Old 04-03-2024, 02:30 PM   #155
Espi
Espi's Avatar
Drives: 17 BRZ
Would a rear wing have any reduced benefit with the B6/B8s for track? Or better to pair with coilovers?
Espi is offline   Reply With Quote
Old 04-04-2024, 11:26 AM   #156
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by ZDan View Post
Sachs weren't great for me. Stock, they were unduly harsh over bumps, classic too-much-high-speed-damping. Felt racy/go-karty in test-drives, but not the way good trackworthy damping works. When I got Swift springs, which lowered the car more than expected, in concert with Raceseng camber plates which lowered the front even more, about 35mm total, the front Sachs struts were just unbearable, with zero front bump travel. They were *hard* on the front bump stops statically. Even with front bump stops cut down and a 6mm spring spacer, they were awful over the smallest bumps. Bilstein B8s *transformed* the car. Way way WAY better damping, massively reduced harshness, and made the car able to swallow up bumps on the street and curbs at the track.
Anyway I have a set I would sell for a lot less than used Bilsteins. Because they aren't *nearly* as good, on the street or at the track. Not even close...
This has been pretty much my exact experience with PP shocks, TRD springs, and Raceseng camber plates. It's been pretty tiring to drive on Midwest roads, especially after moving to Detroit. All your posts have get me heavily considering throwing some B6s on. Will see how soon I'm ready to pull the trigger, and whether or not SS1s come back in stock soon...
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 04-04-2024, 01:48 PM   #157
ZDan
ZDan's Avatar
Drives: '23 BRZ
Going to Bilsteins was transformative for my car. *WAY* more front bump travel, went from unliveable to being an absolute pleasure to drive on the street and at the track.
Shark_Bait88 (04-04-2024)
Old 04-04-2024, 03:38 PM   #158
Espi
Espi's Avatar
Drives: 17 BRZ
Specifically the Verus low drag rear wing
Old 04-05-2024, 10:00 AM   #159
Racecomp Engineering
No issues really, though with real downforce you'd want stiffer springs.
- Andrew
Racecomp Engineering is online now   Reply With Quote
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Espi (04-05-2024)
Old 04-30-2024, 12:23 PM   #160
JIM THEO
Drives: BRZ 2018
I installed before a month the B6 with the STI aftermarket springs from the STI suspension package (https://www.sti.jp/en/parts/subarubr.../ST20330AS010/) and I could say they work much better than anything else I have tried except the Ohlins R&T coilovers!
JIM THEO is offline   Reply With Quote
The Following 2 Users Say Thank You to JIM THEO For This Useful Post:
Racecomp Engineering (04-30-2024), Shark_Bait88 (05-02-2024)
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 shattered_memory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 01-04-2017 11:22 AM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 03:12 AM
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts FRSport.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 02-25-2016 12:50 PM
Ok, who has stories that can't be explained? husker741 Off-Topic Lounge [WARNING: NO POLITICS] 143 11-26-2014 05:25 AM
Part of the problem explained. Suberman CANADA 95 01-28-2014 01:26 PM
