Old 07-03-2021, 02:50 PM   #155
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Originally Posted by Greg_2086 View Post
I preface this with I have not taken apart my dash yet, but stumbled across while digging into whether the front dash and door speakers are wired in parallel or series and how the rear amp jumper might impact impedance versus using the amp.
If this unused connector still exists in the 2020's, it might minimize the adapter harness FR-S2GT86 is making for the no-cut factory wire/adapter harness solution since the antenna adapters would no longer be needed.
Possibly D29 Option Connector in the wiring image below?
Given that the antenna turn-on and amp turn-on are energized when the vehicle is in ACC or ON and whether the head unit is manually on or off versus being controlled by the head unit (referring to FR-S2GT86's post #140) this might be another source to tap the amp turn-on into instead of the antenna turn-on.
Maybe oddrelic or FR-S2GT86 could test the functionality of this?
The tweeters and 3" mid-range drivers in the dash are indeed wired in parallel to each other and are normally powered by the OEM head unit on the front channels.
The factory also taps off of those speaker circuits and sends that full-range speaker level signal back to the door speaker amplifier in the trunk, where it either:
(a) feeds the amplifier it's signal, then gets filtered and amplified and then sent back up to the door speakers, or
(b) it gets immediately sent back up to the door speakers through the bypass harness, unfiltered and unamplified.
The problem with the situation described in (b) above is that now the head unit has to bear the burden of two extra 2-ohm speakers, which makes them sound like crap. In reality, according to some here, it makes the entire system sound like crap, and I would suspect the reason behind this is that the front outputs of the head unit are distorting due to a low damping factor in the built-in head unit amp. Most aftermarket amplifiers aren't even stable at loads less than 2 ohms in stereo mode, let alone factory head unit amplifiers.
The guy in the video that you posted was installing an aftermarket head unit, which has the necessary antenna/amplifier turn-on outputs. The Harman head unit does not have a turn-on lead that matches up to the amplifier turn-on wire in the dash harness, which still requires us to use the antenna turn-on lead to power up the amplifier which will still require an integration harness to use, if cutting and tapping wires in your vehicle is a problem for you.
The one special feature of the antenna turn-on lead coming out of the head unit is that after you turn off the vehicle, there is a slight delay, before the head unit de-energizes that turn-on lead (See @oddrelic's description of the delay in post #136). If you use an ACC controlled wire to turn on and turn off the amplifier, it de-energizes it immediately, with no delay, and you will hear strange things, like what @trueno86power described in his latest comment above, (post #153) which is what using the antenna turn on lead instead should solve.
Perhaps I'm misunderstanding your inquiry?
Originally Posted by Mr.ac View Post
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following User Says Thank You to FR-S2GT86 For This Useful Post:
trueno86power (07-03-2021)
Old 07-04-2021, 02:45 PM   #156
Greg_2086
Drives: 2020 86
Thank you for the informative wiring/impedance information, which is what/why I was looking into it and what I was able to conclude. It would seem by using the jumper in the 2020's the door speakers become parallel with the dash tweeters and mids already parallel at 2 ohms...thus the head unit front channels are driving 1 ohm. Theoretically increasing power, but more likely causing other issues like heat, distortion, etc. in addition to the fact the door speakers are no longer using the trunk amp low-pass filter.
I was just sharing that the person in the video found an unused 6-pin harness (in addition to the rear speaker 6-pin harness) with a 12v turn-on. Possibly providing a way to make an adapter harness using only 10 and 6-pin adapters. But like you and trueno86power mentioned, this turn-on might cause other unwanted issues like noise, etc. if it energizes/de-energizes too quickly.
2020 86 Neptune, TRD handling package, TRD lowering springs
Build Thread
Greg_2086 is offline   Reply With Quote
The Following User Says Thank You to Greg_2086 For This Useful Post:
FR-S2GT86 (07-04-2021)
Old 07-04-2021, 03:41 PM   #157
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
You can take an actual resistance measurement of each parallel speaker circuit at the amplifier. Take a look at this diagram, which represents the ten-pin vehicle harness at the amp: (ignore the wire colors in this example, go by pin positions)
With the male end of the vehicles’ ten-pin amplifier connector plugged into the female bypass plug, if you measure across any of the pin circuits indicated with different color arrows at the wire side of the plug, you should get the total resistance load measurements of that circuit.
For instance,
Measuring across the two pins indicated by the blue arrows or the black arrows will give you the value of the total resistance load for the right side front speaker circuit.
Measuring across the green or the white arrow-indicated circuits will give you the value of the total resistance load for the left side front speaker circuit.
All three speakers for each side are wired in parallel with the bypass plug in place. I would be interested in knowing what those measurements are.
Old 07-04-2021, 05:57 PM   #158
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Since an ohmmeter is uses a battery as a voltage source this will give you the DC resistance of the circuit under test which is to say the resistance at 0 Hertz. What would be of more interest is a graph of circuit impedance (the vector sum of capacitive and inductive reactance along with resistance) from 20 Hertz to 20 Kilohertz. Not as easy to come by but much more indicative of amplifier load across the audio spectrum.
