i knew it was going to reduce my space, wasn't expecting this much! but it is what it is...
and the finished product
of course, no project is without it's surprises
all-metal undersink drains, starting to rot out, the 1 is held together and not leaking only by rust/corrosion. needed to re-pipe anyways to get the dishwasher drain in, good thing too, this was already on borrowed time!
all piped in and almost read to go! lots of crud in the old setup for some reason
i was all set, and celebrating not having any leaks, then everything plugs up and water starts backing up the drain...
i knocked some of the sediment somewhere loose re-piping it, it's clogged somewhere.
so after all that, NOW i need to call a plumber this week to roto rooter out the line...
The Following 4 Users Say Thank You to soundman98 For This Useful Post:
humfrz (08-15-2022), NoHaveMSG (08-14-2022), Spuds (08-15-2022), Wally86 (08-15-2022)
Old 08-14-2022, 09:27 PM   #159
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Can't believe you are single.
Old 08-14-2022, 10:17 PM   #160
soundman98
soundman98's Avatar
Jdmjunkie (08-15-2022), Sapphireho (08-14-2022), Spuds (08-15-2022), Wally86 (08-15-2022)
Old 08-15-2022, 03:47 AM   #161
humfrz
time for a bump!
Hell, it would have been easier just to get a wife to wash the dishes -
Old 08-15-2022, 12:15 PM   #162
Dadhawk (08-15-2022), humfrz (08-15-2022), soundman98 (08-15-2022), Teseo (08-31-2022)
Old 08-15-2022, 05:04 PM   #163
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Who gets a dishwasher at Walmart?
The Following User Says Thank You to Spuds For This Useful Post:
Old 08-15-2022, 05:54 PM   #164
Sapphireho
Famous Potatoes
Sapphireho's Avatar
I get mine at Victoria's secret.
The Following 4 Users Say Thank You to Sapphireho For This Useful Post:
Captain Snooze (09-24-2022), soundman98 (08-15-2022), Spuds (08-15-2022), Tcoat (08-15-2022)
Old 08-15-2022, 06:15 PM   #165
Well Walmart dishwashers are well equipped even if a bit cheap.
humfrz (08-16-2022), NoHaveMSG (08-15-2022), Sapphireho (08-15-2022), soundman98 (08-15-2022), Spuds (08-15-2022), Wally86 (08-16-2022)
Old 08-15-2022, 06:18 PM   #166
Not for me, too tall, lanky and they all seem to walk funny.
I prefer the local strip joint, at least then you know exactly what you are going to get.
Short of that, Weight Watchers is good, at least you have a better than even chance she can also cook and do dishes.
The Following 5 Users Say Thank You to Dadhawk For This Useful Post:
NoHaveMSG (08-15-2022), Sapphireho (08-15-2022), soundman98 (08-15-2022), Spuds (08-15-2022), Tcoat (08-15-2022)
Old 08-15-2022, 11:36 PM   #167
soundman98
soundman98's Avatar
that was plan a. it's been 5 years, time to move to plan b!
humfrz (08-16-2022)
Old 09-23-2022, 10:01 PM   #168
Stonehorsw
Stonehorsw's Avatar
Drives: 18 Brz (Sold) / 22 BRZ
Lately had to do some maintenance
1. Refilled ar-conditioner gas (took me a while trying to figure out what the issue was, until someone gave me a hint, to check line pressure
2. Replaced fridge evaporator fan
Youtube, google and asking the right people saves a lot of money.
Stonehorsw is offline   Reply With Quote
The Following 2 Users Say Thank You to Stonehorsw For This Useful Post:
bcj (09-24-2022), soundman98 (09-24-2022)
diy, home, living
Brought my BRZ home today Smokinbuffalo Northwest 8 06-01-2012 12:49 AM
WRB-Got it home!!! jaytaurus BRZ First-Gen (2012+) — General Topics 28 05-29-2012 12:33 PM
#64 brought home today. FujiwaraTofuShop Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 10:04 AM