LimitedSlip is offline   Reply With Quote
Old 07-04-2021, 08:43 PM   #159
86-75309
Drives: Until recently, a 2020 Hakone 86
Speaker impedance will vary quite a bit with frequency. As I recall from my past life working with professional sound reinforcement equipment, a typical 8 ohm rated speaker would register in the neighborhood of 6.2 ohms of DC resistance. I'm guessing a 2 ohm speaker array would be around 1.55 ohms and a 1 ohm speaker array would measure around 0.77 ohms on a meter. I'm surprised there are 2 ohm car audio components, but I've been disconnected from audio for a few decades. Back in my day, 2 ohms was dangerously close to a dead short and was to be avoided at all costs.
86-75309 is offline   Reply With Quote
The Following User Says Thank You to 86-75309 For This Useful Post:
LimitedSlip (07-04-2021)
Old 07-05-2021, 01:04 AM   #160
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
It would be nice to have an impedance meter that can measure a circuit of multiple parallel speakers in a sweep from 10Hz to 20kHz and display a graph of the results.
Old 07-15-2021, 01:30 AM   #161
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I have finally completed the DIY for building and installing the plug-and-play harness for re-integration of the OEM door speaker amplifier into the Harman audio systems, see the first post in this thread here,
https://www.ft86club.com/forums/show...11#post3446011
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
Greg_2086 (07-15-2021), saltywetman (07-31-2021)
Old 07-21-2021, 05:59 PM   #162
If you have one of these units go to his DIY.
GO THERE NOW.
Don't wait.
Don't fart around.
Go there.
chaoskaze (09-20-2021), FR-S2GT86 (07-21-2021), saltywetman (07-31-2021), soundman98 (07-21-2021), Wally86 (07-27-2021)
Old 08-23-2021, 06:33 PM   #163
Greg_2086
Drives: 2020 86
Now that I have completed the wiring modification to use the trunk mounted door speaker amplifier, I wanted to update that I also looked to see whether the existing 24-pin connector is still present in my 2020 86 wire harness as far as a plug and play solution for the reverse camera on the 2020 Harman head unit (referencing vitriumGTS post #22, reh8388 post #34, and trueno86power post #44). Unfortunately it is not...so a more complex modification is still needed to bring it down from the rear view mirror to the head unit.
Build Thread
FR-S2GT86 (08-24-2021)
Old 09-20-2021, 01:34 AM   #164
nettech_gt
Drives: GR86
I have not been able source a company that will ship a Kenwood DDX919WS to the US... Can some verify the 2020 86 headunit will work in a 2017 BRZ with an OEM Audio+ system? Plug in play? Thanks.
nettech_gt is offline   Reply With Quote
Old 09-20-2021, 11:52 AM   #165
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I'm certain that we can get it to work, but if it's the Harman head unit that you're wanting to install, we'll have to make a few minor modifications.
Old 09-20-2021, 12:07 PM   #166
nettech_gt
Drives: GR86
Yes, I want to install the model with Car play/AA. What type of modificats are needed? Thanks.
Old 09-20-2021, 05:17 PM   #167
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Speaker level signals from the Harman head unit are relatively the same as the original '17 OEM head unit, so those will connect up and work just fine. The amplifier output for the Harman head unit, however is a negative output and won't turn your amplifier(s) on. It will end up popping the head units' fuse, so you'll have to de-pin the amplifier turn-on wire from the 10-pin harness behind the head unit and use the antenna output wire to power both the powered antenna and your amp(s).
Here is a DIY write-up on that which you can use as a guide:
https://www.ft86club.com/forums/showthread.php?t=145959
Make sure to read the link on installing the new Harman head unit that Toyota provided their dealers which is included in the write-up as you will have more plugs and harnesses to have to deal with than what my DIY write-up addresses.
The only differences in your car will be the lack of the yellow bypass harness at the OEM amplifier in the trunk so you won't have to worry at all about re-integrating the factory door speaker amp. And you might also have to install the newer single trim piece to fit around the head unit. Just make sure you try and physically fit it into the dash with your existing trim pieces first.
If you have any questions, just post them in that thread and we'll get it all sorted out in there.
Old 09-27-2021, 01:18 AM   #168
nettech_gt
Drives: GR86
Thanks for the guide! Just so we are on the same page, I have a OEM Audio + (Reference 450Q) system. Will your guide still apply? Also will I retain the use of the factory mic and backup camera?
https://oemaudioplus.com/wp-content/...EF450Q_Web.pdf
audio, head unit double din, mp3, stereo, usb port
2020 86 TRD info? Vr4gasmtt Scion FR-S / Toyota 86 GT86 General Forum 18 08-27-2019 03:41 PM
Android based stereo vs. stereo w/ Android auto redlined600 Electronics | Audio | NAV | Infotainment 12 02-24-2019 03:53 AM
2013 BRZ Nav Stereo For 2016 BRZ Starlink Stereo brzsubarusti13 Audio/Visual, Electronics, Infotainment, NAV 11 02-27-2016 07:33 AM
Stock FRS stereo on Toyota 86 - Wiring problem position lights turn on/off the stereo dssence Electronics | Audio | NAV | Infotainment 0 01-27-2015 07:43 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
